Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Programming an old sears 139.538xx keypad for sears door opener 139.654001
glenmann62
  • 91 Answers
SOURCE: Resetting a keypad for a garage door opener.
simple , i was a sears installer for 10 years installing garage door openers so your in luck , just locate the smart button on the machine ,it would be on the back or if your looking from the back at the back ,it could also be on the right side depending on if the machine is a sideways mounted machine or frontmount, after locating this button which maybe green/orange /or purple in color also depending on your model ,the newest sears machines are purple buttons ,and 5 years ago they were orange and the older ones would be green ,...ok so after you,ve located it just push it once and you will see a solid yellow indicator light come on , now go over to the keypad and put your 4 digit personal code in after that press the enter button AND HOLD IT for around 3 seconds , at that time you will see the lightbulbs on the machine go off and then click back on , and THAT,S IT! plain and simple , now go proramm your remote! hope i was of help to you , and if i was leave me a nice rating Sincerely Glenn mayer
Posted on Mar 07, 2009
  • 118 Answers
SOURCE: Model 13553965- programming wireless keypad
You have to buy a liftmaster or craftsman keypad
Posted on Jan 29, 2009
Doorguy27
  • 30 Answers
SOURCE: Keypad outside not working Properly
Have you replaced the battery in your keypad? That should take care of the trick.
Posted on Feb 10, 2009
SOURCE: Sears garage door keypad/remote programming problem
Hi All,
I had the same issue recently and here's what I found out (through a LOT of research) and the solution (yes, there is one!):
As described by many, when you can't get both the remote and the wireless pad to work together it means your garage door opener can accept both rolling code and billing code technology, BUT not at the same time. When you reset all codes (normally by pressing a button on the opener for a period of time e.g. 6 seconds or more), you erase all codes and remote "pairings". Then when you follow the manufacturer's procedure to pair again (which could be the wireless key pad first OR the remote first), the first pairing determines the technology for all subsequent pairings. Example: if your first pairing/programming was with the wireless keypad, and if it was rolling code technology (normally the case for newer models), then the garage opener will only recognize and accept rolling code for subsequent pairings. If your remote(s) are older (billion code technology) then the opener won't even recognize the signal (e.g. led won't blink when trying to pair/program).
And vice versa if you start with your remote after erasing all programming (then your keyless pad won't work).
But here is a potential workaround! For newer wireless keypads (e.g. clicker from chamberlain), you have an option to select the type of opener you are using as you do the initial password set up (normally indicated by a number e.g. 1 for models built after 1995, 2 for models built between 1997 and 2004, etc). Each choice is associated with a technology in the background (e.g. either rolling code or billion code). If you are programming your wireless keypad first after erasing all codes / programming, if you chose the "recommended" option for garage opener, chances are it will be rolling code and that means you won't be able to program your older remotes (billion code) after that. So how can you chose the option that will match your remote???
Here's what you do: start by pairing / programming your older remote first after erasing all codes / programs. That sets the technology (e.g. billion code). Then, go ahead and program your wireless keypad, but you may have to go through the process several times by trying the different options until you find one that works!
For me, I had to try 4 options before making it work. Options 1 through 3 (mind you, options #2 was the exact match for my garage door opener model but it would cause the problem discussed here e.g. wireless keypad would work but not the remotes) would not even be recognized by the opener in this procedure (LED would not blink), but it did work once I hit option 4.
I hope this will help you with your problem. Let me know if it's not clear. Cheers!
Posted on Apr 15, 2009
  • 3197 Answers
The button you added in your car is an earlier technology that is not compatible with the rolling code technology.
Posted on Jun 01, 2009
I am trying to enter a new code on my outside garage door opener keypad, however, it does not have an enter button, what do I do after I already erased the old code. thanks
If your keypad is hardwired do this:
To program the keypad, first unplug the garage door opener from the electrical outlet. Next, remove the nameplate from the console that the keypad plugs into and locate the program/operate switch. Flip the switch to program. Next, enter your desired four-digit PIN number into the keypad. Slide the switch back to operate and plug the garage door opener back in. The keypad should be programmed.
Aug 31, 2011 | Sears Craftsman LiftMaster Chamberlain...
Wireless keypad 139.18795 does not work with sears garage door opener 53993d. What's the key to program it?.
Can't find 139.18795 anywhere but if you are trying to program an old keypad with a new opener it will not work. The radio frequency was changed in 2005.
Aug 19, 2011 | Sears Craftsman LiftMaster Chamberlain...
Entered 4 digit passcode and doesn't have a enter button. What do I do?
Sounds like you have an old hard wired keypad. Make sure all the wires are connected. You can try programming it.
Dec 12, 2010 | Sears Craftsman LiftMaster Chamberlain...
Chamberland keypad opener Model 976LM will not program . Craftsman opener has a purple or lavendar training button . Yellow one at old house worked fine.
If I understand what you are saying it is that you are trying to program a keypad from your old house to an opener at your new house. There are several models and you must have the correct one.
Nov 15, 2010 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman key pad is about 20 years old. Need to re-program code. I know you hit a few numbers then the 4 digit code but I can't remember the #'s.
If it is a wireless keypad do this:
Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to the keypad and key in any 4 digit code you like and press enter.
If it is hardwired do this:
Oct 28, 2010 | Sears Craftsman LiftMaster Chamberlain...
We have a sears 1/2 hp garage door opener model 139.53674SRT2, manufactured in 9/98. Today the keypad stopped working. I replaced the 9V battery. Not sure if the keypad just died or if there is something...
Odds are it just died but you can try programming it just to make sure.
Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to the keypad and key in your 4 digit code and press enter. If this doesn't work it is dead. You can get a replacement keypad at Sears. Be sure to take the model number of the old keypad with you. It should be on the back of the old one. If not, take the model number of your opener. There are several models of keypads and all of them wont work with your opener.
Sep 21, 2010 | Sears Craftsman LiftMaster Chamberlain...
Nnew Sears garage door opener - old keypad
Yes,buy the new keypad in the safe side.Probally have new Inferred signal codes by the new remote might work with the old keypad.
Mar 16, 2010 | Sears Craftsman LiftMaster Chamberlain...
Programing garage door opener
Hold the button on the remote and press and immediately release the smart/learn button. Do this for each of your remotes.
For the keypad press and immediately release the smart/learn button. Walk over to your keypad and key in your 4 digit code and press enter.
If these instructions don't work you have a bad logic board.
Dec 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
OLD garage door opener
Sounds like you have the keypad that is hardwired.
To program the keypad, first unplug the garage door opener from the electrical outlet. Next, remove the nameplate from the console that the keypad plugs into and locate the program/operate switch. Flip the switch to program. Next, enter your desired four-digit PIN into the keypad. Slide the switch back to operate and plug the garage door opener back in. The keypad should be programmed.
These instructions may not work if the keypad is some other manufacturers.
Aug 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
Keyless entry pad for garage door opener
THE FREQUENCY OF THE UNITS ARE PROBABLY NOT COMPATABLE THEY CHANGED ABOUT 2 YEARS AGO.
SORRY - I THINK YOU NEED A NEW KEYPAD TO GO WITH THE NEW OPENER.
Oct 22, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
182 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
