Question about Canon PowerShot Pro1 Digital Camera
Telephoto lens I have added a telephoto lens to my pro 1. I have 2 lens adaptor tubes and a merkury 2x 58 mm lens. When I try to photograph at any distance the object is blurry, out of focus.I have tried only using optical zoom and it still won't focus properly.Every other aspect of the camera is great.Macro works great with the merkury wide angle macro lens & adaptor, it's just the tele lens. HELP, I can't get as close to the deer as I would like without the tele lens.
    Master:
  • 619 Answers
Hi, the adoptor tube are not compatible to the camera try to consult nearest lense seller they can recommend the exact adoptor lenses to your camera.
Posted on Jan 14, 2008
SOURCE:
Need to convert a Vivitar 70-150mm telephoto from Canon TX to Nikon FTn mounts
Vivitar made several different 70-150mm lenses. If the lens has a T-mount then you can purchase a Nikon T-mount adapter and replace the Canon one on the lens. If the lens does not have a T-mount then you're out of luck. Nikon cameras have thicker bodies than Canon cameras, and an adapter would have to have negative physical size.
Mar 16, 2014 | Vivitar Series-1 3.5x Tele Conversion...
Is the Raynox DCR 250 compatible with 75-300mm Canon lens?
Have a look at this page for discussion about this adapter. Depending on the lens you're using it with - the DOF can be extremely shallow and make focusing difficult. If you're in Auto Focus mode - try switching to manual and see if you can get better results.
Aug 21, 2012 | Canon EF 75-300mm f/4-5.6 II Lens
Caqnon G10 shuts off when zooming with an adaptor tube
Yes...the Canon brand is made to work properly with the camera.
Jul 23, 2010 | Canon PowerShot G10 Digital Camera
I have a Canon Powershot S3IS and I recently purchased a 2x telephoto lens. When I use the telephoto lens and try to extend the distance as far as it will go, the camera shuts off and says lens error...
Did you tell the camera that you are using an external/additional lens? You have to specify it somewhere in the menu, the camera gives you some options (the lens model numbers) and you need to match it with your lens' model number.
Sep 30, 2009 | Canon PowerShot S3 IS Digital Camera
I want to use fairly telephoto lens in D3 slr nikon camera
You don't say what sort of telephoto you want to buy or how much money you want to spend but basically anything longer than a 50 mm is regarded as telephoto.
A staring point for you maybe the lens listed below: Nikon Telephoto Zoom 70-300mm f/4.5-5.6G IF-ED AF-S VR
It importantly has VR or "Vibration Reduction" on it to reduce camera blur when hand holding telephoto shots. This is just a staring point... You need to work out what you want to photograph Cheers Ian
Mar 17, 2009 | Nikon D40X Digital SLR Camera Digital...
Nikon Optiphot-2 microscope: tube length?
The Nikon Optiphot 2 tube length is 160 mm DIN finite. It is a 1990 vintage microscope. Any objective lens with the standard RMS thread, -160 engraved on it will work. It will not work with other brnads with the infinity symbol engraved on it or infinity tube length Nikon 200 mm, CFI60 objectives for 2000 vintage to present microscopes. - Lawsen Lew
Oct 22, 2008 | Nikon 7314 Binocular Microscope
Lens adapters
I received an answer on Flickr (almost immediately!) thanks, anyway!
Apr 05, 2008 | Panasonic Lumix DMC-FZ18K Digital Camera
Attachment for filter and hood
If you go to the camera store that sells quantaray then they will be able to order you one if they do not have it in stock.
or you can find one on a online auction site.
you need a step down ring. I believe the size of your lens is 58 mm but you could go to any camera store and ask them to verify that. but it should also be stamped on the front of the lens written in white.
if you find 58 mm anywhere on it then I am right. And that means you need a 72 to 58 mm stepping ring.
hope that helps,
Caleb
Mar 04, 2008 | Quantaray 28-200MM F3.8-5.6 Lens for Canon...
What is the distance range at macro-photography for the DiMAGE Z3?
Macro: Wideangle: 0.1m to 1.0m (from lens front) / Telephoto: 1.2m to 2.5m (from lens front) Wideangle: 0.185m to 1.085m (from CCD) / Telephoto: 1.285m to 2.585m (from CCD) Super Macro: 3cm to 100cm (from lens front), 9.5cm to 109.5cm (from CCD), focal length: 10.45 mm (equivalent to 63mm in 35mm format)
Sep 13, 2005 | Konica Minolta DiMAGE Z3 Digital Camera
Portrait
Well if 1x = 35mm, then 4x = 140mm
Sep 06, 2005 | Panasonic Lumix DMC-FZ20 Digital Camera
Canon PowerShot Pro1 Digital Camera Logo
110 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
sathish kumar
sathish kumar
Are you a Canon Camera Expert? Answer questions, earn points and help others
