Question about Hardware & Accessories
Manual for Tungsten 7 day digital timer Model EM0101
2 Suggested Answers
SOURCE: I have a 7-day timer model em0101 and can't set it
There is a reset button to the left of the on/off button. It's recessed so you'll have to use a ball point pen or paper clip to reset the timer. The clock will flash 12:00 after it's reset. Press the clock button several times to select the day of the week. Then hold down on the clock button (third button on top right) and then twist the dial clockwise to set the hours, then counter-clockwise to set minutes. After the clock is set, press "timer" and do the same thing to set your on/off times. If you only use one timer, make sure the other 5 don't have anything in them.
Posted on Aug 02, 2012
How do I reset the timer on model no Y1N601; I have lost the instructions. I want to set for a week to come on and off at the same time each day.
I believe this is a manual for your device. It looks pretty simple to do what you want. In Timer mode press the Day button until you see MO-SU
http://www.thenccusa.com/pdf/pguide/28015.pdf
Dec 10, 2014 | Hardware & Accessories
That timer is not identified:
Copy following link to see variety of timers that might match your timer, and then download same-similar manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html
Jun 15, 2012 | Timex Hardware & Accessories
Indoor timer 0155671 it wont turn on or off after programing
Utilitec 0155671 7-day digital programmable timer is sold under different brand names and numbers
http://waterheatertimer.org/Woods-timers-and-manuals.html#59377
Read instructions on following link.
http://waterheatertimer.org/How-to-program-Utilitec-0155671.html
There are 7 general things to look for if digital timer is not working correctly.
1) 0155671 timer is considered incandescent light bulb timer (tungsten) and not necessarily made for motors loads, TVs, CFLs etc. Try using timer on table lamp with incandescent bulb. Turn lamp ON, and make sure bulb is good.
2) Outlet is wired wrong: test outlet with circuit analyzer, and try timer on another outlet, and with different load. For example if outlet polarity is reversed, or if load has interference.
3) Timer is programmed for ON times but not for OFF times.
4) Programming has conflicts, for example program1 ON is for 8am Mon but program1 OFF is for 11am all-days-of-week.
Or program1 and program2 ON-and-OFF times conflict.
5) Timer is not set in AUTO mode, and timer is in random or countdown mode.
6) Timer is defective: 6-8% of all timers arrive defective.
7) If timer is older, the internal battery may be fading. Battery is not replaceable. These timers have 1 year limited warranty.
Jul 11, 2011 | Hardware & Accessories
I have an intermatic 7 day all weather timer model HB71R.I have lost the owners manuel.Anywhere I can print one off as it has to be re-programed.
Intermatic does not show that manual.
Intermatic manuals:
http://www.intermatic.com/customer%20service/instruction%20manuals.aspx
They show HB77R raintight.
This model may be close enough to figure out button sequence.
I work with timers and most programming follows similar pattern.
Older timers usually follow same pattern as new timers, except with fewer options.
http://www.intermatic.com/products/timers/consumer%20outdoor%20timers/digital%20timers/hb77r.aspx
Nov 16, 2010 | Intermatic 7 Day Digital Timer Model...
Do you have a source for the programming instructions for a "7 Day Digital Timer" model EM0101 Thank you, Chris
I have a scanned copy of original Instructions for EM0101 7 day timer. But I don't know how to transfer it to this site w/o showing an email address. It's 2 full pages with display diagram.
Oct 19, 2010 | Kitchen Appliances - Others
So far, I bought 5 Woods 59377 Indor Digital 7-day timer and each of them stopped working. The timer is connected to the hologean 90 Watt lightbulbs. What's causing the timer to stop working?
Check following link to identify timer and download manual:
1) Manual shows 59377 timer is for Tungsten (incandescent)
http://waterheatertimer.org/pdf/Woods-59377.pdf
2) GE faq page shows halogen and incandescent together, so the timer may be rated for halogen. It is unclear.
http://www.gelighting.com/na/home_lighting/ask_us/faq_compact.htm
3) Buy cheap circuit analyzer at home center and check circuit. Whenever electronic timers fail, circuit is suspect. The light fixture may be causing interference. Try timer on different circuit. Try timer on different load.
4) Use mechanical timer instead of digital timer:
http://waterheatertimer.org/Woods-timers-and-manuals.html#59201
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jul 28, 2010 | Woods Industries 59377 Indoor Digital...
Hardware & Accessories Logo
61 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
