Question about Harmar Mobility Pinnacle Stair Lift - Used
Lift has opperated very good, however it now will travel only about 2 feet & it chatters & won't continue moving up or down . I then use a ratchet wrench to lower the chair to to the lower position again. I believe that I then reset the control & I can run the chai as beforer up again about 2 feet & stops again. . Can you help me ??? Thank you. --- Bob Goff
What is error code 60.02
60.2 is a lifter motor error, this is the motor that lifts the paper into position when you push tray 2 in. They do fail. Restart the printer and watch the paper level on the front of the tray to see if it moves at all. Also listen for any chattering noise is it does lift. Sometimes if the metal panel in the tray that lifts is not moving smoothly this error can occur. Pull the tray out and on the right hand side you will see a geared piece of plastic, rotate it to see if the tray lifts when you do. If not the tray might be the problem not the motor.
Sep 16, 2014 | HP LaserJet 4250n Printer
1998 isuzu amigo 4x4 3" lift front suspension problems no travel verry stiff
if you have lifted the front suspension by 3 inches then that is 3 inches less travel for the shocky piston to move when the suspension goes down. You have probably damaged the piston and shaft of the shocky. Replace with longer travel shockys.
Jun 01, 2013 | Cars & Trucks
Lift is out of vehicle and won't go up or down
Sounds like the jack screw has bound. That requires a complete disassembly and inspection to see if it just needs lubrication or a part.
Feb 27, 2013 | Pride Backpacker Avp Lift SSBPAVP
Will not close
depending on the vehicle you may be looking at a bad sunroof motor, or the regulator(roof track and cables) could be bad, on some cars you can replace these things seperately, and on some you have to replace it all as one assembly. In most cases if you pull your headliner down so that you can see the motor there will be a manual opperation "port" usually a 1/4 or 3/8 drive ratchet opening so that you can manually close the roof until you get it fixed. In most sunroof motors I've seen the manual opperation port is either a red plastic circle with the ratchet drive opening in the middle, or there is a round plastic insert that you have to pull out to access the ratchet opening. hopefully this helps, if not try updating the question to include year make and model of the vehicle. Good luck!
Aug 29, 2012 | Cars & Trucks
How can I get the battery out of my 2005 Hyundai Elantra? I have everything removed to get it out and disconnected the cables but it won't budge.
  • Hi, I can help.
  • If you look down right in from (or behind) the battery onto the battery tray you will see a battery mount.
  • Take a ratchet and an extension and a socket and twist that bolt out and the battery will lift up.
  • That mount keeps the battery from moving and bouncing around.
  • If you have any comments feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards,
Tony
Aug 20, 2011 | 2005 Hyundai Elantra
When I activate the garage door moves up about 2 feet then just continues to go up and down as if stuck but there does not appear to be an obstruction
Use the pull cord and disconnect the opener from the door. Operate the opener and let the carrier slide back away from the door. Is the carrier moving smoothly when disconnected? Next, lift the door by hand from the bottom to the top. Is it moving smoothly? If not, lubricate the axles of all the rollers on both sides of the door. Check the cable pulleys at the top sides of the door channel, lubricate them as well. Are all cables in all the pulleys, there are 4. After checking those things, there is a "up force" and "down force" adjustment on the opener, try increasing the "up force" by turning the adjustment in the direction of MORE force.
Gary
Dec 19, 2010 | liftmaster Chamberlain Garage Door Opener...
Makes clicking noise
clicking noises are generally caused by loose parts (such as loose condenser coils or compressor "tubing rattle") or rollers and feet that sit unevenly on the floor.
Look for any part that is loose. Then remove the bottom trim piece by lifting it off its supports, and check the feet at the front of the unit. If necessary, turn the adjustable feet up or down so they contact the floor squarely.
have a good day!!
Aug 01, 2009 | Refrigerators
Chicago Pnuematic air ratchet runs continuously
under the lever you push to make it operate you will se a pin .if this pin is stuck down the ratchet will run all the time.also this could be a bad O ring on this same part,
May 16, 2009 | Chicago Pneumatic 1/2" Heavy Duty Air...
2000 Cherokee Heater only works once the vehicle is moving
this is normal, heat comes from your motor so it isnt hot enough until you start working the engine
Nov 20, 2008 | 2000 Jeep Cherokee
Harmar Mobility Pinnacle Stair Lift - Used Logo
19 people viewed this question
Top Harmar Mobility Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Harmar Mobility Health and Beauty Expert? Answer questions, earn points and help others
