Question about Kyocera Torque Sprint
After 3 days of perfect operation, my Torque will not play music through my 2010 Toyota Tundra radio. I have reset my phone to factory default settings and reinstalled my apps. Also, I have unpaired and re-paired the two several times. I had the same problem with my previous Torque phone, but I could get it to work intermittently after unpairing and re-pairing it. No luck with one. I have paired other devices to my truck radio and have no problems with them.
I have a 2010 Toyota Tundra. How do I reset the low washer fluid warning light?
With a Hammer. No, seriously, it should reset just by it gauging the fluid level. If it doesn't, then it is probably just stuck, and needs a little help. Hitting on the tank with something like a rubber mallet should do the trick.
Apr 13, 2015 | 2010 Toyota Tundra CrewMax
How do I reset a Toyota 2012 tundra Bluetooth back to factory settings?
ask toy? how to magic works? does the operator guide answer that.
that be like first.
or google for days?
Feb 08, 2015 | 2012 Toyota Tundra Tundra Crew Cab Pickup...
Is there a recall on 2010 tundra
Go in on the net and put in recalls for 2010 Toyota Tundra it will be detail..good luck
Oct 22, 2014 | 2010 Toyota Tundra
After 3 days of perfect Bluetooth operation, my Kyocera Torque will no longer play Pandora through my 2010 Toyota Tundra stereo system. I have unpaired and repaired the two several times, and have reset my...
I would first trying pairing to your tundra with another device. If that works then you know the issue is on the phone side. Next you can try sending a photo to a brother or sister via Bluetooth and see if that works on your phone. Other than that It sounds like you have covered the basics.
Oct 22, 2013 | Generic Kyocera Rise C5155 Rubberized Snap...
How can I play music from my desktop backup disk (My Passport 1GB) via USV in 2012 Toyota Tundra
You need to format the hard drive to FAT32 and then copy your 80Gb of music files to this hard drive.
Mar 27, 2013 | Western Digital 1TB My Passport Essential...
Sir I have nokia 5130 express music.... when i play songs or video in gallery, it gives white screen n shows operation failed.... i m able to play the songs by entering into the application but cant...
Please have your SD card checked , put the card for a scan in your PC and confirm that all the files present are readable by the phone. If not remove , format and reinstall all the files for valid media files accepted on the media player.
Also have your phone reset to factory default- open settings- factory settings type- 12345.
Jan 05, 2011 | Nokia 5130 Cellular Phone
2003 Ford Focus Blaupunkt Cd Player issue!!!!
I hav an 03 and it exhibited the same problems; on off on off nothing works. I discovered this repair 2 days ago and it works perfectly and I am one happy camper.
1. Start by pulling the main fuse for the radio (if you already haven't)
2. Re insert the fuse and turn the radio on (nevermind the on off sequence). Insert a music CD, it will take one.
3. Pull the fuse again, count to five and re insert fuse.
4. When the CD starts to play, use the menus to get down to the factory default settings and ask it to reset to factory.
5. And you are now working again. Or you should be. It basically is a processor and it operates just like your home PC whn it needs a reload. It searchs to the default drive which is the CD player.
Good Luck everyone!
Feb 07, 2008 | Car Audio & Video
Toyota dashboard CD player won't eject
I had this say problem with my 2000 solara. Here is the fix, remove one of the car battery terminals for a couple of mins (3-4mins). The reattach the battery terminal back. This would make your cd player and car clock reset. once you start your car you should be able to eject the cds. You'll just need to reprogram all your preset radio station. Hope it helps
Oct 04, 2007 | 2003 Toyota Celica
Kyocera Torque Sprint Logo
44 people viewed this question
Top Kyocera Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Kyocera Cell Phone Expert? Answer questions, earn points and help others
