Question about Samsung LN32B360 32 in. LCD HDTV
I have a samsung ln32flat screen LCD, trying to find the jumper to cut to stop the flickering. I know on the 46 and up its jumper jp854, my model is jw jumpers thanks in advance
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 27 Answers
There is no jumper on this model of power supply to cut. Although you can send your power supply here http://www.electronresort.com/repair-service-c-144/samsung-bn4400260b-power-supply-inverter-repair-service-p-5297.html to have it repaired if you can not find one.
Posted on Feb 05, 2014
  • 192 Answers
SOURCE: LN-T4665F 46 in. LCD- Black Line across screen
The set is under a year old and is under warranty. The LVDS cable inside these sets have a history of coming loose. The problem could be the panel. Either way, the set is the problem and needs to be looked at. This set is worked on in the home and does not need to be taken to a shop, so, you can still use it. Contact Samsung at: 1-800-SAMSUNG Hope this helps.
Posted on Jun 03, 2007
  • 197 Answers
SOURCE: Samsung 46" LCD picture dark at one side of the screen
bad panel
Posted on Jun 07, 2009
roety
  • 585 Answers
SOURCE: Heads are cut off on my LCD TV on a samsung 46
Hi my name is Eric,
I hope I can help you with your issue ,
 There are a few buttons on your remotes to push for size, on the TV remote P-size to full. fill or just, on a cable/satelitte box
# key is zoom (brighthouse) aspect/format to stretch , make sure you only have 1080i as the output resolution in cable box display settings.
unzoom it and you'll see the edges, thats all
Hope this helps, if it has solved your issue please click accept
But if you have more questions please respond and I will reply asap
Thanks
Eric
Posted on Sep 09, 2009
  • 541 Answers
SOURCE: SAMSUMG 46'' LCD TV MODEL LN46A530P1FXZA PROLEM
Check for bad capacitors in the power supply. The capacitors will be bulged on top. Typically there will be 3 or 4 caps with this problem. Thanks for using fixya.
Posted on Jan 23, 2010
eagle338
  • 4889 Answers
SOURCE: Samsung LCD 46" television model no. LNS4695D,
Are these vertical lines colored or do they look like static lines? Also are these lines present even on the no-signal screen? It sounds like an LCD controller problem but first I would like to make sure that its not the video precessing board. So please provide this info.
Posted on Jan 30, 2011
Samsung LE40R71B flickering problem
appears other people are having the same issue with Samsung TV's.
Try calling Samsung or wherever you bought it from.
I've been dealing with Samsung on this issue.
We got a 40" LCD in October 2010 and it started flickering January 2012.
Changing it from 'standard' to 'movie' helped (natural and dynamic flicker)
Then it started flickering in 'movie.'
I called Samsung and told them this issue is all over the internet. They agreed to pay for repair, parts and labor, even though it's out of warranty.
The guy just left and this is what I know. He said that in the 46" and larger, the issue is a jumper. In the 40" and, I think, smaller, it's the panel. He's ordering the panel and will be back to replace it when it comes in from the warehouse in CA.
Try calling Samsung and good luck!
Dec 28, 2013 | Samsung LE40R71B 40 in. HD-Ready LCD...
Samsung tv model LNS3241DX flickers
I'm not sure of a jumper wire to cut, but one of the first things is to clean out the dust that has accumulated on the electronics. You can blow out the back with compressed air or disassemble the TV case and dust it. Sometimes a layer of dust can cause excessive heat to build and shut off any type of overload circuit. Good luck!
Dec 18, 2013 | Samsung Flat Panel 32-inch 720p 60hz...
I have a Samsung LN46A650 LCD TV and just recently I started getting an electrical popping sound while watching the TV. When this occurs, there are 2 light white bands across the screen and then it is...
without a standby error code or maintenance mode fault detection code, it's hard to say.
if you are looking for possibilities, then start with targeting the Ysus board as a possible culprit along with the Zboard buffers. the band would lead me to think buffers are having issues.
Nov 24, 2013 | Samsung LN46A650 46 in. LCD HDTV
My Samsung LN-S4092D LCD TV is exhibiting a strobing/flickering screen occasionally. I've read that cutting the jumper cable will fix this, but I'm not sure which wire is my jumper. Does Anyone...
It could possibly be a HDMI cable that is bad. If it is hooked up that way, I have found that problem before. Not sure about the jumper cable.
Aug 15, 2013 | Televison & Video
I have a 46 inch lcd samsung flat screen. the picture will flicker.
when it flickers is it lines that go up and down or across the screen or is it flickering bewteen lighter and darker?
Aug 05, 2012 | Samsung LN46C650 46 Series 6 LCD 1080p...
Samsung picture flickers
Pull the back off the tv. Look at the power supply. Find jumper designated JP854 on power supply. Take a pair of wire snips and cut that jumper out of the circuit. Put the tv back together. That's it.
Jul 15, 2012 | Samsung LN55C630 TV
My Samsung DLP TV's pictures are flickering on the regular screen, but pictures are fine in PIP mode. How do you explain that phenom?
Set uses two tuners, one for regular and one for PIP. If normal with DVD OR SOMETHING INTO REAR INPUTS, MAIN TUNER IS PROBLEM
sd tech
Aug 21, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
Samsung LN32B360 32 in. LCD HDTV Logo
170 people viewed this question
Henry  Thomas
Henry Thomas
