Question about Xantrex Technology Xantrex Xpower PowerPack 300 EP (XPOWERPK300EP) 300-Watt Power Supply
When i plug in the adaptor to charge my powewr pak the green lite comes on and it makes a clicking sound that will not stop and the green lite keeps on flashing is my battery no longer able to accept a charge?
Advent power adaptor flashes green
does the charge light come on? It could be the connection piece of it, they are made pretty flimsy..
If you know how to safely do this check the voltage on the computer side of the adapter for the proper voltage.. sounds like it's on it's last legs though.
Apr 18, 2013 | Computers & Internet
DS won't turn on
Hi Atticus,
I have seen this happen when someone plugs the wrong charging cord up to the DS lite, Is there any chance some one did this to your DS lite.It sounds also as if the battery is not making proper connection.
  1. REmove the battery from the compartment
  2. inspect the connector on the battery and where the battery connects to the DSlite.
  3. Wipe thee connections off some way. I suggest some contact cleaner for bith the battery and Battery compartment connections
  4. Try the DS lite again with the battery installed.
I hope this gets you in business  Atticus. Do not Vote until we get it working.  Try this and add a comment to this problem posting. I will answer as soon as I possibly can. Thank you very much for the opportunity to solve your porblem with a DS Lite.
Oct 18, 2007 | Nintendo DS Lite Console
Nyko charger won't charge
Had same problem with blinking lights and not charging.
Plug charger base in (blinking lights), remove controllers, and plug USB cable into front charge slot (behind hinged panel). This reset charger base and lights stopped blinking. As FYI - the USB was connected to other device (charging it). Add the controllers and correct charging lights show up - including the controller 1 and 2 symbols. Controllers now charging.
Feb 07, 2012 | Nyko Charge Station 360 For Xbox 360
I just got a Marlboro Power Pack too and have not idea how to charge it. It came with a corn with a cigarette lighter plug at one end and a negative and positive plug at the other end. what does this...
The pac will have a door on both sides that hide the cables you hook to a battery to help jump start a car once it is charged up. The cord that you say has a cig plug on one end is used to charge it using your car plug. There is another door on the back of the Pac that holds all the accessories, extra fuses and the charging cords. It does not sound like you have the A/C adaptor to plug it into a wall outlet.. If this unit is old the internal battery may be bad these Pac's are notorious for battery failure. You can find these batterys on eBay for about $13.
Nov 12, 2010 | Garden
My tomtom 910
Have same thing. I did call Tomtom and they are guessing ,just like me ,that battery is dead and offered me US$ 75 off brand new go 730 and old one u can keep. Was told ,they dont sell battery replacement .
Sounds like someone will sue their **** soon as class action .
Sep 05, 2009 | Tomtom GO 910 GPS Receiver
Havoc heli will not charge
As far as the green light on the charger not coming on: after I tested the batteries in the remote, I found that it was due to 2 of the 6 batteries in the remote control being dead (0.1volts) The charger probably sucks the power out of the #1 and #6 battery.
Make sure all batteries in the Remote have the same charge.
Also, there seems to be a loose contact in the charger plug prongs. You will have to find a way to sit the helicopter so that it stays in contact with the prongs while charging. Mine has to be on it's side to keep the green charger light on.
Dec 26, 2008 | Air Hogs Havoc Heli Helicopters
Nintendo DS Lite power adaptor disconnection problem
There is a small latch on the connector that may be stuck. Try this. Turn the DS Lite upside down with the charger plug facing away from you. Press down the on the plug gently with your right thumb and with your left hand pull the connect away from the socket. FYI this should be a simple fit! Make sure the connector was not jammed in upside down to start with. It has a clear six sided shape to it!
Dec 23, 2008 | Nintendo DS Lite Console
Ac adaptor
Sounds like a DC jack or supply line issue. How old is the machine?
Feb 12, 2008 | Compaq 127770-001 127770-001 ARMADA E-500...
Xantrex Technology Xantrex Xpower PowerPack 300 EP (XPOWERPK300EP) 300-Watt Power Supply Logo
42 people viewed this question
Top Xantrex Technology Computers & Internet Experts
Are you a Xantrex Technology Computer and Internet Expert? Answer questions, earn points and help others
