Kennmore Top load washer Model 110 20432990
The washer is filling and agitating fine but shuts down when it reaches drain/rinse/spin. Where should I start? Thanks for the help.
  • 1 more comment
  • gove66 Sep 30, 2007
    Great Call Thank you!! Replaced Lid Switch problem solved. Model 11020432990 not easy to get to the switch...
  • Anonymous Nov 20, 2007
    the washer is filling and agitating fine but shuts down when it reaches drain/rinse/spin. Where should I start?
  • esp55 Nov 20, 2007
  • 447 Answers
Lid switch is broken
Posted on Sep 28, 2007
Wedge a penny coin between swtch and lid-lip — mine now works fine with this method.
good luck.
Posted on Aug 06, 2008
SOURCE:
Model 23832100
Sounds like clutch not catching,this may need to bed in .The fact it works okay with no load and no spin with load sounds like clutch/ but also could be motor torque.Ask repair man to recheck work done.
Jan 14, 2014 | Kenmore 24032\24036 Top Load Washer
Serial # SD117482G
Most likely the control or timer. What is model #?
Nov 17, 2017 | GE WBSE3120B Top Load Washer
Kennmore model 110.98575120
Sears paid repair service
1-800-827-6655
Feb 14, 2018 | Kenmore 88732 Top Load Stacked Washer /...
Kenmore Model 22722 will not drain
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 01, 2010 | Washing Machines
Top load washer won't go through cycle
modle problem here its the main board common fault with this model good luck
Mar 26, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
I have a Kenmore top loading washer model #110 and won't agitate
First, see the Sears parts site for your washer.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.23912100
Also see the Whirlpool (Kenmore) Service Manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
The first thing I'd try is using a different cycle. If the washer works as it should, the problem points to the timer.
I'd also check to make sure that when replacing the switch, the connections to the timer haven't come loose.
Since you've replaced the Lid Switch, the motor has power for the drain and spin cycles.
These washers use a reversing motor. The motor turns one way for agitating and reverses for the drain and spin.
Since you cannot hear anything when it is supposed to be agitating, the problem does point to the timer or motor.
Nov 14, 2009 | Kenmore 22422 Top Load Washer
Will not spin on any rinse cycle
Hi, This washer does not have a belt. While the washer is agitating, if you lift the lid will it stop? Some models will agitate but not spin if the lid is up. It sounds to me like the lid switch might be going bad.
If you will get me a model #, I can look this up for you and give you a better idea.
Vic
Jul 05, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
KitchenAid washer Model#KAWS700jqsr fills but won't agitate
if it's making a loud buzzing noise while its suppose to be agitating or spinning its the motor coupling
Dec 20, 2008 | KitchenAid KAWS700L Top Load Washer
Won't drain, rinse, or spin
That will be a lid switch problem
Nov 01, 2008 | Kenmore 22622 Top Load Washer
Washing Machines Logo
648 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
