Question about Victron MultiPlus Inverter/Charger CMP242020100 Compact 2Kw 24VDC
I have a victron inverter 12v to 220v it was off and functioning, i left home a week and when i came back it doesn't start anymore ... nobody touch it !!!
De inverter switches off indicating low Batteries while according to my monitor ( xantrex charge ) battery bank is 100%. How can I help help it?
use a voltmeter and measure the voltage AT THE INVERTER'S Battery terminals and see if its over 11 volts. You could have a loose connection or a bad cable creating a voltage loss.
Jul 26, 2015 | Victron ENERGY Quattro 24/5000/120-100/100...
Overvoltage protection does not protect anything ...
Have you opened the inverter to view the circuitry. There may be a fuse on the input -if you're lucky. Otherwise, look for burnt components. If you know how to test electronics, test the components on the board for shorts. So unless you are an electronics tech, I think you may be out of luck.
Jun 09, 2014 | Victron Phoenix Inverter PIN024751110 24V...
What kind of Fuse do I need for a THG 1500 power converter?
No idea as not sure what this converter is to start with ,is it a solar 12v to 220v inverter by any chance
May 20, 2012 | Cars & Trucks
I have a problem w the auto Gen. start turning the Gen OFF once it has started it. The lowest voltage setting to turn it off is 14.0vdc the problem w this is it will never reach that voltage. So I set the...
Your experience matches my own. I think the only solution is to use a DC monitor such as the Victron unit which has an external relay. Hook up the relay contacts to the Temp in on the AGS, then set the Victron to trip the relay when the batteries are charged to whatever percent you decide, such as 80%. Use the DC volts to start the gen and percentage of charge to turn it off......
Nov 17, 2010 | Xantrex Technology Xantrex RS2000 Sine...
Power inverter fan don't work
fan should come on when the unit has a load on it and it starts to get hot.
Jun 05, 2010 | Watts 75w Power Inverter 12v Dc To 220v Ac...
I have a gateway profile 4 and the screen does not turn anymore someone told me that i have to change the invertor or bulb can you help me?
Yes change the inverter first it is more common problem cost arround $15 on eBay. If the screen doesn't start or if has a week light you would have to change your screen (arround $90). As it is looks the inverter prob. assuming that nobody drop the laptop by accident. replace the bulb it will be more expensive than replace the screen because it is a lot of hours to work.
Jan 11, 2010 | Gateway Profile 4 All In One (MPN...
My boat refrig works on shore power but won't convert to 12v this only started this week
The inverter that converts the 12 volts to 120VAC is not working. An eletronic repair shop can fix this. refrigertor technician will replace the whole inverter, Or you can order the inverter unit and replace it yourself if you are somewhat a handy kind of person. It is not really that hard to replace them. Make sure first that the inverter is not putting out 120VAC when you connect 12V to it, before you take it to a shop.
Jun 28, 2009 | Refrigerators
Problem with getting inverter to work...
Inverters works from 12v carr battery or backup battery, you can not charge the inverter you msay killed your inverter if you connected to 120v wall mount...you use the inverter to give you AC (electric) from 12v battery. if your tv is 12v you need to know how much needed to get the correct connrection as output and input.
Nov 07, 2008 | Vector Maxx SST Power Inverter
Different HZs problem (from 60Hz to 50Hz)
Yes there are frequency converters available but most are relatively over rated (industrial) for your requirement such as MDS Power or VisiComm Industries. What you need is a Low Power Solid State Frequency Converters lower than a
Electrocon Frequency Converters. However, I expect this devices to be rather expensive.
A few other options you may want to consider:
1. Contact the store where you bought if from; swap with an International version (Model SL-1210 Mark II; same price as SL-1200 Mark II); dual voltage switchable on rear of unit: 120 volts/60 Hz (U.S.) or 220 volts/50 Hz (Europe). You hopefully just spend for the cost of shipping + a restocking fee;
2. Contact 3rd party Technics TT specialist like TopDJGear, Quality Electronics, Planet DJ or DJHardware
and inquire if they would supply you the part(s) that you need to convert the 1200 to a 1210; or
3. Offer a swap on eBay.
Hope this be of some idea/help. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Nov 13, 2007 | Technics SL-1200MK2 Turntable
Victron MultiPlus Inverter/Charger CMP242020100 Compact 2Kw 24VDC Logo
29 people viewed this question
Top Victron Electronics - Others Experts
Are you a Victron Electronics - Other Expert? Answer questions, earn points and help others
