Question about Tappan Kitchen Ranges
Need replacement knob for oven temp ktm-2872-87d
4 Suggested Answers
buffalonyman
  • 1865 Answers
SOURCE: I thank i need to replace thermostat in tappan
Go to this link and select your model number. It will take you to a set of drawings and parts list
http://www.apwagner.com/index.php?main_page=part_finder&searchType=model_number&keyword=tgf320
Posted on May 14, 2009
SOURCE: I have a tappan self cleaning oven KMT-2893-87A
call Sears for they took over Montgomery Wards services and we have the same stove
Posted on Aug 21, 2010
SOURCE: I have a magic chef gas stove model #3167VUV and need to replace the oven knob as you cannot see the temp. numbers anymore where to get part in white
Try www.appliancepartspros.com if it is still available.
Posted on Nov 19, 2012
I need to adjust the thermostat on my Hamilton Beach toaster oven. Can you help me?
bench toaster oven
you dont adjust
if the temp knob isnt working
you get an electrician to o replace the knob or thermostat
or buy a new oven
Apr 10, 2017 | Hamilton Beach Toaster Ovens
Temp control knob loose on old Frigidaire oven
my best guess its A Frigidaire wall oven, circa 1966-1970,
unsafe to use at any time if the temp controller trips the circuit breaker
could be the oven thermostat causing the trip as well
if Frigidaire are still in business
You will need to ask an electrician to fit a /tested used controller or new superseded part temp controller and knob
Oct 11, 2016 | Frigidaire Ovens
I have a Jenn Air JJW9830DDP double oven electric, and the temperature in the oven is about 100' less than what it reads on the display. I tested the temp sensor and it ready 1073 ohms. Any s
Well, your temp sensors can still be bad. If not, there's always a new control board you buy!
However, I wouldn't drink water from that oasis without making ABSOLUTELY sure I'm not seeing a mirage.
The only common denominators between your upper and lower oven temp readings is the firmware and the oven thermometer you are using to visually check the temps.
What type of thermometer are you using to check your oven temperatures with?
If it's not a digital thermometer used specifically for testing ovens, you might just be leading leading yourself astray.
You need a calibrated thermometer. If I don't have a calibrated digital thermometer on me, I use two or three oven thermometers (the dial type) and average the readings.
It's the only way to be as close as possible with a digital probe.
If you have thoroughly verified that your oven is in fact not reading the correct temperature, then you can adjust it +/- 35 degrees F via your oven's control panel.
To adjust the oven temperature:
1 - Press Setup pad.
2 - Select the down arrow to scroll to the next screen.
3 - Select Temp Adjust using the Quickset pads.
4 - Select upper or lower oven (select models).
-"Set temperature offset using the Upper Set Knob" is displayed.
5 - Enter the desired temperature change using the Set knob.
The temperature can be increased or decreased up to 35 degrees.
The temp. change is displayed at the top of the window.
6 - Press the Set knob to accept the change.
Now, if you are still worried about the temp. reading being off, replace both the upper and lower temp sensors. That's all you can do besides replace the main board.
Oct 24, 2014 | Jenn-Air JJW9830D Electric Double Oven
Oven is off 100 degrees. How to calibrate it?
To Adjust the Thermostat
Pull the OVEN TEMP knob off the shaft. look at the back of the knob and note the current setting before making any adjustment. The knob is factory set wit the knob directly under the pointer.
1. Pull of the OVEN TEMP knob
2. Loosen both screws on back of the knob
3. Adjust lower screw so it moves in the desired direction. You will hear and feel the notches as you turn the knob. Each notch changes the temperature about 10 degrees F.
4. Tighten the screws.
5. Return the OVEN TEMP knob to the oven.
Re-check oven performance and make the necessary adjustments accordingly.
Feb 12, 2011 | GE Spacemaker JMS08 Electric Kitchen Range
How do you fix the temperature for the whirlpool oven
Buy a oven thermometer to put inside the oven to check the accuracy of your oven temp setting. If the oven temp is not too far off from what your oven thermometer is reading, you can recalibrate the oven knob. Pull the knob off and look at the back. You can adjust the degrees approx +or - 20 degrees. If the temp is all over the place or just not heating up enough, then it's time to replace the oven thermostat, assuming the oven isn't too old or not worth fixing.
Douglas
Oct 05, 2010 | Ovens
The oven will not keep correct temp. What do I need to replace?
replace the oven thermostat or take the temp knob off. look on the backside of the knob. you can adjust 50 degrees each way you need to know the exact oven temp to adjust this right
Aug 20, 2010 | GE Kitchen Ranges
Feb 03, 2010 | Tappan Kitchen Ranges
Self-cleaning feature of GE Built-In Oven does not work
Simply set the Clock and Delay Start to the current time, then set the Stop Time ahead 3 hours. For example, if it is currently 8:00 then set the Stop Time to 11:00. The lights on the console will come on and the cleaning cycle will begin. At some point during the cycle when the oven gets hot enough, the lock mechanism is "fixed" and will not release until the cycle is complete.
Jun 26, 2008 | Ovens
Kitchen Ranges Logo
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal De
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
