Question about Frigidaire Ovens
Feb556cbt-a flashes f5 - Frigidaire Ovens
My toaster showing f5 mag temp and it only toast for 6 seconds then stops any ideas???
assuming its been fixed by now.
thermal-couples on mags trigger at 160F i believe.. forces shutdown for safety.
possible causes..several
mag fan working?
EC fan working?
mag cooling fins packed with dust?
wave guides full of crud causing arching?
mag tip burnt?
faulty mag thermal-couple, unlikely
Nov 07, 2012 | TurboChef TORNADO Electric Oven
What is F5 Frigidaire oven unit, it's beeping and
The F5 ERROR code means that the self check that the control (also called clock)board runs to check itself has failed and the control has detected a problem within itself and the control must be repalced.
Gene
Aug 10, 2011 | Frigidaire Ovens
My kenmore oven will not work . it flashes an F5 code.
Hi, the f5 error code is a door lock code, which means there is a problem with your door latch. its should lock the door at a crtain temperature and its not.
Oct 19, 2010 | Ovens
During selfceaning cycle F5 and beeping occured, removed power and powered back on and it seems to be ok, however I haven't tryed the self cleaning yet.
possibly a door latch issue depending on your brand , this is common during self clean dont self clean unless u have to those ovens get close to 1000F so melting of some parts is inevatible.. did it flash f5 and then an error code like e1 or e2 that would direct us to possible more solutions, or it might blown a thermostat more likely on a wall oven and not a range.
Jan 28, 2010 | Ovens
Admiral designer series gas stove flashing f5 error
Hi There
i look up your codes for you and found it. you can read this and i hope this gets you in the right direction.
F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC)Thank you for writing to fix ya.
Best Regards Richard
Dec 23, 2009 | Ovens
Flashed F5 when temp is heating up
HI, this code is signaling that your temperature sensor is malfunction. it will result in major damage to the control board and sensor wiring harness if it is not corrected soon. the will allow for high temps during the cleaning process that will ruin the ovens control circuit board.
replace the oven temp sensor soon.
May 19, 2009 | Kenmore 47834 / 47832 / 47839 Electric...
Dacor oven beeping
Keeps flashing F1 and beeping help! how do I make it stop?
Apr 25, 2008 | Ovens
Oven failed to work; F5 error message
please tell about the make & serial no. of oven.
Sep 30, 2007 | Ovens
Ovens Logo
41 people viewed this question
Top Frigidaire Ovens Experts
Oloyede Monsuru
ashburton
Starnley Johnwells
Starnley Johnwells
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
