Question about Frigidaire Ovens
F3 code for model # pleb30s8ccc oven - Frigidaire Ovens
SOURCE: GE Model JTP15 oven shows F3 error code
I have the same problem. I noticed that the oven gets to the selected temp ok. Then when the pilot attempts to RELIGHT, it gets the error F3. Did you get a solution? After other posts, I will see if the temp sensor is around 1100 ohm as suggested by others. Ken
Posted on Sep 24, 2007
protek480
  • 1723 Answers
SOURCE: Kenmore Model 665 95781000 Stove Displays a EO-F3
F3 - E0 Oven temperature sensor (RTD) opened (upper oven, if double oven) Replace Oven temperature sensor (RTD)
Posted on Sep 26, 2009
rylee_smith
  • 8619 Answers
SOURCE: How to Fix Code F3 on GE Oven
Hi
Thanks for using FixYa. Error F3 in your range/oven means oven temperature sensor circuit failure. To resolve this issue you’ll have to check the oven temp. sensor circuit if the reading is more then 1100ohms then it should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 04, 2010
blueextc3221
  • 15935 Answers
SOURCE: Error Code E2 F3
The F3 E2 error code indicates that the electronic oven control board in the range senses an over-temperature condition in the oven.
This can be caused by a failed temperature sensor probe, a wiring problem between the sensor and the control board, or a failed electronic oven control board.
If the oven is apparently not overheating when this error code appears, then your likely failure is the temperature sensor probe.
If the oven is overheating, then you likely have a failed electronic oven control board due to a stuck relay not cycling the oven heating element off properly.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%%%%
Posted on Sep 29, 2010
chrispolkele
  • 4342 Answers
Our people make the difference
    Verified Fixya Pro
    SOURCE: Frigidaire model FEF352CATB has a F3 error code
    Hi - Typically error code F3 indicates a faulty sensor probe or wiring harness between sensor probe and EOC. Try resetting the range by unplugging it or flipping the circuit breaker off for two minutes (this usually will clear most false error codes). Turn on the range and if resetting the unit proves to be ineffective, I would recommend contacting a professional to move forward accurately.
    Posted on Oct 16, 2012
    Fault code E4 F3
    The F3 codes mean that the oven temperature sensor has a problem. In the case of the E4 error, it is an open circuit. (If the GR465XLS0 is a double oven model, it's the lower oven with the problem with the sensor.)
    You need to replace the sensor. Unfortunately, I'm not sure that you have provided the correct model number. Most Whirlpool ovens have an extra character in the model number. If your model is the GR465LXLS0, the temperature sensor will cost ~$65. One source is http://www.appliancepartspros.com/Appliance-Parts/whirlpool-oven-sensor-assembly-item-number-ap4326911.aspx .
    I hope this helps.
    Sep 07, 2012 | Whirlpool Ovens
    Tip
    Whirlpool oven, stove and range fault codes (ERC and EOC display errors).
    Here a list of Whirpool oven fault codes. The codes had been collected from different service manuals. This was a memo that I wrote for my own use. I think this can be useful to owners and technicians.
    WHIRLPOOL - most models
    Range/Stove and Oven Fault Codes, Common error codes.
    F1 - Analog control board Failure
    Disconnect for one minute - if error comes back, replace control board
    F1 - Shorted control keypad
    Replace keypad
    F3 - Oven temperature sensor open
    Replace oven temperature probe
    F2 - Oven temperature sensor shorted
    F3 - Oven too hot
    F3 - Clean temperature too hot
    Replace oven probe
    F5 - Door latch switch fault
    Test and replace the door switch.
    Whirlpool with 4 Digit Failure Code:
    F1 - E1 - Electronic control (flip flop)
    Replace control board
    F2 - E0 - Shorted control keypad
    Replace keypad
    F3 - E0 - Oven temperature probe open
    Replace temperature probe
    F3 - E1 - Oven temperature probe shorted
    F3 - E2 - Oven temp too high
    F3 - E3 - Clean temp too hot
    Replace temp. probe
    F5 - E0 - Check door latch
    F5 - E1 - Check door latch
    Replace switch if defective
    WHIRLPOOL Polara models 5 digit codes:
    F1 F0 - EEPROM communication error
    Replace ERC
    F1 E1 - EEPROM checksum error
    Replace ERC
    F1 E2:7 - UL A/D errors
    Replace ERC
    F1 E4:2 - Model ID error
    Reinsert keytail.
    F1 E6:0 - Latch signal mismatch error
    Replace ERC
    F2 E0:4 - Shorted key error
    Replace keypad assembly
    F2 E1:3 Keytail unplugged
    reinsert the keytail
    F3 E0:5 Top oven sensor open
    Test and replace top probe.
    F3 E1:6 Top oven shorted
    Test and replace temp probe
    F3 E2:9 Bake range over temperature
    F3 E3:8 Clean range over temperature
    Test and replace temp probe.
    F3 E4:10 Bottom oven sensor open
    F3 E:15 Bottom oven sensor shorted
    F5 E0:14 Door switch errot
    Test and eventually replace door lock switch
    F5 E1:16 Door latch not operating
    Test and eventually replace door latch
    F8 E0:17 Refrigeration error
    Test the cooling module.
    PF Power failure - Does not indicate a fault.
    PF occurs when power is disconnected.
    WHIRLPOOL
    Models SF3, 30'' and 24"
    F2 - Oven temperature above specifications
    Check 8-pin connector from temp. probe to Electronic Oven Control
    F3 - Open oven temperature probe failure
    Check wiring, replace oven probe if necessary
    F4 - Shorted oven temperature sensor failure
    Check wiring harness, replace oven temperature probe if necessary
    F5 - Push button stuck or faulty
    Check for binding of pushbuttons and control panel glass. If OK, replace touch panel
    F6 - Electronic control logic error (timing)
    Replace Electronic Range Control (ERC)
    F7 - Electronic control logic error (lock motor)
    Replace ERC.
    F8 - Electronic control logic error
    Replace ERC.
    on Jan 31, 2010 | Whirlpool RBS305PDS Electric Single Oven
    My built in oven AKZ 110 is showing F 03 and nothing happens when I try to tune it in to work just stays on F 03 no fan no light either
    This should help any further assistance please feel free to contact me.
    WHIRLPOOL
    Range/Stove/Oven Fault Codes Non Y-Line
    NOTE: Not valid for Y line. If there is a Y near the end of your model number, do not use this chart.
    Failure
    Code
    Condition Check/Repair 4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock (ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock (ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock (ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
    2. Test relay contact operation
    3. High resistance in oven temperature sensor F3 Open oven temperature sensor or thermal fuse Replace oven temperature sensor or thermal fuse F4 Shorted oven temperature sensor Replace oven temperature sensor F6 Problem in time keeping circuit 1. Reset time and/or cooking operation
    2. Check for proper ground F7 Stuck function switch or button on Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F8 Failure Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F9 Door lock circuit Check wiring and test operation of door lock switch bkg-faultcodedivider.jpg txt-gototop.jpg WHIRLPOOL
    Range/Stove Oven Fault Codes, Common
    Failure
    Code
    Condition Check/Repair Digit Failure Code2 F1 Analog to Digital Failure Disconnect for 30 seconds - if display reappears - replace control board F1 Safety flip flop Replace board F1 Shorted keypad Replace keypad F3 Oven temperature sensor opened Replace oven temperature sensor F2 Oven temperature sensor shorted Replace oven temperature sensor F3 Oven too hot Replace oven temperature sensor F3 Clean temp too hot Replace oven temperature sensor F5 Check door/latch switch Replace switch if defective 4 Digit Failure Code F1 - E1 Safety flip flop Replace board F2 - E0 Shorted keypad Replace keypad F3 - E0 Oven temperature sensor opened Replace oven temperature sensor F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace switch if defective
    Jul 16, 2011 | Whirlpool Ovens
    F3 code model 9114558819
    The F3 error code indicates that the EOC (Electronic Oven Control board) senses a problem with the oven temperature sensor. You could have a defective sensor, a failed EOC or a bad wiring connection between these 2 components.try replacing the sensor first yu can have it mailed to you directly from marcone appliance parts
    Jul 25, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
    Lower oven message E3, E0, F3
    on maytag's a F3 means shorted or open oven temperature sensor. google your models oven number codes.
    Jun 22, 2010 | Ovens
    GE Wall Oven JTP 10GP F3 code when I turn it on it goes straigt to F3
    on our maytag a f3 code means shorted or open temperature sensor. do not know if that code is the same as a ge, but you can google your oven model codes and find out what the problem is.
    Jun 21, 2010 | GE Profile JTP18 Electric Single Oven
    Kitchen aid wall oven Model YKEBS2780B1 SHOWS
    Hello,4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock(ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock(ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock(ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
    Thanks
    May 26, 2010 | Ovens
    Kenmore Model 665 95781000 Stove Displays a EO-F3 code and the oven does not work WHat part work be defective to give me this fault code EO-F3?
    Sep 25, 2009 | Ovens
    Error codes
    Hello raco1
    Welcome
    I need your model number to look up the fault code !!!!
    You said , you see fault codes, FD F3 and E2 F3 is showing up on display pane
    Looks like this may be your problem
    F3 - E2 - Oven to hot -Replace oven temperature sensor
    Waiting for your response.
    When responding send me this whole communication . Not just your answer!
    Thank you Huuum.
    Oct 03, 2008 | Whirlpool RBD305PD Electric Double Oven
    Error code F03
    although i don tknow what model your talking about all the F3 codes in ovens is pointing toward bad oven sensor, replace oven sensor
    Mar 16, 2008 | Ovens
    Ovens Logo
    Top Frigidaire Ovens Experts
    Dan Webster
    Dan Webster
    Oloyede Monsuru
    ashburton
    Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
