Question about Saniflo SaniCompact-48 SaniCompact One Piece Macerator Toilet
Won't flush when button is pressed - Saniflo SaniCompact-48 SaniCompact One Piece Macerator Toilet
Roca dual push button Toilet will only flush when holding the push button continuously down until the cistern is empty. It won't completely flush like it should when pressing the button once.
allow tank to fill a little more by adjusting fill valve. When there's not enough water flowing from tank the stopper can over-power the water flow and cause the flush to stop by re-sealing.
Feb 28, 2015 | Home
Flush button, when pressed nothing happens
Grasp the collar that surrounds the button and turn counterclockwise to unscrew it and allow the cover to be removed.
Hope this helps.
Bob
Jun 22, 2014 | Porcher Home
Mac won't turn on
Plug the laptop into the wall with the included charger. If that does not fix the problem, check that the battery is properly installed- it should be flush with the rest of the computer and locked in place.
Oct 14, 2012 | Apple MacBook Pro Notebook
Hi Ive had my senseo coffee machine for a while, i need to flush it but cant remember how to?
Flush it with a citric acid suspension:
  • Fill the reservoir with the suspension,
  • Place a large bowl under the spout,
  • Press and hold the 2 small buttons, and
  • Briefly press the Power button.
To stop the rinse, press the Power button again. I suggest you repeat the procedure a few times, remember to swap the pad holders somewhere in between.
Then repeat the procedure a few times with fresh water to get rid of the citric acid.
Oct 17, 2009 | Cakewalk SONAR 4 Producer Edition for PC
Push Button - Have to Hold Down Button
I had the same problem. The fix cost me 50 cents (literally). I just placed a quarter on top of the Blue and White flush buttons (not sure of the technical terms) inside the tank and now it flushes properly. It seems that the 2 plastic poles the extend from the faux chrome buttons are just a bit too short.
Hope this helps
Feb 18, 2009 | Toto Aquia II Dual Flush Toilet
Brother mfc 420cn, machine error 46
Your waste ink absorber box has reached its limit. You have to replace the box (which is cheap, get one from your local brother service centre).
After replacing it you have to reset the purge counter and flushing counter.
This is not easy to do and I don't recommend it for anyone who is not technically inclined. You have to remove the front control panel, open the covers on the top cover assembly under the scanner. Unplug all the cables. Disconnect the ground wire (if any), remove the prop, remove the scanner assy by opening 90 degrees and sliding rearward. Put scanner aside. Remove four screws holding top case on, pry out the bosses at the front and remove the top cover.
At the rear you will see the flushing box or waste ink box. Lift it up a little. You should see two tubes attached. Remove the tubes and pull the box out. Dispose of old box. Attach the tubes to the new box and install it where the old one was. Reassemble in reverse order. Don't forget to plug in all the cables under the control panel.
Plug the unit in while holding down the Menu button. Keep holding until all the lights are flashing. Welcome to maintenance mode.
Press 8 and then 0. Press the Black Start key several times until you see Purge or Purge Count on the display. Now press 2, 7, 8, 3 to clear the count. Press Stop. Press 8, 0 again and the Black Start key several times until you see Flush or Flushing count. Again press 2, 7, 8, 3 to reset the flush count. Press Stop. Press 9 and 9 to exit maintenance mode. Job done.
Jan 19, 2009 | Brother MFC 420CN All-In-One InkJet...
Saniflo SaniCompact-48 SaniCompact One Piece Macerator Toilet Logo
56 people viewed this question
Top Saniflo Home Experts
Paul Carew
Tim Whalen
Are you a Saniflo Home Expert? Answer questions, earn points and help others
