Question about Flotec Pentek Pentair Fp217-812 Water Submersible Motor Control Box
How to test capacitor in pentek pentair water pump submersible motor control box? The part number is SMC-IR1021-01 1 hp 23V, 001jO9X
Well water pump won't stop running
if it is a submersible well pump it could be crack in your line leading to the bottom of your commercial welcome and called it to leak water and still feel pressured
if it is a submersible well pump it could have a crack in the line leading to the summer double well pump in the ground it will cause it to leak but the tank will still be build up pressure
Jan 10, 2015 | Pentair Water 123324 1hp Submersible Well...
Well a 1/2 hp control box work on a 3/4 hp well motor
That rating is deceptive. Horsepower equates to amps and they are two different ratings. You should not use a 1/2 HP for a 3/4 rated motor.
Dec 24, 2014 | Flotec FP217810 Submersible Well Pump...
What causes a fuse to blow
I would suspect either you have a short somewhere or your circuit breaker may need replacing. Talk to a well company for possibilities.
Jun 28, 2014 | Pentair Water 123324 1hp Submersible Well...
Wiring diagram for ff32atc control box
If your hot tub has been submersed by water then you are going to need all new controls for it.
NEW control box with a new topside, New motor and whatever else is electrical under the skirt of the tub.
Start your search by getting the brand name and model number off each item.
Rod
US Parts Center
888-521-6183
Mar 19, 2013 | Pool & Spa
The pump is making a noise, but it is not turning. It will kick off after about 5 seconds
THE PUMP PICTURED IS A PENTAIR THE LITTLE CAP ON THE TOP OF THE MOTOR IS THE RUN CAPACITOR, TAKE IT OFF AND HAVE IT TESTED. BE CAREFUL THESE CAN HOLD VOLTAGE AND GIVE A NASTY SHOCK !SEARCH YOUR AREA FOR YOUR LOCAL POOL PUMP MOTOR REPAIR GUY WITH FREE TESTING..JAY
May 31, 2011 | Pentair Whisperflo 15 HP Pool Pump WFE6...
What goes out on the control box my pump wont start
check your pressure switch to see if the points are closed if there open its not asking for water the box wont go bad very easy starting capacitor would be the part.
Jan 12, 2011 | Flotec FP217810 Submersible Well Pump...
Pump switching off for about 10 -20 seconds, then back on. Hapens about every hour
the little house on top of the motor has a capacitor in it 90% of the time thats whats wrong with this motor it's eather a 30 or a 35 mf .
pull this off the motor and search your area for pool pump motor repair, free testing ,use your zip code in the search, ask if they can test a capasitor for you.. wait to take capacitor off till the motor cools off
about a $20.00 fix
hey if'n i was of help vote..thanks ..jay
Aug 08, 2010 | Pentair Whisperflo 1 12 Hp Pool Pump Wf26...
Whisper Flo model WFE 6 (1 1/2 HP) appears not to turn thus not pumping water through system; only clicks on/off when pressing fitler motor button on panel. Other spa equipment consists of: Pentair...
Possible bad motor. You would need to test voltage at the motor connections with a multi meter. If the voltage is correct, then the motor or start capacitor is bad. If the proper voltage is not correct, then you would need to look upline in the electrical system to find the problem
Oct 25, 2009 | Pool & Spa
Flotec Pentek Pentair Fp217-812 Water Submersible Motor Control Box Logo
425 people viewed this question
Top Flotec Plumbing Experts
Boyet Soriano
Boyet Soriano
john h
Are you a Flotec Plumbing Expert? Answer questions, earn points and help others
