Question about Kenmore Dryers
I have a Kenmore HE3 electric dryer model #110.82822102. I keeps blowing thermal fuses. I have inspected and cleaned the exhaust duct from the back of the dryer to the outside exhaust vent, so that's not the problem. Could the thermostat be defective?
SOURCE: Hotpoint NVL333EY Electric dryer blows thermal fuse
I had the same thing happen, I replaced the thermal cutoff and made sure no lint build up. It lasted a week then blew again. I then replaced it again and got to thinking why it would blow. I then took apart the exaust inside the dryer running fron the drum to the motor and right before the motor was a build up of lint ane particals that was almost like compressed sawdust which was blocking half of the line. I cleaned this out and it seemed to work much better.
Posted on Jan 04, 2008
ronpar
  • 27 Answers
SOURCE: Whirlpool Duet Dryer - Working but no heat
it sounds like your heating element is gone bad. there is no heat if they burn out or get corroded
Posted on Jun 29, 2008
larryyb
  • 291 Answers
SOURCE: thermal fuse keeps blowing
they will blow if the heat dont get out of the dryer and builds up inside / check and see if vent hose behind dryer is kinked or vent going outside is open / it will be one of those two.
Posted on Nov 25, 2008
  • 132 Answers
Good Afternoon,
Unless there is something restricting the ventilation I think you are having a problem with the heating coil staying on too long. If that is the case, one or more heating sensors are bad. Let me know if this helps and thank you for using FixYa!
Posted on Mar 27, 2009
vickygomar
  • 460 Answers
SOURCE: blown thermal fuse on Kenmore dryer
I need the serial# to assist you better.
Thank you for trust fixya.com
Posted on May 14, 2009
I have a Kenmore dryer Model 1.10 60902990 that keeps tripping the thermal cut-off fuse (part #3398671 or substitution part #279769) after running for about 5 minutes. I have checked the high limit...
this will keep popping if the dryer is running to hot,if the cycling thermostat is bad the dryer can do this or something is blocking the air flow.if you have a long vent line most likely this is the problem,also you have to remove the metal duct that the lint filter slides down into and clean that out.if your vent line is long try running the dryer with the vent line removed from the back of the dryer,also when you remove the vent line stick a leaf blower into the vent line and blow it out to the outside,but like i say all a dryer does is move air and if the air doesn't move out of the dryer and it runs to hot the t-stat will blow as a safetygo here and check out the cycling thermostat http://www.repairclinic.com/PartDetail/Cycling-Thermostat/8318268/904589#repairHelpVideoTabs
and replace the 279769 and try running it with the vent line off the back of dryer,also when you take off the metal duct that the lint filter slides into spin the drum and make sure the blower wheel is spinning,if the blower wheel is bad and can't move air this can happen but usually something is in the vent line.let me know what you find,thanks
Nov 07, 2013 | Kenmore Dryers
Thermal cut-off
when the thermal fuse or the high limit pops it's because the dryer is running to hot,all a dryer does is move air,when one of the fuses pops it's from a block from lint either in the lint filter duct or the vent line,if the air can't blow outside or out of the dryer the fuse will blow.if your vent line is long remove it from the back of dryer and stick a leaf blower into the vent line and blow all the lint outside,make sure there isn't a cage or anything blocking the outside hood,then pull out the lint filter,take the dryer apart,remove the lint filter duct and clean it out,also vac and blow out the cabinet and motor,you should do this once a year,your clothes will dry on time,less parts will get damaged from overheating ,your electric bill will be less and most important you won't have a dryer fire.hope this helps,the fuse will keep blowing until you clean out the dryer and vent line.
May 16, 2013 | Kenmore Elite Oasis 6808 Electric Dryer
My dryer keeps blowing the thermal fuse help
Check your lint filter, exhaust duct, and check if duct flapper is opening fully or not. Allow some time between loads and don't stuff too many clothes.
May 12, 2012 | Maytag MDE9700AYW Neptune 174 Electric...
Where is thermal fuse
If your Kenmore dryer has stopped producing heat, chances are the problem lies with the dryer's thermal fuse. A fire-prevention safety device, the thermal fuse is designed to disrupt the flow of electricity to the dryer's heating mechanisms if the dryer temperature reaches a predetermined maximum. Once activated, the thermal fuse must be replaced to restore the heat to your dryer. In Kenmore brand residential dryers, the thermal fuse will be located in one of two places.
Instructions
Front Panel Access
1 Unplug your Kenmore dryer from its power source. Make sure that the appliance is unplugged before proceeding.
2 Use a flathead screwdriver or putty knife to remove the dryer's bottom service panel, sometimes called the toe panel. Slide the screwdriver or putty knife along the top of the toe panel until you've located the toe panel clips. The clips are usually located about four inches in from either side of the service panel. Push down on the toe clips with the screwdriver or putty knife to release. Remove the panel and set it aside.
3 Locate the thermal fuse on your Kenmore dryer. Look for the thermal fuse directly above the dryer's motor; it looks like a white strip with two wires, and is usually mounted off to one side. See Resources for a diagram of thermal components.
Rear Access
4 Disconnect the Kenmore dryer from its power source while locating the thermal fuse.
5 Move the dryer away from the wall so that you can access the back of the appliance.
6 Use a screwdriver to remove the dryer's back panel. Set the panel and loose screws aside until you are ready to replace them.
7 Locate your Kenmore dryer's thermal fuse just above the exhaust port. The thermal fuse looks like a white strip with two connected wires.
Tips & Warnings
Clogged exhaust ports are a common cause of thermal fuse failure. While you've got your Kenmore dryer in pieces, clean out the exhaust ducts to keep it functioning at its best.
Take all proper safety precautions when working with electrical appliances. Make sure that your Kenmore dryer is unplugged before attempting to service it.
Check this link ,if you use Whirlpool Dryers:
http://www.do-it-yourself-washing-machine-and-dryer-repair-help.com/thermalfuse-dryer-Whirlpool-29inch-electric.html
Thanks
Apr 01, 2012 | Dryers
Dryer runs for 3 to 4 minutes then and error message of E1 comes on. I have cleaned all the vents that I can find. I have tried spraying the filter screen with wrinkle free this works for a load or two...
Hi
E1 is a thermostat/thermal fuse failure error which means that the thermal fuse has gone bad and should be replaced. I believe that everything else is fine rather it is the the thermal fuse that is located inside the rear panel to the exhaust duct that is bad and should be replaced. If you want you can test this fuse for continuity and if bad replace it as it cannot be reset. If the fuse is fine then it can be due to the control board that is bad and should be replaced. Hope this helps...please post back with its model no for further assistance.
Daniel
Jul 31, 2011 | Kenmore Elite HE3 Steam 8674 Dryer
I have a kenmore elite model # 110.64942300. It seems like it now takes forever to dry clothes. Where should I start? It heat
Hello & Welcome to FixYa
If you have already tried cleaning the vent then the problem is with the Thermal fuse. When the thermal fuse goes bad it cannot be reset and replacing it is recommended repair.It is located on the blower wheel housing inside the rear panel to the exhaust duct. You can test the fuse for continuity before replacing, if the fuse is fine then please get back to me if you have any other questions.
Kevin
May 09, 2011 | Kenmore 62802 Electric Dryer
Kenmore Elite HE# electric dryer mod # 110.82822103 - Dryer turns on, but no heat and clothes unable to dry at all. It's like fluffing them with cold air blowing on them. :(
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)Here is a link to a video that will walk you thru the process.Here is a link to any of the parts you may need to fix it.I hope this helps you,Rick
Nov 28, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
My Kenmore Elite HE3 gas dryer does not heat up? What do I do?
Hi
Thanks for using FixYa. The first thing that should be checked is the Thermal fuse which is mounted to the exhaust duct inside the back cover. If this fuse goes bad the dryer will not heat and you’ll have to replace it as it cannot be repaired. If this is fine then you’ll need to check the thermostat, igniter and coils. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 21, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
Kenmore 80 dryer runs and blows air but no heat
If it's an electric dryer, then unplug the machine and check for a blown thermal fuse or a faulty heating element. The thermal fuse is about an inch long and is located inside the rear of the dryer, usually attached to or near the exhaust duct. The thermal fuse and heating element can be tested for continuity using a multimeter or ohmmeter. A lack of continuity will indicate a bad component. Sorry for your trouble and I hope this helped. Best wishes.
Oct 07, 2009 | Kenmore Dryers
Dryer not heating he3 kenmore elite
repl/ thermal fuse if no heat if heating for a little while clean exhaust, and repl/ coils
Dec 20, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Dryers Logo
52 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
