Question about Canon PIXMA Office Equipment & Supplies
How do you load photo paper on 5400? i loaded 2 pieces of photo paper on the try with the aligners but it kept saying no paper!!!
SOURCE: Canon pixma ip1800 --- load paper problem
pojkjjj
Posted on Apr 03, 2008
SOURCE: Loading cut sheets
Try to check the paper media set on the plotter (roll/plain paper). It usually happens if paper media is not the same with the plotter setting. To change it, unload the paper, press the media button on the printer to the right media and load the paper again. It should work now.
Posted on Aug 19, 2008
sodeep
  • 3267 Answers
SOURCE: how to load 5x7 photo paper into hp photosmart D7460 ??
Simply set the page layout option to select from printer. Place the cut & proper sized paper in the inlet tray, adjust the sliders so that they just rest lightly against the edge of the paper. Remember only one slider moves and the other one remains fixed to one edge. Click print preview. You might get a message saying paper orientation is not right...should I adjust the printer automatically, click yes and behold it will print in Portrait or landscape mode depending on the matter. If it warns that output does not fit on the media(paper) then select fit to page option.....sodeep
Posted on Mar 22, 2009
fdlixboy
  • 79 Answers
SOURCE: Trouble photo printing
hello.. try to unplug the power cord and usb cord and replug again and also chick the inside part of your printer maybe have a paper jump or ashes due to saying of of paper or try to remove the printer driver software how to remove? go to control panel and click the name (ad and remove program )and you can see the currently install files find your printer driver bellow the currently install files and remove it and install again..........thank you hope i can help you.. have a good day
Posted on Jul 06, 2009
SOURCE: Load A4
any setting needed to print full page A4 in regular Hp printer.The gap I have at the bottom and above is not the same.Pliz help.
Posted on Aug 11, 2009
I have a 5650 lexmark printer and it keeps saying paper jams but there is not paper anywhere.. how can i find a solution... when you load paper it keepps getting stuck.. help
There could be something blocking the paper path. Try to shake the printer upside down. You'll be amazed of the things that falls off inside the printer. Also, make sure that there's no paper left inside the printer. Tiny pieces of paper will still lead to paper jams.
May 31, 2012 | Lexmark X5650 AllInOne InkJet Printer
"Load paper"
hey not a big problem. its usually encountered by many users.
i too get this many times.
this happens when you keep papers freshly.
it needs to sense the papers kept.
now what you do is just keep more papers or try re-aligning the papers kept inside
Dec 27, 2007 | Ricoh Aficio CL2000N Laser Printer
I cant get the printer to align what should i do
IssueA Printer alignment failed error message displays on the product.SolutionFollow these steps to resolve the issue.
  1. Load letter or A4 unused plain white paper into the input tray.
  2. Touch the Setup icon.
  3. Touch the down arrow button (c01093709.jpg) and select Tools.
  4. Touch the down arrow button (c01093709.jpg) and select Align Printer. The product calibrates, aligns the printhead, and prints an alignment page.
  5. Touch OK to close the message.
  6. Recycle or discard the alignment page.
CauseAn incorrect type of paper is loaded in the input tray. If colored paper or photo paper is loaded in the input tray when aligning the product, the alignment might fail.
Jul 21, 2011 | HP Photosmart D7460 Printer
Changed cartridges, printer doesn't align or function
Something seems to be physically wrong in the mechanism.
Try the rolling wheels and the belt on which the cartridges run.
Jul 19, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Driver installation progam says "print head needs alignment" but doesn't say how to do it.
Canon i860
Align printhead automatically:
1) Be sure that the printer is powered on and letter size plain white paper is loaded in the sheet feeder
2) Press and hold the <Resume/Cancel> button, and release it when the Power lamp blinks four times.
The alignment pattern sheet should now be printed out. Wait for the pattern sheet to finish printing.
The printer should stop prompting you for this procedure.
Feb 27, 2010 | Canon i860 InkJet Photo Printer
Will not recognize loaded paper, keeps saying no
There 's a torn piece of paper blocking the paper level sensor. Re check all areas where the paper feeds. the try re insert the paper, if its clear . turn printer off for 5 mins then turn on and try again
Jul 08, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Can't allign the paper.
make sure that the paper roll is pushed all the way down on the rod and the piece that you put on it is fitted snuggly against the roll. When you pull the paper through the feeder pull it about 2-3 feet outward and it should align.
Oct 23, 2008 | Canon iPF700 InkJet Printer
I have installed the HP Photosmart C7280 All-in-One and tried to print an article off the computer. I have paper loaded in the tray-I get a message Out of Paper. Load paper face down in Main Tray. What's...
I experienced the same problem on a HP Photosmart C7280 All-in-one printer. The problem was that the light-blue plastic piece, which covers half of the printing paper tray, had gotten out of alignment with the gray piece which covers the other half of the paper stack. Pull the blue plastic tray out and align it properly.
Apr 11, 2008 | Office Equipment & Supplies
Lexmark 5400 series paper jam
As several previous posts said there was a pieces of paper folded up inside. Per a previous post remove the sheet feeder rack. At this point I removed the two outside screws (of the three) on the backe. After this the whole top lifts about 3/4 inch (19mm) to give your fingers more room to clear it. Looks like she will print another day.
Thanks for the tips on here.
Ken Bowd
Nov 07, 2007 | Brother Multi-Function Center MFC-240C...
18 people viewed this question
old marine
old marine
