Question about Empire Comfort Systems Televison & Video
Need skytech sky mrck sr 1001 remote only for propane log fireplace
SOURCE: skytech model no. sky-3001 changed batteries in
You have to get the remote and transceiver to talk to each other. Remove all the batteries and wait a couple of minutes
before replaceing them. Place the transceiver in the REMOTE
position, press and hold down the LEARN button, and then
press the MODE button on the remote control. A change in the
beep tone will be heard and you have MARRIED the two devices. Should solve the problem.
Posted on Jan 01, 2011
  • 4736 Answers
SOURCE: I have a Skytech 1001
Rhonda, if you have the On/Off/Flame Height Remote Control ... from what you have described (it's working in reverse) someone has wired it backwards to the control valve. With this particular remote, there is a positive and a negative. Reverse the wires that are connected to the gas control valve (at the control valve. Not on the Black Remote Box) and everything should be fine. If you need more help contact Skytech Technical Service @ 888-672-8929 Monday - Friday. They are great people to work with.
Posted on Jan 15, 2011
  • 4736 Answers
SOURCE: hello, My heat n glo fireplace
Yes, just a couple of thoughts and questions. When you replaced the batteries, how many batteries did you replace? If it wasn't more than 2, you have 4 more AA Batteries to replace in the receiver (black box that beeps) behind the louvered flip down door. If you did replace those, recheck them to make sure they all facing the proper direction. One battery out of place, will throw the whole system off. In addition, sometimes the Slide Switch on the front of the Receiver (black box) can be a little finicky. It may appear to be in the REMOTE position, when in fact it isn't. Gently moving it one way or the other will allow you to feel it go into place.
It would also be wise to check the two wiring connections, at the receiver box and the control valve terminals to make sure they are tight. The wires to the control valve terminal should be on the TH & TPH terminals. Also, make sure the wires haven't been grounded out due to wear and are touching some metal part of the firebox.
And last, but not least, your Heat-n-Glo fireplace has it's own ON/REMOTE/OFF rocker switch. Has it been moved to the wrong position? If it has, it's overriding the remote control. Depending on who installed this fireplace, the may have just wired the remote to the wrong switch position. So, try using the hand-held remote in all three positions, until you find the right one.
If all else fails, contact Sky Tech Systems, Technical Service Dept 888-672-8929. They are great folks to work with.
Posted on Apr 13, 2011
sales50056
  • 72 Answers
SOURCE: Skytech 1410 fireplace remote (8 yrs. old) has stopped working. Replaced batteries in the transmitter. The red light lights up when
It may need to be re-synchronized:
Make sure the receiver's slide switch is in the REMOTE position.
Press and release the LEARN button on the receiver.
When you hear the "Beep", press and hold the ON or OFF button for about 2 seconds on the transmitter.
You will then hear a series of beeps that indicate that your new transmitter has been accepted by the receiver.
If you press the LEARN button on the receiver and you hear no beeps, the receiver is unable to retain any more transmitter codes
(make sure the transmitter battery is properly installed and fully charged).
To delete all of the transmitter codes on your receiver, press and hold the LEARN button for 10 seconds. Then you will hear a
series of beeps, indicating that the receiver's memory has been cleared.
It could also be dead after 8 years. A new unit can be purchased here: Skytech Remotes. I would even suggest on of the new styles with a built in timer or thermostat.
Posted on Nov 30, 2012
  • 34255 Answers
SOURCE: I have a skytech 1400 remote to a gas fire log fireplace. The light in the hand held will not burn even after replacing a new battery what di I do next?
The replacement battery could be defective or installed incorrectly.
Posted on Dec 08, 2014
Connect wires properly
Yes, you SHOULD connect all the wires properly.
Your should also ASK YOUR QUESTION PROPERLY!
Come on, man. Get with it.
You are asking how to connect wires to a remote control?
Someone dropped you on your head as a child, yes?
Fireplace? Don't play with fire.
Mar 05, 2015 | Skytech 1001-A Fireplace Remote Control...
My fire place elecric starter won't work after running out of propane
Most likely, you need to "bleed the line". The new propane needs to travel to your fireplace, but you have a huge air pocket in there now since it ran dry. It takes forever for the air to "bleed" out through the tiny orifice of a pilot light, especially if the distance from the fireplace to the tank is far.
Jan 28, 2013 | Skytech 3301 Thermostatic Gas Fireplace &...
My AVANTI remote will not turn on my gas fireplace even after replacing the batteries
Problems with the Avanti remote led me here:
http://www.amazon.com/Skytech-Sky-3301-Fireplace-Thermostat-Remote/product-reviews/B001DEZ7J6
Jan 22, 2013 | Heating & Cooling
Remote for SkyTech Un3 will not work, need Manual
I have a direct link to the Skytech 1001-A owner's manual on my site here: Skytech 1001-A Fireplace Remote.
Simply scroll down to the bottom of the page to the "Download Owner's Manual" section. I try to keep it updated if the link ever changes.
Thanks!
Dec 28, 2012 | Skytech 1001-A Fireplace Remote Control...
Need Manual for SkyTech Remote UN3
You can visit my product page here: Skytech 1001-A Fireplace Remote. Simply scroll down to the bottom where it says "Download the Install Manual", I keep an updated link to the owner's manual.
Thanks!
Skytech 3301 thermo
Check to make sure your thermostat is set at a temperature that will turn the fireplace "on".
Double-check what your "swing" temp settings are set at, as this may effect how quickly the unit shuts off because it thinks it's too close to the target temperature.
If needed:Skytech's Tech Support number is 1-888-672-8929They are available Monday to Friday, 8am to 5pm EST.
If your remote needs to be replaced, the 3301 is available here:
Skytech 3301 Fireplace Remote
If you are looking to replace it, I would also highly recommend looking at Skytech's new 3301P2 remote. It adds a programmable thermostat, and a much nicer back-lit LCD screen. This unit is available here:
Skytech 3301P2 Fireplace Remote
Dec 15, 2012 | Skytech 3301 Thermostatic Gas Fireplace &...
The remote no longers turns on the fireplace.
  • Is your valve turned "on" and not in the "pilot" mode?
  • If your valve is in the "on" position, try turning the Skytech receiver's switch to "on" instead of remote.
  • If the fireplace ignites when the receiver is "on" then the remote needs to be re-synchronized.
  • If the fireplace valve is "on", the remote's receiver is in the "on" position, and the fireplace will not light, then you most likely have a bad thermopile in your fireplace and need service.
  • Skytech 1001-A product page and manual can be found here.
Dec 09, 2011 | Skytech 1001-A Fireplace Remote Control...
How do I sync my remote to the receiver?
If you don't have your Owners Manual, it's available online in pdf format from SkyTech. I recommend that you download it and print for future reference. These are not hard to program, but having the Owners Manual for other trouble shooting problems you may encounter, makes it worth it's weight in gold.
http://www.skytechsystem.com/editor/assets/installation%20files/1001%20BE%20Instructions.pdf
If, when you click on the link above and it doesn't work .. copy and paste it into you web browser.
Jan 21, 2011 | Skytech 1001-A Fireplace Remote Control...
I have a Skytech 1001 TH-A thermo remote. Everything was hooked up correctly, but the remote continues not to work. When I turn the remote off, the fireplace comes on and vice versa.
Jan 02, 2011 | Skytech 1001-A Fireplace Remote Control...
Televison & Video Logo
Top Empire Comfort Systems Televison & Video Experts
Electro Med Services...
Are you an Empire Comfort Systems Televison and Video Expert? Answer questions, earn points and help others
