Question about Shark Vacuums
I have a Shark vacuum model # NV22LN do I wash to top filter that you empty every 3 months
  • 43 Answers
SOURCE: washing cloth bag
According to the FAQ's on Shark's web site on your model, they state: "The cloth filter can be washed as well and must be completely dry before using again. We recommend 24 hours to air dry as well."
Posted on May 07, 2009
  • 17 Answers
SOURCE: bissell cleanview vacuum poor suction
The next thing that you need to do is replace the belt. Even if it's not cracked or worn, many times it's too loose, and it won't turn to rotor efficiently.
Believe it or not, just replacing the belt may be all that you need to do!
Posted on Jul 07, 2009
heatman101
  • 43501 Answers
SOURCE: Shark Steam Mop - Gray/ Purple Vacuum: When washing the shark steam mop pads, can I use a...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Yes, ammonia should not hurt anything as all of the parts are plastic and there is nothing to corrode...
Euro-Pro Shark Steam Mop Problem
heatman101
Posted on Sep 03, 2010
  • 5370 Answers
SOURCE: I have a bissell vacuum
The filter if its dirty in gives bad smell.Also if it gets worn out or very old it gives bad smell.Many other users too have noticed this bad smell.Replacing the filter helped many other users too. The worst part being smell of the filter once it goes bad it stays bad and fills the room with a nasty rotten smell. ----------- Also you try cleaning the filters.As you mentioned in your question that you have already tried this but try to clean the filter as per the instructions mentioned in the service manual.And see if that reduces the bad smell. The manual specifically states not to use a mild cleaning agent while washing the filters, you may wash the filters in cold or warm water using a scented mild detergent, and make sure to remove any excess water in the filters since this is what normally creates the horrible smelling odor after it has been washed and dried.Also let the filter get completely dried up before you refit the filter again.If its fitted wet the bad odor smell comes.You can use hairdryer to dry the filter quickly.Check out if this is helping.Thanks.Helpmech.
Posted on Dec 10, 2010
small6363
  • 18392 Answers
SOURCE: I need a manual for the shark roadster aspirateur vacuum model EP732. Can't seem to find the power switch.
click this link for your manual,,enjoy please rate me
http://www.sharkclean.com/manual/EP732_-_EP732F_REV_0705.pdf
Posted on Apr 18, 2013
Shark navigator lift away turns on but no suction
Hello, this is Ava with Think Crucial.
It seems that there may be something blocking the airway. To fix this, please make sure to unplugged the unit from the power before performing this.
There are two places where you can check for a blockage: the dust cup air duct and the intake opening behind the brush roll. To check for a blockage in the dust cup air duct stand the vacuum upright and remove the dust cup. Now you can disconnect the super stretch hose and check for clogs in the air duct behind the dust cup. If that is not the case, to check for a clog near the roller brush lay the vacuum down. Next check the opening behind the brush roll for clogs. If there is debris, clean the opening with scissors, carefully cutting away any debris.
If the dust cup is too full, there is no space for the dirt to go when you are vacuuming. To fix this, remove the dust cup and empty the it. If your vacuum is still not picking up dirt after emptying the dust cup, keep reading for other options to fix the suction.
If both your foam filter and felt filter have not been cleaned in the past month, this may be why your vacuum has lost suction. To clean the foam and felt filters, remove the dust cup and pull out the two filters that are on the top of the motor base. Rinse the filters with lukewarm water until the water is running clear. Let the filters dry fully before putting them back into the vacuum. If your vacuum is still not picking up dirt, you may need to replace it.
If none of the other solutions worked, your motor may be bad. You would need to check with Shark about this.
If your need to replace your Shark parts such as filter, belts or hose, you can also order replacement parts directly to us. You can check our online store in this link: http://www.thinkcrucial.com/search?type=product&q=shark
As a special offer here is an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
Ava B.
Think Crucial Customer Care
Oct 17, 2016 | Shark Vacuums
Shark rotator no suction
If your vacuum is still not picking up dirt after emptying the dust cup, there may be something blocking the airway. There are two places where you can check for a blockage: the dust cup air duct and the intake opening behind the brush roll. To check for a blockage in the dust cup air duct stand the vacuum upright and remove the dust cup. Now you can disconnect the super stretch hose and check for clogs in the air duct behind the dust cup. If that is not the case, to check for a clog near the roller brush lay the vacuum down. Next check the opening behind the brush roll for clogs. If there is debris, clean the opening with scissors, carefully cutting away any debris.
Uncleaned filters may also the reason why your vacuum has lost suction. To clean the foam and felt filters, remove the dust cup and pull out the two filters that are on the top of the motor base. Rinse the filters with lukewarm water until the water is running clear. Let the filters dry fully before putting them back into the vacuum.
Unfortunately, if none of the other solutions worked, your motor is going bad. Most of the time a new motor costs as much as the vacuum itself and it is not easy to replace the motor. It may be time for a new vacuum.
You can purchase a wide variety of high quality Shark replacement parts for your Shark vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=shark+rotator
I hope this was helpful.
Ava B.
Oct 10, 2016 | Shark Vacuums
I cleaned the filter and emptied out the canister from the bottom and now the dirt comes out on my filter and not in the canister?
The first place the "dirty" air enters is the top chamber of the canister where it traps the bigger stuff.
The canister has two clean-out doors so make sure you open them both (top and bottom) or you could have problems.
Nice thing about the Shark as it has a number of clean-out points starting at the base of the hose where it enters the bottom of the vac. to the beater brush (on the bottom of just behind the brush assembly). Good luck!
Mar 16, 2015 | Shark Navigator Bagless Upright Vacuum
Vacuum is clogged with dog hair. How can clog be removed?
HI, it's Jim from Crucial Vacuum!
If your Shark vacuum is clogged with dog hair there are a number of general maintenance cleaning tips you could perform to help keep your vacuum working at its peak performance.
First let's check out your brush roll. Is there dog hair wrapped around the roll itself? If so remove it by pulling out the dog hair, or use a razor if its tightly wrapped around. Manually rotate the brush roll to help unearth any hidden clogs behind the roll.
If there's dog hair throughout your unit be sure to empty the dust cup after every use. When the dust cup isn't emptied often this leads to clogs and a loss of suction.
Also, be sure to check your vacuums hose for any clogs, or clumps of dog hair. Stretch the hose out as far as you can. If you notice a clog in a hard to reach place use a broom handle to unclog it.
Your Shark vacuums filters may need to be replaced, or washed and may be a source for a lot of the dog hair in your vacuum. Wash and clean your unit's filter weekly. To do so, empty your filter screen outdoors to take off any excess debris and then clean under running water until the water comes out clean. Allow the filter screen to fully dry before inserting it back into the unit. This may take up to several hours.
You can purchase replacement parts for your Shark direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/shark.html?limit=all
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim Thompson
Crucial Vacuum Customer Care
Mar 11, 2015 | Shark Vacuums
Shark troubleshooting
Hi, it's Jeremy from Crucial Vacuum.
There are a few potential solutions you should try. You can check the hose and canister again to make sure nothing is lodged in them. If that does not work the problem could be related to your filter. Filters should be replaced every 3 to 6 months for optimal performance. You can also try replacing the battery. This should be done every 6 to 12 months.
You can purchase direct your replacement Shark Vacuum products from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
Jeremy Lerner
Jul 16, 2014 | Shark Nv352 Navigator Lift-away Complete...
Model number NV501 seems to be running hot. what should I check for?
i think the coil lamination have got shorted or there may be any shorting of circuit. you should get it repaired without anymore use.
Jun 20, 2014 | Shark Rotator Professional Lift-Away...
THANK YOU FOR THE INFO ON THE SHARK NAVIGATOR--almost bought it!!!
I don't now where you got your information. We have 3. You cann't beat them. The price you can't beat. Warrenty can't beat 10 years.
Feb 16, 2012 | Euro-Pro NV22 Shark Navigator Bagless...
My Shark vacuum is losing suction. How do I fix that?
If the dust cup is too full, there is no space for the dirt to go when you are vacuuming. To fix this, remove the dust cup and empty the it. If your vacuum is still not picking up dirt after emptying the dust cup, there may be something blocking the airway. There are two places where you can check for a blockage: the dust cup air duct and the intake opening behind the brush roll. To check for a blockage in the dust cup air duct stand the vacuum upright and remove the dust cup. Now you can disconnect the super stretch hose and check for clogs in the air duct behind the dust cup. If that is not the case, to check for a clog near the roller brush lay the vacuum down. Next check the opening behind the brush roll for clogs. If there is debris, clean the opening with scissors, carefully cutting away any debris.
Uncleaned filters may also the reason why your vacuum has lost suction. To clean the foam and felt filters, remove the dust cup and pull out the two filters that are on the top of the motor base. Rinse the filters with lukewarm water until the water is running clear. Let the filters dry fully before putting them back into the vacuum. If your vacuum is still not picking up dirt, you may need to replace it.
You can purchase a wide variety of high quality Shark replacement parts for your Shark Vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
Ava B.
Dec 09, 2011 | Shark Navigator Bagless Upright Vacuum
Vacuums Logo
49 people viewed this question
Top Shark Vacuums Experts
Thomas Perkins
Thomas Perkins
Ruth summersides
Are you a Shark Vacuum Expert? Answer questions, earn points and help others
