Question about DeVilbiss Garden
I have a devilbiss wg 1420 the inlet elbow for it is obsolete is it possible to find it anywhere?
2 Suggested Answers
  • 5245 Answers
SOURCE: Intermatic WG 1420 replacement motor
Which timer is this for?
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#T100
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Posted on Mar 01, 2013
We are installing our new Samsung dishwasher and there is a slow leak where the elbow and inlet valve connect. We have tried a couple of times, used teflon tape and still a very slow drip. What to do?
Home Depot and other stores have dishwasher installation kits. Don't go to a hardware store this time, go to a store that sells dishwashers-- and other appliance installation kits. There should be braided hoses and all sorts of fun connectors and gadgets to get you going safely. You may need a new inlet elbow for the inlet valve if you have a bad seal because you're replacing an old dishwasher. Speak with a store representative and explain your situation and ask for guidance on install kits.
Jan 31, 2015 | Samsung Dishwashers
Water freezing in ice maker inlet tube
yes exactly,
follow your tube down to the water vavle you probaly have a small leak in the solonoid and it is dripping up
hard to beleive but it is
you can also turn down your freezer just a bit
but you will find the replacement water valve at the
www.appliancepartspros.com
just type in your model number
Nov 04, 2009 | Refrigerators
Water spraying out of the front vent of unit.
Dear zenith 10deg,
The outlet elbow attached to the head inside must have cracked. Leakage from selas do not that much spraying. Spraying are almost always caused by the cracking of the outlet elbow or the cracking of the head itself. The inlet elbow also makes a lot of spraying wheb broken, especialy if inlet water pressure is high. To see exactly from where the spraying is coming out, one must for sure remove the cover. Removing the cover must be done, because just the same one has to fix the problem.
Regards,
fulltech.
Apr 08, 2009 | Karcher Garden
REPLACEMENT BLADE NEEDED FOR MORPHY RICHARDS 48504
My food processor has broken, so have lots of spares for 48504 - inc 2x blades. I can post to you?
Feb 21, 2009 | Food Processors
WATER LINE 90 DEGREE ELBOW LEAKING FRONT LEFT
Did you actually break the elbow? you may be able to cut the tubing back and get a new surface for the elbow to push back into. if not a 5/16" push in connector is what you need you may be able to find this at a water condition store such as culligan.
Feb 03, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool dishwasher leaks everywhere
CHECK YOUR HOSES FOR CRACKS. BE SURE THEY ARE ATTACHED SECURELY TO THE PUMP OULET.
THERE IS ALSO A BLACK HOSE FROM THE VALVE THAT GOES UP THE LEFT SIDE TO A VACUUM BREAK ON THE SIDE OF THE TUB. BE SURE THE HOSE HASN'T BEEN DAMAGED OR DISCONNECTED. IF THERE IS SUFFICIENT SUPPLY HOSE, PULL THE DISHWASHER OUT OF IT'S INSTALLATION AND TURN IT ON. WATCH FOR WATER DRIPPING ON THE FLOOR AND TRACE IT BACK TO FIND THE PROBLEM.
Mar 25, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Connecting the hot water line to a new dishwasher.
use teflon tape on the elbow if you did the back it off put some more on it and stop when its snugged facing the right direction now ive torqued them things pretty tight my self they don't strip that easy
Feb 16, 2008 | Dishwashers
your tub seal needs to be replaced. you might have damaged it when you moved it
Jan 25, 2007 | Whirlpool 24 in. DU1055XTP Built-in...
Garden Logo
Top DeVilbiss Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a DeVilbiss Garden Expert? Answer questions, earn points and help others
