Question about Honeywell 2020-5B Cordless Bar Code Scanner Accessories
Honeywell 2020-5 suddenly stopped scanning. The lights are on the charger base, but the scanner seems dead.
  • 55 Answers
I guess there is a problem with the base station. Let me tell my story:
I got a 4820 scanner with 2020 base. All worked fine till I experimented with scanning images. After a few images (which I cannot retrieve/receive properly due to lack of software) the scanner seems dead. From time to time a short buzz sounds when triggered, but no light or else.
So I bought another 4820, a slightly different model. Seems to work fine but has to be paired with the base to get the data. Now after pairing this scanner shows the same issues as my first and refuses to scan.
I installed QiuckView and HSM-USB-Serial-Driver on a virtual machine at my MAC to flash firmware to base and scanners. But the base device does not show up in the program (althought it is shown in the USB device table). Maybe I can try on a native WindowsPC ...
Posted on Sep 29, 2014
Why won't my Realistic Pro 2020 stop scanning
You might have the squelch turned up too high so the broadcast cannot break the squelch open. Here's an instruction manual (with how-to) for your scanner. Seems easy. Also make sure you have a good antenna so you can pick up signals.
http://pdf.textfiles.com/manuals/SCANNERS-F-R/Radio%20Shack_PRO-2020%20VHF-UHF%20Scanner-Reciever_Short%20Manual.pdf
Sep 08, 2015 | Radio Communications
I have a Binatone house Telephone and it has locked
take the batteries out for 24-48 hours and let it sit unpowered to see if this helps (usually does)
Oct 01, 2014 | Honeywell 2020-5BE Compact Cordless Charge...
Barcode Scanner stopped scanning
These devices do fail, so that is most likely what has happened here.
Apr 13, 2017 | Honeywell 3820 Wireless Handheld Barcode...
My ls4278 is not lighting up when on the cradle, will not scan or charge...i have 3 scanners and cradles and somehow all the scanners stopped working completely..all the cradles have the light on but when...
The most unlikely scenario is that all the bases are defective. If you power your PC off every night, you should purchase a power supply so the scanners can continuously charge. Another issue may be that you need new batteries (also unlikely if they stopped working at the same time). Also try swapping scanners and bases (one scanner from one base and place it with another base) make sure you firmly place the bottom of the scanner in the base to verify there is a good connection with the charging pins. We are here to help if you have further questions.
Tech Support Barcoding Technical Support
May 18, 2011 | Symbol LS 4278 Barcode Scanner
FocusBT 1633 scanner will not scan. Windows XP says USB device is unrecognized. Owners manual indicates there should be an installation CD included for proper driver installation but Honeywell support...
win xp is a far outdated os and may not be compatible with the scanner
click on scanner properties and then the compatibility tab and see that the small square is ticked and then high light win xp as the OS
If there is no win xp , it will not work
if all is there then get the honeywell web site open and down load the driver for that scanner
Jul 30, 2017 | Metrologic Instruments...
RS Pro 2020 Scanner won't come out of scan mode, pad ineffective
If you mean a Bearcat 2020 radio, then that unit is ancient, and I'm amazed that it still works. If you're only monitoring one frequency, you can get a really cheap scanner to do that and replace the 2020.
Aug 01, 2009 | Radio Shack Pro-2018 Scanner
Radio Shack (Realistic) PRO-2020 Scanner stuck in Scan Mode
Sounds like old age - the 2020 is nearly 30 years old! Have you tried just using the LOCKOUT feature on all channels except the you want? How about just programming the same frequency into all 20 channels?
Jul 25, 2009 | Aiwa AV-S17 Receiver
Honeywell 2020-5B Cordless Bar Code Scanner Accessories Logo
585 people viewed this question
Top Honeywell Computers & Internet Experts
Les Morrison
Les Morrison
k24674
Are you a Honeywell Computer and Internet Expert? Answer questions, earn points and help others
