Question about Samsung "UN40D5500 40"" LED TV "
Micom upgrade On Service menu I accidentaly clicked on Micom Upgrade and then turned off the tv because I freaked. Any fix without replacing the main board?
2 Suggested Answers
ctf1800
  • 4402 Answers
SOURCE: no sound or picture
HLP, HCN HL-S The Start-up Problem or/and
3 LEDs in the front blinking.
Unplug the set, pull out the lamp module (not all the way - leave it on the track) and push it back in.
Power issues (Tv not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Posted on Feb 06, 2008
I spilled a liquid in my jvc rx-502ov receiver and a message reads dsp micom ng what do i do?
You fried the poor thing to put it mildly, Get a different one end cut down on your partying ,(GUY) Unless you have money to burn
Dec 05, 2012 | JVC Rx 5020v Stereo Receiver
Sanyo 5-cup Micom rice cooker, no power
I had the exact same problem with my rice cooker. I took the lid apart. There was a broken wire because of the constant friction of the hinge when open and close the lid. After I soldered it, it started to work again.
Jan 29, 2010 | Sanyo Kitchen Appliances - Others
Tv philips 20mf605t no power
write down the number of the micon if that is the component that you are suspecting and go online checking for company from who you can purchase the micon.one such company is dalbani.com and mcmelectronics.com
Aug 29, 2008 | Philips 20MF605T Television
Sharp 32U S50
Maybe a problem in deflection section. If there is a problem in these section the micom ic is trying to protect to continue anymore short circuit. Or there is a leakege in power supply section. This could be fixed by service technician only. Better to call nearby service people.
Jun 24, 2008 | Sharp 32U-S650 32" TV
Monitor
Steve from Monitor Technology. You need to open the monitor and locate the inverter board.
Remove 3 screws,turn the board over and locate 2 caps,C110 and C111.Replace,820UF/35V
this will fix this problem.
thewizguy@comcast.net
May 03, 2008 | Samsung 225BW Monitor
Television will not come on after low voltage surge
Good day.
Check on the horizontal output transistor, vertical transistor, and loose contacts along MICOM and system ICs.
chris
Feb 09, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony32fs120
1. Try your Memory to replace.
2. Check all estated voltage in each particular section.
3. TRy also to replace your MICOM / System IC if your Confused.
Feb 07, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Tv switches itself off then back on again
Hi.
If the tv set is still under warantee get it sorted before gtee runs out.
The problem is caused by cummunication error between ATV Micom and DTV Micom.
To correct this problem requires going in to service mode to make changes & updating the DTV firmware.
This will need to be done by a proffesional.
http://dysonmanuals.llc.nu/
Chris.
Jan 02, 2008 | Samsung LE32R41BD 32 in. HD-Ready LCD...
No sound or picture
Sep 29, 2007 | Samsung HLN467W 46" Rear Projection HDTV
Samsung "UN40D5500 40"" LED TV " Logo
155 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
