Question about Logitech Harmony 200 Universal Remote - Simple Setup, Large Buttons, R
Remote control does not turn tv on. new batteries in TV Cable DVD buttons are flashing
    Champion:
  • 226 Answers
Hi, your remote may not be programmed to the TV. Read the manual for the remote for instructions. If remote has been used a lot the remote's buttons may also be worn. Try testing your remote.
Posted on Nov 01, 2013
SOURCE: Remote will not control TV
try obtaining the factory original remote at www.remotes.com
Posted on Nov 26, 2008
  • 59 Answers
SOURCE: Should be controllng one box. is controlling 2 boxes
Unfortunately, there is no solution for this issue.  The remote control sends out an infrared signal, which can be picked up as far as 40' away from the device.  And to make things worse, the signal will reflect off any surface such as glass, mirrors, or even brightly painted walls.
The only way to solve the problem is to block the path of the beam to the other room.  This may require closing a door or drawing heavy drapes closed.
Posted on Jun 08, 2009
  • 101 Answers
SOURCE: volume control
Try this:
1. Login to your Harmony Remote Account.
2. Click on the Settings button next the Watch TV Activity.
3. Choose Review the settings for this Activity.
4. When the software asks what device are you using to control volume, please choose the TV.
5. Continue through the setup until you are brought back to the Home Screen.
6. Click on the Update remote button and follow the on screen steps.
7. Once the update is completed, please test the Watch TV Activity.
Posted on Jan 21, 2010
  • 101 Answers
SOURCE: Harmony 1000 never worked right; out of warranty
email in they will help you there. I have never been turned down by them! i have been out of warranty for about a year
Posted on Apr 20, 2010
  • 38 Answers
SOURCE: I recently bought a Logitech Harmony One universal
Great remote but not always easy to find right category for device.
Had a look for you and sure enough the device IS listed in data base under AMPLIFIER- then select amplifier again and input vizio for make and soundbar for model and click next.Problem solved!
Posted on Mar 02, 2011
Tv cable and dvd lights keep flashing and tv doesn't get signal
The remote is in safe mode, remove batteries and reinsert batteries while keeping the button 2 pressed.
Aug 04, 2012 | Logitech Harmony 200 Universal Remote -...
Tip
How to Program your Innovage Jumbo Remote Control
Would you like to program your Innovage Jumbo Universal Remote to your TV, DVD, VCR, Satellite or Cable Box?
Have you tried the Auto Search function?
To have the remote try each TV code it knows one at a time, follow these steps:
  1. Turn on your TV.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Press the ON/OFF button slowly and repeatedly untilthe TV turns off. The LED will blink once each time you press theON/OFF button.
  5. Once the TV turns off, press the ENTER button to store the code and the LED will turn off.
When searching for a TV code, the remote will try all the codes it knows for every TV brand it know. To search for a DVD or CBL code, make sure you substitute the DVD or CBL button for the TV button in the directions above, because it doesn't attempt DVD codes while in TV mode.
When programming the Innovage Jumbo Remote control for cable or satellite services such as DirectTV or Comcast, or other digital TV and service providers, make sure to auto-search through both CBL and SAT code sets to find one that will control your set top box.
I hope that helps.
on Jan 02, 2010 | Innovage Jumbo Remote Control
The remote is not working - the cable button is flashing constantly - the tv will not turn on or respond to any remote controls
I have the same problem. The suggestions about holding down buttons for 1-2 minutes without the batteries in do NOT work. Pressing the TV button does NOT work. Still no clue what does work.
Dec 08, 2010 | Samsung TV Remote Control
It does'nt turn on don't respond any comand The
I had a problem similar to this. I fixed it by toggling through the top buttons on the remote control. Sometimes the wrong button gets pressed and the remote cannotcontrol the unit it is supposed to. i.e. make sure TT320 remote has good batteries and then make sure if it has other buttons on it like TV, cable, DVD etc that the correct one is pressed to control the TT320. My TV remote would not control my TV and by chance my kids had pressed the satellite button so I had to press the cable button and then the controller startedto control the TV again.
Nov 02, 2010 | TruTech TT320
I put in new batteries and i get lights for TV Cable and DVD but not one for vhs, i also cant use the remote the lights just stay on and i cant turn channels or turn off the tv or anything help
it seems some of your remote buttons doesn't work! is it? is this remote original for your Tv or its just universal?
tell me. explain more we will help you.
Jun 25, 2010 | RCA RCU400 Remote Control
I have dish network and a new rca tv with dvd the
You can power scan for the code.
Turn ON the electronic device you want to program the remote to control.
Press the Mode button( sat,tv,dvd,aux) on the remote until the appropriate mode light is flashing.
Press the Power button. The mode light will stop flashing and stay lit.
Press the Up or Down arrow button to set the remote to the next code. The Down arrow button scans backward and the Up arrow button scans forward.
When the correct code is reached, the device (whether a TV, VCR, or other) will turn off.
Press the pound key button to store the code in the remote control memory. If the code is valid for your remote, the mode light will blink 3 times.
Turn the device back ON by pressing the Power button.
Press sat mode key once you power back on the tv to be able to operate the receiver box.
Try some other functions to make sure you have the correct code. Occasionally the Power button may work when others do not.
If the other buttons work you are finished.
If the other buttons do not work, repeat the previous steps. The scan will resume from the last code stored.
The mode light will flash rapidly when the scan has returned to the starting point and all codes have been tested for that mode. The remote control may not control some device models.
Mar 11, 2010 | DISH Network 322 DTV Receiver
JUST BOUGHT AN OPEN BOX TOSHIBA T.V. MODEL #26LV61OU LCD-HD AND IT DIDN'T HAVE A REMOTE. IT'S WORKING WITH MY VERIZON FIOS BUT I CAN'T CONTROL THE SOUND. WHAT TYPE OF REMOTE SHOULD I GET FOR THIS T.V. AND...
The remote that came with your Verizon FIOS can be programmed to control the sound on your TV. There are four different remotes can come with Verizon FIOS, and there are three different procedures to program them. I will give you all three to print out try to fix your remote control problem.
Does your remote look like either of these two?
If so you have a Philips universal remote. Here are the steps to find the code that will control the sound on your TV:
1) Turn on the device you want to program into your remote, for example if you are programming your remote to control your TV, then turn on the TV.
2) Press and hold the device button for the device you turned on in step 1 (DVD, AUX, TV, STB) and press OK. Release both buttons. The mode buttons blink twice.
3) Press 922.
4) Point the remote control toward the device you are setting up and press the upper part of the Play button.
5) Press the Fast Forward button. If the device you are setting up does not turn off, keep pressing the Fast Forward button until the device powers off. (You can use the Rewind button to go back, if necessary.)
6) When the device powers off then you've found the correct code for that device. Press OK to assign the code in your remote control.
Note:
There are over 200 possible combinations for TV and DVD codes. The most common codes are tried first but you may still need to press the Fast Forward or Rewind buttons over 200 times to find the correct code for your device.
If you reach the end of the list of codes, the entire remote flashes twice and returns to normal operation. You can exit programming at any time by pressing the Exit button.
Does your remote look like this?
If so, your have a Motorola universal remote. These are the steps to find the correct code to control your tv:
  1. Turn on the device you want to program into your remote, for example if you are programming your remote to control your TV, then turn on the TV.
  2. Note: The DVD/VCR button can control a DVD, VCR, or a combination TV/DVD, TV/VCR, or TV/DVD/VCR.
  3. Press and hold for six seconds the device button for the device you turned on in step 1 (AUDIO, DVD/VCR, TV, CABLE).
  4. The lights for each device button light up and the light for the device button you selected remains on.
  5. Press the Power button on your remote.
  6. The device button blinks three times then turns off.
  7. Press the Up arrow button (this is the button directly above the OK button, not the Page Up button).
  8. Did the device turn off?
    Yes: Congratulations! You've found the correct code for that device. Press OK to store the code in your remote control.
    No: Repeat step 3 and 4 until your device turns off, then press OK to store the code in the remote control.
    Note: To retry the previous code, press the Down arrow button (not the Page Down Arrow button).
If so, you have a Scientific-Atlanta universal remote. Here is how to find the control codes for your TV:
  2. Press and hold the Select button while also pressing the device button for the device you turned on in step 1 (AUX, DVD, VCR, TV, CBL) until the device button blinks twice.
  3. Press 991.
  4. The mode button blinks twice.
  5. Point the remote control toward the device you are setting up and press the Play button.
  6. The remote control tests each code in its library. The mode button blinks once each time the remote transmits a new code. When the last code is reached, the mode button blinks twice.
  7. When the device powers off, press the Select button.
  8. Verify the new code is correct by pressing the Power button.
    Did the device power on again?
    Yes: Press Select to assign the code in your remote control.
    No: Turn the device on and press the Channel Up or Channel Down button to step forward or back to the correct code. When the device turns off, press Select to assign the code.
___________
One of those three should work for you.
Hope that helps.
Oct 02, 2009 | One For All URC-3021 Remote Control
I have an LG 42lg30 and the user manual does not show you how to program other divices remote codes so the LG remote controls my cable box and dvd player. Does anyone know how this remote works?
go and buy a universal learning remote and you will be able to program all your devices on the remote, works very nice. as far as the lg remote, dont think there is a way where u can program your cable and dvd onto the remote and I have lots of experiences with LG
Mar 26, 2009 | LG 42LG30 42 in. LCD HDTV
I need the code for an echostar remote ir103602
How to Program a EchoStar Remote Control
Instructions
Step1
Ensure that the remote control has new batteries installed. If you are not sure or have been using the device for a while, go ahead and insert fresh batteries. You need four AAA batteries.
Step2
Locate the mode buttons on the controller. You will see SAT, AUX, TV, and VCR. SAT stands for the satellite receiver. Your remote is automatically set up to work with your EchoStar receiver, and you do not need to program it for this function. AUX may refer to a cable television device or an audio device that hooks it into your stereo system. TV refers to your television set. VCR may be chosen to control a standard VCR or a DVD player.
Step3
Press the mode button that corresponds with the device which you want to control with the EchoStar remote control. For example, if you want to program the remote to control the TV, press down the TV mode button.
Step4
Turn on the device. This is the item you want to control with the EchoStar remote. You may need to do so manually or with its own remote control. In this example, you would turn on your television set with its own control.
Step5
Press down the EchoStar mode button for the device again, but this time hold it down for three seconds. You are going to notice that all the other mode buttons are going to flash on. Aim the remote at the device you want to control.
Step6
Depress the EchoStar remote power button briefly and then slowly click either the up or the down arrow button. You are performing a code scan that allows the remote control to run through all the preprogrammed codes that are stored in its memory. Proceed slowly and do not hurry this process. It may take a few minutes, but it is virtually foolproof.
Step7
Stop when the appliance you want to control with the EchoStar remote control suddenly turns off. You have hit upon the correct code, and if you save it now, your remote will be able to use it in the future to control the functions of the item.
Step8
Store the code in the EchoStar remote control’s memory by pressing the pound button. You will notice that the corresponding mode button is going to flash, acknowledging the programming choice. You are now ready to control the item with the EchoStar remote control.
Aug 28, 2008 | Televison & Video
Remote control
Does your remote have a button called TV. Press this first and then hit the power button and the TV should turn on. Remotes these days control multiple devices like DVD players and VCRs and you need to ensure that you have selected the right mode. Hope this solves your problem.
Aug 20, 2007 | Soyo GVTL3727AB Television
Open Questions:
See all Logitech Harmony 200 Universal Remote - Simple Questions
Logitech Harmony 200 Universal Remote - Simple Setup, Large Buttons, R Logo
81 people viewed this question
Top Logitech Televison & Video Experts
Greg Ulan
syspro
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
