Question about Home
Kidde help MY CARBON MONOXIDE DETECTOR BEEPS EVERY 12 HOURS AND IF I UNPLUG IT IT VIBRATES WHEN UNPLUGGED
SOURCE: smoke alarm/carbon monoxide detector
I have a First Alert Smoke Detector Model SA 86RAC.When I changed the Battery today it beeps.How do I fix this problem?
Posted on Jul 17, 2008
  • 4 Answers
SOURCE: my kidde smoke and carbon monoxide alarm keeps
You will need to remove the unit from the ceiling to reveal the battery compartment on the back. It should just need to be rotated counter clockwise a small amount and will then come loose from the bracket. When installing a new battey be sure to press the battery reminder finger down into the battery compartment or the battery door will not close. Call the Kidde (pronounced kid-a) hotline if you have problems 1.800.880.6788
Posted on Aug 05, 2009
asnowman
  • 788 Answers
SOURCE: every hour my detector beeps and the green lights
If it only beeps once and then pauses, the batteries are suspect. The batteries should be replaced twice each year. I like to change them when we change the clocks back and forth.
I hope that this helps.
asnowman
Hint you can test them with a match (blow it out) and let the smoke rise into the detector. I recommend that this be done at lease once a year.
Hope this helps
asnowman
Posted on Apr 17, 2010
TeaCii
  • 90 Answers
SOURCE: I replaced the 9 voly battery to the Smoke and
Can you pleas ensure that you have cleaned the unit as well. If it is not broken, that would be the probable cause. You can ask your local fire dept. to assist. They do that for free :-)
Cheers
TeaCii
If you own website, add live support almost free
Real security guard to watch your cctv for $1/day
Posted on Apr 23, 2010
  • 54 Answers
SOURCE: how to fix detector
You don't mention how old the detector is. If it is more than 5 years old the detector may be beeping to indicate the end of its service life. A smoke detector can last much longer but carbon monoxide detectors have a limited life span. If putting in new batteries doesn't fix the problem then most likely you will need to replace it.
Posted on Jun 10, 2010
How can I shut off the beeping when my carbon monoxide monitor is accidentally pulled out of the wall?
Unfortuanely, you can't. The loud beep is in place to alert you to the issue so that you don't get carbon monoxide poisoning.
Jan 10, 2013 | Home
My Kidde carbon monoxide alarm keeps beeping every 30 seconds and we have put new batteries in it but it keeps beeping
Detecotrs have a limited lifespan of 5-7 years. So sounds like you need new one (Its not worth to buy just a sensor). Take a look on amazon Amazon com smoke alarm detector (watch out on reviews). I hope this was helpful. cheers
Jan 09, 2012 | Kidde Carbon Monoxide (KNCOBB) and Smoke...
I have a nighthawk carbon monoxide alarm err message is on and beeps.How do i fix it?
Ur detector not close to the kitchen?Tries unplug,replug or take out the battery of the device like 10 -20 mins and replace it with a new battery.The device should reboot itself.Will correct itself most of the times.
Feb 16, 2011 | Kidde Nighthawk Combo Gas/co Detector
I have a nighthawk carbon monoxide alarm which is showing nan error code. Please can you tell me what to do to rectify it? Thank you.
You can unplug the unit if it's an AC detector, change the battery for a new one and reset the Carbon Monoxide Detector. If that doen't work, you can have it checked by your local fire department. If the unit is more than 5 years old, it absolutely needs to be replaced.
Whenever in doubt about the efficiency of a carbon monoxide detector, a replacement is recommended. Yes, protection has a price, but a life cannot be replaced.
Read more industry information, buy your next Carbon Monoxide Detector here.
Aug 06, 2010 | Kidde Nighthawk Combo Gas/co Detector
My Kidde Nighthawk Carbon Monoxide detector was beeping shrilly and read gas. When pressed the reset button it read 221. Problem was it was sitting facedown in a box (i'd just taken it from my old...
A reading of 221 ppm carbon monoxide gas is a dangerous level that should be taken seriously. You could try a new battery and reset the detector. If in doubt, always err on the cautious side and have the apartment checked by a professional or by the local fire department.
A new carbon monoxide detector is a small investment that may prevent carbon monoxide poisoning or death.
Jul 22, 2010 | Kidde Nighthawk Combo Gas/co Detector
My carbon monoxide detector just has one sold beep and is not plugged in.
I assume you mean your carbon monoxide detector has one solid beep, and it is probably an AC unit. It may be safe to assume that it has battery backup if it is beeping without being plugged in.
First, you may replace the battery with a new one, plug it in and hit the reset button. If that doesn't work, you could bring it in to your local fire department to have it tested.
Check the expiry date on the Carbon Monoxide Detector. It should be replaced if it is more than 5 to 7 years old, check manufacturer recommendations.
A replacement carbon monoxide detector will give you the protection you need and peace of mind. Your safety depends on how fast you deal with this issue.
Jul 07, 2010 | Kidde Nighthawk Combo Gas/co Detector
How can I shut off my Kidde carbon monoxide detector when beeping
Here is the link to the manual for your Kidde model KN-COB-LCB-A
Carbon Monoxide Detector. This may help you solve your issue.
You may find more related information on my website. If you need a replacement or you need to add additional Carbon Monoxide Detectors in other levels of your house, you can purchase them here.
This issue should be solved immediately, Carbon Monoxide Poisoning can only be avoided by making sure you have good working CO Detectors in your house, camp or recreational vehicle.
Jul 24, 2010 | Kidde Nighthawk Combo Gas/co Detector
My nighthawk carbon monoxide alaram is keep biping
Check your user manual for issues dealing with beeping alarms.
Your local fire department may be able to help educate you on the proper installation and use of Carbon Monoxide Detectors. A CO detector alarm should be taken seriously and you should follow the manufacturer procedures included in the package.
NEVER dismiss a Carbon Monoxide Detector Alarm for a malfunction.
ALWAYS treat an alarm as an emergency and follow manufacturer procedures.
Check our website for more industry information or for buying replacement Carbon Monoxide Detectors.
Jul 16, 2010 | Kidde Nighthawk Combo Gas/co Detector
Home Logo
106 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
