I have a duroguard furnace does not turn on at all it only makes a clicking sound
2 Suggested Answers
  • 3315 Answers
SOURCE: carrier furnace clicking/rattling
Hi some thing in the blower motor or combustion fan?
Posted on Feb 16, 2010
Clicking noise as furnace tries to start
If you have a gas or fuel oil furnace, that is your igniter trying to light the fuel. If it does it for a few seconds and quits without lighting the furnace, there may be no fuel getting to the burner. Check for fuel supply - oil tank empty? gas line turned off? etc
Jan 16, 2017 | Cars & Trucks
Multiple clicking sounds coming from AC unit before AC unit turns on or before furnace turns on.
the is a 24v wire that feeds from your thermostat to your unit, inside there is a contactor that engages, this makes a click sound as it really is a basic mechanical part the makes metal touch metal to allow current to flow through the system, perfectly normal, your hearing the low voltage engage the highvoltage at the contactor.
Jun 18, 2013 | Dometic Rooftop RV Air Conditioner
Have a rheem furnace/ten yrs old.just replaced thermocoupler and gas valve,furnace will turn on thermocoupler will get red but no heat? whats up?
I know it may sound strange but check to make sure the gas cut-off valve is turned parallel with the gas pipe. If its open, you may have a failed fan proof switch. air pressure from draft induced blower causes the switch to click and open the main gas valve. if this this switch doesn't click(close contacts) the maing as valve will not open to ignite the burners. its a sequence of events that a furnace goes through before it ignites the burner for heat.
Nov 28, 2010 | Heating & Cooling
FURNACE MAKES STRANGE INTERMITTENT CLICK SOUND
Measure the voltage to Terminals #2 and #3 on the main gas valve. If the voltage remains consistent while you hear the sound and the burners diminish slightly, the problem will be your main gas valve. If the voltage fluctuates, you will have to trace it back through the wiring to see through which switch you are losing it.
If this furnace has a hot surface ignitor with flame sensor, try cleaning the flame sensor with some emory cloth.
I hope you find this information to be very helpful as a good starting off point for you.
Please leave a rating. :-)
May 11, 2010 | Heating & Cooling
Looks like an older system. Tighten all of your electrical connections. Inspect all of the low voltage wiring for any insulation cracks or other damage. The problem you describe sounds like something is either "shorting" or breaking down electrically. Unless the technician can catch it while he/she is there, it will be difficult to determine exactly what is happening. You might get lucky and resolve it yourself by tightening all electrical connections and reinsulating (use electrical tape) any damaged low voltage wire connections. If you continue to experience problems, get the tech. Hopefully the last company you used will be willing to work with you on the bill considering they were unable to "catch" it during the last visit.
Without being there with toolbox in hand, I hope you find this information very helpful moving forward. :-)
Mar 19, 2010 | Heating & Cooling
Carrier furnace clicking/rattling
Feb 16, 2010 | Heating & Cooling
Furnace does not work
Is there a booster motor for the burner? I have seen these stick and make a furnace not turn on. The thermostat trips and you hear the furnace click on but nothing else happens. The booster is a small electric motor connected to a small duct. Take the booster motor loose and turn the fan by hand. Usually they will start working after you do this. Make sure furnace is shut off when you do this. Some booster motors have ports to oil them also.
Dec 09, 2009 | Calvin Klein The Field Controls Company...
Thermostat seems to be working, furnace does not always turn on
Joss sounds like the anticipator setting on thermostat i would replace it with a digital it will be more actturat . The furnace has to go over temp setting to turn off
Jan 15, 2009 | Honeywell Electronic Programmable...
Fault Code on Dayton Gas Furnace
This happens when the furnaces tries to light to many times and doesnt succeed. If you stand in front of the furnace while it is coming on, you will be able to hear the problem. If its an electronic start, there will be a clicking sound, followed by the gas valve opening to start it. If it has a pilot light, make sure it is lit, then listen for the gas to come out, it will make a hissing sound. If no gas is coming out, first double check to see if the gas is turned on to the unit, if it is, then its possibly the gas valve. Oh, if it is electronic, and you hear gas, but dont see a glow inside the furnace, or no glow or gas, it could be the ignite. Hope this helps.
Jan 07, 2009 | Dayton Gas Furnace Heater
Heating & Cooling Logo
11 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
