Question about Northstar Generator 10 Hp, 6500 Watt, Diesel
I own a All power American diesel plant model APG3202 6,500 watts and need the wiring diagram. Will pay for is requested. This is a brand new plant located in Puerto Rico. Suddenly the sellenoid switch start falling and turn the plant off.. This plantis located in a school. and have no more than 8 hours of use.
Need a wiring diagram for a 1982 generator model number 4BPH SE/F4 4000 WATTS
need more info---a name brand of generator with engine type and double check the model number---could not research any info as something missing somehow----I'm not trying to get smart but nothing seems to cross??
Jun 11, 2017 | Watts Electrical Supplies
Need wiring diagram,from alternator to plug-ins for briggs & Stratton (3500) Elite series Model # 030208-0
No wiring diagram available from Briggs. Try re-magnetizing the rotor. No AVR or Capacitor listed in the parts list.
Disconnect the wires to brushes ( pay attention to the order) and apply 12vdc to brushes. Positive goes to brush closest to the bearing. Start the generator and check for output. If output is normal run the unit a few minutes to ensure re-magnetization then shut down normally. After shut down disconnect the 12 vdc source and re-install the previous disconnected wires. Now re start the generator and test for output should be okay provide there is no problems with the alternator. If no output during the above re-magnetization then your rotor windings my burned out.
Oct 10, 2014 | Briggs & Stratton Gas Powered 3500-4375...
Need a wiring diagram for rheem electric water 50 gallon 2007 model
1) Copy following links for standard wiring that applies to all brands electric water heater: wire colors vary, and do not matter.
You probably have ordinary residential non-simultaneous water heater.
http://waterheatertimer.org/How-to-wire-water-heater-thermostats.html
http://waterheatertimer.org/images/WH-w-combined2-1000.jpg
2) Look at tank label.
Typical label will show number of elements (upper and lower)
And give wattage for each element.
http://waterheatertimer.org/Figure-Volts-Amps-Watts-for-water-heater.html#label
http://waterheatertimer.org/images/Whirlpool-energy-smart-watt-rating-IMG_2600.jpg
Notice also total connected watts.
If total connected watts is same as individual upper or lower element watts, then you have ordinary residential non-simultaneous tank.
Mar 07, 2013 | Water Heaters
I need the diagram american heat adk-3 6.4
You want wiring diagram? With recommended wire size?
This particular water heater is direct-wired into a wall box, and appears to be 240Volt 6500 watts. Connect water heater to 40 amp breaker and 8 gauge wire.
Look at nameplate on device for amp and wattage rating to confirm exact power requirement.
http://waterheatertimer.org/How-to-wire-Tankless-electric-water-heater.html
Or a general part illustration?
http://waterheatertimer.org/images/American-ADK-3-parts.jpg
Contact American Heat. 888-818-4328
Their support button and link to product manuals and literature seems rather null date 10-14-12 which could indicate a company in transition.
There is email form
http://americanheatus.com/index.php/contacts/
American Heat is NOT same company as American water heater company.
Oct 14, 2012 | American Heat ADK-3 - Electric 6.4KW...
I need the diagram
This particular water heater has a factory-pigtail, and is direct-wired into octogon box, and appears to be 240Volt 6500 watts. Connect water heater to 40 amp breaker and 8 gauge wire.
Here is illustration:
http://waterheatertimer.org/images/Main-subpanel-Tankless-4a-8.jpg
Model MES5770AAB Serial 11517659WK The single element, 700 watts came with a wiring kit for a new connections. My range has "Old connection type 1" . the moddification kit (A-30001, Revision 4) shows...
Ten to one the elements will have to be changed also. Call or email Maytag about your dilema. You can simply reject to pay me also on this one
Jan 21, 2010 | Maytag Kitchen Ranges
Circuit diagram
I'm afraid I cannot comply with your wishes, as there are copyright laws governing this, for one. (For existing circuitry)
Two, there is the liability issue. Take for example that I design the requested circuit, give it to you freely, and you or someone in your group is injured using my circuit.
Will state that this is a basic circuit design. I believe that if you 5 put your minds together, you can build this circuit.
Sep 14, 2009 | Powerline 200Watt DC to AC inverter...
Need a wiring diagram for both these pickup(not audio)
what part of wiring diagram ? and i might be able to email it to ya
May 07, 2009 | Dodge Pickup Cars & Trucks
Wiring diagram Problem - Maytag MMV5207A 1100 Watts Microwave Oven
This doesn't have the diagram hidden away somewhere inside? Check at the bottom edge of the control panel, transformer brack, or rear of the oven. Otherwise, you can find wiring diagrams of earlier models that may be close enough. Just enter your model number here: http://tinyurl.com/gv383
Sep 04, 2007 | Maytag MMV5207A Microwave Oven
Northstar Generator 10 Hp, 6500 Watt, Diesel Logo
26 people viewed this question
Top Northstar Electrical Supplies Experts
John Trevino
Jim London
Jim London
Are you a Northstar Electrical Supply Expert? Answer questions, earn points and help others
