Question about Whirlpool LTE5243DQ Combination Washer/Electric Dryer
Dryer drum makes noise thin twin, gas dryer
    New Friend:
  • 50 Answers
Bearing worn-out - replace it
Posted on Oct 22, 2013
4 Suggested Answers
Illeagle
  • 525 Answers
SOURCE: noisy drum
You may have a rear drum support issue. There are 2 rollers,(supports), 1 at 4 o'clock and 1 at 7 o'clock. If the bushing in the roller becomes elongated,(elliptical), it will give a thumping noise, as you describe.
Below is a link with exploded diagrams and parts help.
http://www.repairclinic.com/0100_14.asp
Please rate my answer on how helpful it was in resolving your issue.
Thank you,
Dave E. (Illeagle)
Posted on Jun 16, 2008
jonniewalker
  • 1031 Answers
SOURCE: whirlpool dryer drum making noise
window.google_render_ad();There are many places & parts that could be causing your Whirlpool dryer to be noisy. To find out what is causing the noises, you need to find out where are the noises coming from.
Start the dryer and let it run for a while and listen to try to pinpoint where in the dryer the noises is coming from. Once you have an idea of the area, you will need to disconnect the dryer from the wall outlet and take the dryer apart.
Below you will find the parts that you need to check when your dryer is noisy.
The drum baffles:
The drum baffles are use to tumble the clothes inside of the drum, in other words, the baffles job is to separate the pieces of laundry as the drum turns.
When the dryer is getting older and if you use the dryer a lot, the drum baffles holding screws will become loose. Loose drum baffles will cause noises. All you need to do, is to open the top panel and tighten the drum baffles holding screws.
The drum support rollers:
These dryers uses four drum support rollers, tow on the front and two on the rear. The job of the drum support rollers is to keep the drum tumbling smooth.
When the grease on one of the rollers dry out, the roller start to make squeaking noises and the roller bearing will start to wear out until the bearing on the roller is gone. When the bearing on the roller is gone, the noise will change from squeaking to a clanking noise.
The blower wheel:
The blower wheel is use to circulate the air inside of the dryer drum. The most common Whirlpool blower noises are cause by something falling inside of the blower housing and hitting the blower when the motor runs.
The Idler pulley:
The Idler pulley is use to apply the necessary tension on the belt. There are two types of idler pulleys, the pulley with the wheel and the pulley with the teflon slide. A bad idler pulley could cause a Whirlpool dryer to be noisy.
The drive motor:
Worn out bearings on the motor will cause the motor to run kind of noisy. When the motor starts making noises, the solution to this problem is to replace the motor.
The belt:
The belt on most dryers is only about1/4 inch wide. These belts work very hard making the drum tumble. When the belt stretch just 1/2 inch more that it supposed to, the belt will start slipping and that could cause your Whirlpool dryer to be noisy.
As you could see, there are a lot of parts that could become noisy in your dryer. When your dryer starts making noises, make sure to check it out before it gets worse.
Posted on Feb 09, 2009
machinetech7
  • 1344 Answers
SOURCE: After replacing the heating element in lte5243dq the thin twin dryer it still doesn't work
http://www.partselect.com/ModelFrames.aspx?ModelID=706288&ModelNum=LTE5243DQ0&mfgModelNum=&ManufactureID=3&Selected=AJ4UQMWK&Position=4&mfg=Whirlpool&Type=&Mark=3
Did you check the thermostat and the high limit thermostat. If not check them for continuity with a volt meter to confirm if they are good or not. Continuity good, no continuity bad. I posted the diagram above so you can locate the pieces in the machine.
Posted on Jun 21, 2012
Whirlpool Twin Thin Washer makes very loud noise on drain/spin.
Sounds like the bearing on the drum has gone , open the door and see if you have any play on the drum by moving it side to side and up and down good luck
Dec 13, 2017 | Whirlpool Washing Machines
Washer spin loud noise
Front load machine......
a) When not on cycle.... Unplug the machine from power. Open the door and give a spin to the drum from your hand.
a1) Does it make a cluck cluck noise.... Your drum bearing or inner drum bracket is gone.... Very expensive repair. Need to buy a new machine unless you have warranty left at least for the part.....
Apr 24, 2015 | Whirlpool Thin Twin Washer and Electric...
GE 5 Cycle Automatic Heavy Duty Extra Large loud noise
All ge dryers have a center bearing on the back side of the drum and drum glides on the frontside. The glides make a scrubbing sound when bad and the drum is hard to turn. The rear bearing does a squeak thang when the plastic bearing wears thin and begins to make metal to metal contact between drum mount and rear bulkhead mount. It is an easy fix but the drum gotta come out. here is my pictorial page that shows how with videos and repair pix:
Paw Paws GE dryer repair page
http://appliancejunk.blogspot.com/2011/09/late-model-hotpoint-dryer.html
http://appliancejunk.blogspot.com/2011/08/hotpoint-dryer-eating-clothes.html
Jan 09, 2013 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Drum inside washing machine seems to come loose..making a really loud banging noise. Whats the best way to fix this.. Whirlpool Thin Twin
Might be a spring or the skate plate out of alignment.
Thin twin service manual is in this apartment series service manual:
http://docs.google.com/fileview?id=0B5If-wTgYWH5ZDgzODI5MjYtMWNmYS00MWZkLTk0ODEtNjM3MTIyYzVmZWVl&hl=en
Sep 18, 2011 | Whirlpool LTE5243D Top Load Stacked...
What is the process for replacing the drum bearings for my thin twin LT5000XSN2. Need step by step. Sounds like is about to fall apart. I am very good at fixing most things.
The problem is usually not the bearings at all but the felt guides on the front of the drum. The felt wears off and then makes lots of noise. You can access this part by removing the front along with the door. Listen close with the button in and door open to see if the noise is coming from the front or rear.
Aug 19, 2010 | Whirlpool LTE6234D Top Load Stacked...
There is a squealing noise when the dryer runs. The belt seems to work fine, but there is a whistling/squealing noise when the dryer is on
The drum rides on a pair of plastic glides in the front. They get thin and their bracket begins to rub the drum.
The rollers tend to get a little noisy in time. I use HVAC oil (zoom-oil from ace hardware) to lube them because it is temp resistant, won't disapate, and is non flammable.
May 01, 2010 | Amana ALG331RAW Gas Dryer
LG gas dryer DLG0452W drum makes a clicking noise
one of the dry drum baffle screw might be lose are there might be something caught inbetween the dry drum front seal are rear
Apr 24, 2010 | LG DLG0452W Gas Dryer
High pitched squeal when running. Capacity Plus Gas Dryer ten years old.
tumble dryer / twin tub is making a loud rumbling noise when running, unplug it, take the rear cover off and remove the drive belt. Then turn the inner drum by hand. If there is a grating noise, the bearings will almost certainly need replacing
Mar 09, 2010 | Dryers
Whirpool Thin twin with noisy dryer?
You could have a wore out dryer belt wich could cause the drum to feel lose, Also you could try checking the glides underneath the front of the drum to make sure they did'nt slip out of position. This helps the drum turn with little or no friction.
Mar 11, 2009 | Whirlpool LTE5243D Top Load Stacked...
Whirlpool Thin Twin Model LT7000XUNO stack unit
ithink I have the lt7000xuno
something got jamed in it now the drum won't turn mabe spun abelt or is there a cut off switch?
Aug 05, 2008 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool LTE5243DQ Combination Washer/Electric Dryer Logo
172 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
