I recently purchased a 5 speaker wireless Soundon WHT 510 home theater system. It has no manual and each speaker has a power cord to plug into the wall. Now how do i program them to work with my Sony Vizio flatscreen TV??? I also have a Pioneer am fm reciever. What settings to i use to get these speakers to work on the tv and reciever??? If u could help i would b very grateful
SOURCE: Curtis 5.1 Home Theater System
can it hook up to the cable and have the sound can out the speaker when wacth tv . so one can here it with not be so loud for the for any oneself,in the roon with then .
Posted on Jan 14, 2007
SOURCE: ilo tv
i dont think that the ilo has a sound output port:(
Posted on Oct 22, 2007
  • 3 Answers
SOURCE: home theater system connections
Hi
I have the same tv but my dvd surround is a toshiba, that shouldn't matter though. When I watch a dvd I go to component 2 which is where I have my dvd connected on the input of the tv when I watch tv and want the surround on I go to component 1 which is the tv input then on my dvd player I go to auxillary and I can watch tv in surround. I don't know the LG home theatre system but you should be able to select your inputs like between dvd, tuner, aux. Flip between them and you should get sound. hope this helps.
Posted on Jan 19, 2008
SOURCE: Can't get tv sound from home cinema system speakers
you need an optical cable going from the TV to the home cinema for an audio output, it worked for, had the same problem!!
Posted on Dec 26, 2008
  • 32 Answers
SOURCE: Soundon WHT 510 Wireless Speakers Not All Connected
try to swap the speaker that are hookt up with the ones that are not ,or thay are out of range from the recever
Posted on May 31, 2010
Red light is on in the back of my t300 tower speakers
That is the standby mode but if its not kicking out of standby mode it could be a fuse issue
The T300 uses a 2.5A fuse.
To replace the fuse:
1. Unplug the AC cord from the AC power source,
then remove the AC power cord from the speaker's
power connector.
2. Remove the fuse cap with a small, flat blade screwdriver
(see diagram 2).
3. Remove the fuse from the fuse cap
(see diagram 3).
4. Replace the fuse inside fuse cap with another metric
5X20mm size fuse
5. Replace the fuse inside the cap, replace the fuse
and cap in the power connector (see diagram 5).
6. Connect the AC power cord to the speaker and
raise it upright.
7. Connect the power cord to an AC power outlet
Jun 01, 2011 | Cambridge Soundworks ton Theater T300 Home...
Hi, I recently purchased a Samsung - 1000W 5.1-Ch. Blu-ray Home Theater System: Model: HT-C5500XAA and was wondering what I need to make the rear speakers "wireless?" I understand a module is...
HT-C5500XAA / HT-C7530W This system comes with wireless speakers... Maybe return this system and get the one with wireless included.... Retails for $999.95
www.samsung.com/us/video/home-theater/HT-C5500/XAA - Cached
Also try out this website....It is quite handy.... Cheers...Sincerely HDTV GURU JAY
Mar 17, 2011 | Televison & Video
I HAVE A JVC HOME THEATER SYSTEM MODEL NUMBER TH-C5 THAT THE RECEIVER POWERS UP BUT THE SUB WILL NOT AND THE SPEAKERS ARE NOT WORKING.
Page 42:
No sound. The system cord and/or speaker cord is not connected. Check the connection.
The audio cord is not connected to AUDIO IN (VCR)
and/or DIGITAL IN (DBS) correctly.
Connect the cord correctly. (A pg. 13)
An incorrect source has been selected. Select the correct source. (Apg. 17)
The decode mode is not set correctly. Select the proper decode mode. (A pg. 35)
http://www.retrevo.com/support/JVC-TH-C5J-Home-Theater-Systems-manual/id/318ag518/t/2/
Do you think the powered subwoofer itself might have a power problem? Check its cord.
Dec 26, 2010 | JVC THC5 Home Theater System with 5-Disc...
May 31, 2010 | Audio Players & Recorders
Recently purchased Sony 52 Bravia KDL52EX1
OK so its software problem? But how did you solve it?! Thansk!!
Jan 09, 2010 | Sony BRAVIA® DAV-HDX576WF Theater System...
How do i hook this up Samsung HT-WX70 Theater System with Wireless Speakers
1. Connect the front left, front right, center, and sub woofer speakers to the back of the home theater system.
2.
With the home theater system off, insert the TX card into the TX Card connection (WIRELESS) on the back of the home theater.
Important:
Make sure to insert the TX card with the slanted portion of the card facing left.
3. C
onnect the rear left and the rear right speakers to the back of the SWA-3000.
4.
Plug the power cord of the SWA-3000 into an electrical wall outlet, and then switch the power switch on the back of the SWA-3000 to [ON]
Hope this helps!
Jun 27, 2009 | Samsung HT-WX70 Theater System
We have a Panasonic DVD home Theater Sound System SC-HT80 and our daughter has somehow "locked" it. We cannot find the remote.....anybody know how we can fix it without remote?
Try cold start.
Power off main set manually by press power button on main set.
Unplug power cord from main set.
Wait for about 5 sec.
[Without plug in power cord] Press and hold "Power" button without release it.
Plug in power cord (must have power) to main set by using another hand [while another hand still press on main set power button]
Keep holding until u see ------ on main set FL display.
Then release you hand which just now pressed on main set.
Power on main set again by manual press power button on main set.
Result should be OK (unlocked)
Dec 27, 2008 | Panasonic Home Theater System System
48 people viewed this question
 Grubhead
Grubhead
