Question about Hobart Dishwashers
Echo Lab supplys the soap for the C64A that I have, they say the machine is calling for water too often and Chef says he is using way too much soap, Cost, Cost, Cost. Any Ideas? I need help
2 Suggested Answers
  • 34 Answers
SOURCE: the water does not drain still has soap in it
is the water backed up inside the dish washer
Posted on Jan 14, 2010
True or false? Only antibacterial soap should be used when washing your hands
Antibacterial soap should only be used when preparing foods for cooking and more so for ready to eat foods that do not have heat treatment.
For normal tasks, normal hand washing with any soap is fine. In fact, good hand washing techniques with water over 110'F makes antibacterial soap unnecessary.
Chef, Hospitality Manager and Advanced Food Safety Certificate holder. I took the course for the second time just last week as required by my company :>)
Mar 30, 2016 | Washing Machines
The soap pipe is not working
how about some more info. Does the soap pipe have a clog in it? Try putting a lenghth of wire down it to check for clogs. Also, run a load of full strength vinegar through the machine. Turn off the water supply, set the machine on to a point past the fill timer, then add at least 1 gallon of pickling vinegar, then turn on the machine. Stop it before it discharges and drains the vinegar, and reset it back to the beginning of the wash cycle. Do this several times until the wash water gets gunky, then let it complete the cycle after you have turned the water supply back on. Check the soap pipe now. Frankly, I have never heard of a soap pipe so I wonder if this is really your issue. do you perhaps mean a spray arm? At any rate, a good cleaning like this should solve your problem. BTW, if you do not want to use vinegar, try a package of lemon jello or a purchased product called Lemi-Shine both of which you run through your machine to clean it iout.
Mar 04, 2015 | Jackson JPX-300L Dishwasher
Water spilling
If water is spilling from the soap tray, try closing the water supply taps a little. Your water pressure may be too strong for the machine...common issue for front load machines when being used on water lines that have not been properly regulated.
Aug 05, 2009 | LG WM-2277HW Front Load Washer
There's a foamy soap left in my washing machine after the laundry is done. We've established that I'm NOT putting in too much soap; it just isn't rinsing properly. The repair guy says it is draining fine,...
For low water volume - or "Trickling" effect...
1. Turn off the water supply to both hoses.
2. Remove hoses (one at a time so you don't get them confused)
3. On the washer side - look for a removeable screen inside where you just removed the hose.
4. Using a small screwdriver - pop out the screen and reverse-flush it/clean it. It will likely be full of sediment and calcium deposits from your pipes.
5. Replace the inlet screens.
6. Re-fit the hose to the machine.
7. Turn on water supply valves.
8. re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 21, 2009 | Washing Machines
My front loader doesn't use enough water.
3. On the washer side - look for a removeable screen inside wher you just removed the hose.
8. re-try.
Feb 20, 2009 | Kenmore Elite 45986 Front Load Washer
No dishwashing agents or rinse agents dispensed into machine through external tubes.
The D-8 is a great D/W and is in fact a full use D/W if you call Ecolab,Diversey or whatever chemical agent you use they can install an automatic soap system on this machine with no trouble
service gnome
Oct 24, 2008 | Blakeslee D-8 Dishwasher
Dishwasher won't drain water
The bubbles created by the dish soap could cause poor draining, but I would think it would just cause more of a bubble problem than a draining problem...
Either way, some people would say to throw a cup of vinegar into the wash area, but I prefer to just use water.
Disconnect the drain line from the machine at the sink and route it into a 5 gallon bucket. Drain and fill the machine several times to clear the bubbles out. This will also give you the opportunity to see if the drain problem you state is a machine problem or a drain problem.
Hope this helps,
Kermit
Aug 14, 2008 | Magic Chef 24 in. DU2000 Built-in...
Hobart LT 1 dishwasher leaving film on dishes
The machine is seldom the cause of "film". Make sure the unit is draining proper and that the fresh water supply is supplying good pressure.
Usually film is caused by using residential soap in a commercial unit. The commercial unit cycle is too short for residential soaps to dissolve and work properly. So soap ends up in your rinse water.
Mar 23, 2008 | Dishwashers
Dishwashers Logo
29 people viewed this question
Top Hobart Dishwashers Experts
Jason
Garth Jackson
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
