Workcentre 7655 fuser system error
3 Suggested Answers
  • 2072 Answers
SOURCE: workcentre c2424 is showing system error 39,003.40:117010
That is a document feed or scanner fault. Often times it is simply that molex connector working loose. It is the connector mounted vertically next to the main power cord on the right rear side of the machine. That bottom screw can be dificult to tighten. What I would try first is to shut the machine off, unscrew and disconnect that conntecot totally then firmly slide it in and get both the top and bottom screwss tight. Like I said, the bottom thumb screw can be hard to tighten even with a screw driver because it is a pretty soft rubber the tighteners are made out of.
If that doesnt work. go to the back and disconnect the document feed to scanner cables and reconnect. Other than that, you pretty much have to replace the feeder/scaner assembly since very very few parts are spared for that .
Posted on Oct 23, 2008
e-Guru
  • 3917 Answers
SOURCE: Close the Tray Top Cover
First disconnect all cables from the workcentre to the computer. Next reboot the computer and restart the printer. Do not connect. First download and install the drivers mentioned in the link bellow on the system to which the machine is primarily is connected.
http://www.office.xerox.com/multifunction-printer/color-multifunction/workcentre-7655-7665-7675/sprt-enus.html
Now while installation it will ask you to connect the printer. Connect the cables now and I am sure the error will disappear. If the error is still there then its a manual problem with the hardware and you need to carry it to a local hardware shop to get some part replaced.
Thanks
Posted on Jan 22, 2011
Model 7665. What do fusher system errors 10.311.00 and 10.322.00 indicate?
Both of those indicate a defective fuser, replace fuser, part number 008R12988.
http://www.iteminconline.com/008r12988_008r12988-8r12988-622s00044-622s44-xerox-docucolor-250-fuser-assembly-110v-compatible-with-docucolor-240-250-workcentre-7655-7665-7675-7755-7765-7775-new.htm
Jan 10, 2016 | Xerox Office Equipment & Supplies
Xerox WC 7655 host to host usb failure. comunnication error 7655
Try changin the usb connector of the cable that goes from the screen to the rear left of the machine. There are 4 connectors there.
Oct 01, 2014 | Xerox WorkCentre 7665 Copier
How to fix xerox docucentre 2056 error 010-327
That error signifies a defective fuser, not coming to temperature. Replace fuser, part number 126K24980. See link below:
http://www.iteminconline.com/126k24980_126k24980-126k24981-126k24982-126k24983-126k24984-xerox-workcentre-5225-5230-fuser-110v-new.htm
Jun 10, 2014 | Xerox WorkCentre 52255230 Copier
Workcentre 7242, it was showing 01-333 fault at first but after correction another error 010-319 how can i sort out this error code
Error 010-333 for this machine is "Fuser Center Thermistor Overtemp (Over temperature) or Overheat Error"
Error 010-319 for this machine doesn't seem to exist (Yes - I know you've got it - hence the problem post.)
Error 010-319 for other Workstation models (7655, 7665, 7675, 7755, 7765, 7775) is "Fuser Heat Control problem *NOTE: This code must be cleared from Diagnostic Mode"
As regards fixing this error the Xerox website should be helpful
Feb 16, 2014 | Xerox Office Equipment & Supplies
Xerox 7655 can it borderless print
No it's fisically not possible. There will always be an edge.
Try to print on a bigger piece of paper and cut it.
Apr 04, 2013 | Xerox WorkCentre 7665 Copier
Xerox workcentre pro 55 pcl xl error
We have a WorkCentre 7655 that has been working fine for ages but is now causing some issues. A user who is running Windows 7 32 bit edition is sending files to print (using the secure print function) - the system is reporting they have spooled fine to the printer - but when they go and release the document they are getting (more often than not) about 16 out of 21 pages (for example) and then a PCL XL Error (Subsystem: Text, InternalError 0x50, Operator: Text, Position: 8564). I have another document that 9 times out of ten will actually crash the WorkCentre completely and cause it to reboot mid way through printing.
The driver we are using is the latest: "Xerox WorkCentre 7655 rev 2.0 PCL6"
As mentioned the user is running Windows 7 - the printer is shared from a Windows 2003 Server which has the same version of the driver.
Jan 06, 2012 | Xerox WorkCentre Pro 575 - 550 Copier
Xerox Workcentre M201 says open heat error
Fuser Error, Open Heat
Error, Heating Error and
Overheat
There is a problem in the
fuser unit.
Unplug the power cord and plug it back in. If the
problem still persists, please call for service.
Dec 09, 2008 | Xerox WorkCentre M20i All-In-One Laser...
141 people viewed this question
jasbo
jasbo
