Question about Car Audio & Video
Fuel-cl FA car amp - Car Audio & Video
1991 1 dodge Dakota 4 cl won't start when it's cold out but after the weathers warms up its fine. I replaced the fuel filter but don't believe that was the problem
Fuel Filter -- doesn't know or care about the temperature
Are the Spark Plugs in the motor over 3 years?
Thermostat -how old is that ?
Oxygen Sensor --over 100,000 miles,replace it
Plug Wires? How old? & dist cap
What your saying-- is when cold-- it is in open loop & won't
run until warm & in closed loop.there is some clue to what
to diagnose
Are all the vacuum hoses on according to the diagram
under the hood ?
What is the fuel pressure at the schrader valve on motor,
with & without the vacuum hose on pressure regulator?
Is the battery any good-test it
Dec 04, 2014 | 1991 Dodge Dakota
1997 Acura CL 2.3 flooding
How do you know it is flooding?
The only cause would be leaking injectors
Mail them away to one of the internet sites
for cleaning
No other type of cleaning will do a thing
They have to come out & be tested,cleaned
& flow tested & maybe a couple leakers replaced
Check fuel pressure & fuel trim first, as well as MAF
Data & check for cylinder contribution & misfires & see
if all monitors run with no issues & O2 Sensor Data is good
Feb 28, 2014 | Acura Cars & Trucks
1999 acura cl 3.0 cranks but wont start
You don't say if you work on your own car
or have experience,if not then a repair shop
You need to check for fuel pressure at the motor
& spark or injector pulse while cranking the motor
You should be asking these questions using Google
& also You Tube Video-- it's all out there in detail
Aug 11, 2013 | 1999 Acura CL
1997Acura CL fuel filter replacement
Just follow the fuel supply rail. The fuel filter is mounted down below the master cylinder near the subframe
Jul 06, 2012 | 1998 Acura CL
Comment fait on pour relacher la lumiere du changement d'huile qui allume p¸ontiac grand am 2002
Réponse
Je ne pense pas que la «pédale de gaz façon« travaille sur cette année. La bonne façon de le faire:
Tournez la clé sur ON - ne démarre pas. Appuyez sur le bouton RESET dans la boîte de fusibles du côté conducteur. Changement d'huile de lumière sur tableau de bord doit commencer à clignoter. Maintenant Maintenir enfoncé le bouton RESET jusqu'à ce que la lumière de changement d'huile s'éteint et vous ici 3-carillons. Bonne chance et merci pour votre question et j'espère que mes suggestions aider. N'oubliez pas de taux de moi.
burdfrenzy
Visitez ma Boutique eBay! http://stores.ebay.com/Pittsburgh-Joes-Pants-Nat
Jan 07, 2011 | Pontiac Grand Am Cars & Trucks
Where is the fuel Temperature sensor located on my 1998
There is no fuel heat sensor on this vehicle? possibly something else your looking for?
Apr 20, 2010 | 1998 Acura CL
Where is the fuel filter located on 1997 acura cl 2.2
Hi, Well just follow the fuel rail. its mounted down below the master cylinder near the subframe.
Thanks! mannu_rakesh
Aug 24, 2009 | 1997 Acura CL
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
