Tuner problem The input on the TV will change on it's own without me using the remote or changing it in any other way. It will change from input 1 to 2 to 3 and so on. I can't control the input from changing, and it's impossible to watch tv.
  • Roosterii Jan 03, 2008
    RCA 35" Model F35760MB - 1st the channel you are on will pop and crack you get intermittent static. Sometimes the channel will switch back and forth to other channels. Then TV shuts off and comes back on. About 1/2 of the time the tv works correctly. When it is acting up you can hit the top of tv this will sometimes make it start working right.
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
Your problem is in the system control section of your tv. please check 1 supply to systemcontrol ic or loose contact. 2 supply or loose contact in tunning ckt of tuner (33v zener line) 3 aft ckt loose or defrctive. 4 loose button on remote &front panel of tv. 5 memory ic. 6 system contro ic. 7 check for loose contact in tuner. I think this will help. good luck .
Posted on Sep 29, 2007
6ya staff
SOURCE:
Dig. lg 26 inches trying to get ch 1to 5
This is the low band in the tuner for the set.
If using a cable box unplug it for a while and plug back in for it to reboot.
Also you can route from a box or even an old VCR signal from its audio/video outputs to a set of rear inputs and bypass the TV tuner--use the box or VCR to change channels.
Leave the set on that input and operate without the tuner in the TV.
Apr 01, 2012 | Televison & Video
I can't program my tv to regular antenna channels
You can program to regular (analog) antenna channels. To do so you must use the original remote which has a TV/DTV switch in the top right corner of the remote. Choose the appropriate mode for the type of channel you want to see or scan for. Here is a link to the owners manual and a picture of the remote swithc. The info on the signal switching is on pg.13.
http://tv.manualsonline.com/manuals/mfg/funai/cr130dr8.html?idRes=707655
Oct 27, 2010 | Durabrand DWT1304 13" TV
I have a Toshiba 24af42 with no remote. I am trying to change the input, but without a remote I cannot figure out how to change it. I have tried a universal remote which works for other functions, but not...
Try this website 1-800-remotes Factory original u can buy an original remote,tries Channels up or down couple times u should get in the input 1 or 2.
Oct 22, 2009 | Toshiba 24AF42 24" TV
Universal remote works for basics but won't change input
Rich,
good day , what button can you see infront of your TV screen?
Not familiar with this model but if you'll manage to locate a button marked as "TV/AV" or "AV" press this button until it the display switch to A/V mode (audio/video). Or if this is a really old model, from Tuner mode or channel model. set the channel station to 1 then press the " - channel " button and see if it will change from tuner mode to A/V mode
cheers,
mark
Jan 31, 2009 | Toshiba 32A33 32" TV
Broken cable hook up
sometimes if the tuner is not damaged then a technician can put it back on... the other option is to tune the channel through a vcr.. essentally bypassing the tv tuner and useing vcr tuner. hook the cable to vcr then using rca jacks yellow red and white connect it to you tv(if it has rca jacks ...most have them these days.. sometimes on front and sometime on back or even on the side.. tune your tv to that input(video 1 or something like that.. then using your vcr remote change channel...its not a perfect solution but it will save you the 130 buck most charge to repair that connector
May 01, 2008 | RCA HD61LPW175 61" Rear Projection HDTV
HOW TO SET TV SETTING FOR GAME SETTING WITHOUT REMOTE
Check in the TV menu, there should be a "Input" submenu that will let you change between the Tuner/Video/SVideo inputs.
Apr 30, 2008 | Televison & Video
How Do I Get a DVD to Work with This TV?
Make sure to switch the TV's tuner mode to Video or Aux mode.
You can change the mode using the original TV remote or directly from the TV's control panel.
Again, tuner mode picks up all live broadcast airwaves and Video or Auxillary mode displays what is inputed into the TV via second device..
Good Luck!
Feb 16, 2008 | RCA G32665 32" TV
Promble changing PIP
You have to have the original remote to turn on or shut off the PIP.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Oct 11, 2007 | Sony FD Trinitron WEGA KV-24FS120 24" TV
No channels above 47
That works great except I can get the tuner to program any channels above channel47. Is this a limitation of this older model TV yes there is limitation in old tv. is there some setting I can change in order to get more channels using the tv tuner? in INDIA what we do is put a remote control ckt which gives us about 250 channels. of course we replace tuner also called hyper tuner along with remote ckt or replace whole kit which are cheaply available.& serves the purpose. hope this will help
Oct 03, 2007 | Televison & Video
Tuner problem
your problem is in the system control section of your tv. please check 1 supply to systemcontrol ic or loose contact. 2 supply or loose contact in tunning ckt of tuner (33v zener line) 3 aft ckt loose or defrctive. 4 loose button on remote &front panel of tv. 5 memory ic. 6 system contro ic. I think this will help. good luck . 4 system
Sep 28, 2007 | Sharp 32F640 32" TV
Televison & Video Logo
483 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
