Question about Element Electronics FLX-3211B 32 in. LCD HDTV
Have an element tv 26 in. lcd hdtv.Model # ELCHS261 I use set as monitor thru vga port , due to partial vision. Turned off last night, This morning set will not turn on have Red light stationary lit. Then tries to turn on blue light Engages for a few moments than a Hard boot noise sounds and everything goes out. No lights until unplug for 30 sec. or so and plug back in.
5 Suggested Answers
SOURCE: Element tv.. model # ELCHS261 stopped working
My Element ELCHS261 will not turn on at all. The only thing it does is the red light will turn to blue but no sound and no picture. My troubleshooting items have been changed the batteries in the remote then I unpluged the power for for 30 minutes and still nothing.
Posted on Nov 28, 2009
budmrtn
  • 11361 Answers
SOURCE: Element 32" LCD HDTV 4
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there is some troubleshooting you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Posted on Apr 25, 2011
  • 73 Answers
SOURCE: Hello, I cannot power on my Element Electronics
Unplug it leave it unplugged for about 10mins. replug it in and turn it on. If that doesnt work. Your going to most likely need to change the fuse for the power current. IF your not sure how to do this find expert repair services near you. It is cheaper to buy a new tv unless you try to do it yourself and end up damaging more
Posted on May 02, 2011
Slinteriors
  • 8617 Answers
SOURCE: element elchs261 wont turn on not even the red stand by light is on.power cord is plugged in
Replace the power supply board. You can get the replacement power board from www.tvrepairworld.com
Posted on Nov 12, 2012
RCA 26 HDTV LCD Monitor
Probably a burnt fuse, have it serviced.
Feb 21, 2008 | Televison & Video
Tv model ELCHS261 WONT TURN ON?
There's a signal lights or power lights.?Plss check the fuse at the power supply, replace if busted.Thanks!!!
Aug 20, 2011 | Element Electronics ELCHW261 26 in. TV
I GOT THIS MONITOR/TV FROM DAUGHTER, I DON'T HAVE MANUAL. HOW DO I HOOK IT TO MY COMPUTER TO USE AS MONITOR. WHAT CABLES AND WHAT PORTS? THANK YOU
Tries Element website itself if ur LCD tv model still in the market u can download manual for free not look for their phone number like 1-800..call them pay them a fee they'll send out a copy of the manual to u.U have a LCD monitor now hook up to ur computer right now to used as a monitor now wright?Yes.Take that VGA cable out from ur computer and ur old LCD monitor VGA cable out of the VGA ports just take ur hand and unscrew the VGA cable.Used ur old LCD monitor VGA cable and hook up to the LCD tv VGA port and to ur computer VGA computer graphic card port or computer monitor port hook up the other end.Turn on ur Computer and tv on used the sides button of the tv find one that said INPUT push it a few times should find ur tv mode 1,2.3 ur computer is on as a monitor.
Aug 19, 2011 | Element Electronics FLX3210 32 in. LCD TV
How do i connect my pc to my LG 32LF77SO I CAN GET SOUND AND VISION
Most HDTVs today have a 15-pin VGA input so to hookup a PC, just connect a VGA monitor cable from the PC monitor output to the HDTV VGA input port. This gives you video. For audio, you can connect a stereo audio cable (3.5mm) from the PC soundcard speaker jack (usually green) to the HDTVs audio input port next to the VGA port. Next you need to adjust the settings for video resolution and refresh rate on the PC so that the HDTV is compatible. Look in the HDTVs owner's manual for a chart showing the acceptable video screen resolutions (1024 X 768) and refresh rates and adjust the PC accordingly. You should now have video and audio on the TV. For a laptop, it depends on what outputs it has, VGA, HDMI or S-Video but this can be done as well.
Mar 26, 2011 | LG Televison & Video
Last night the tv was fine i turned it on this
Unplug 20 minutes. Make sure there is adequate ventilation around the set.
Try with the original manufacturer remote to view setup menu.
Power outages come at night. This sometimes resets the TV and other devices. .
Mar 25, 2010 | Insignia 42" LCD Flat-Panel HDTV
Insignia 26"LCD TV "No Signal"
Your description pretty much narrows it down to tuner failure. I have had experience with Insignia products so not surprised.
Mar 03, 2017 | Insignia LCDTV26 26 in. Television
Jul 10, 2009 | Element Electronics FLX2211B 22 in. LCD TV
Samsung lcd tv wont turn on
My Samsung LCD 32" 540 has two screens side by side. It worked fine last night, turned it on this morning and now double vision.
Aug 17, 2008 | Televison & Video
Element Electronics FLX-3211B 32 in. LCD HDTV Logo
46 people viewed this question
Top Element Electronics Televison & Video Experts
LP
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
