Question about Canon imageRUNNER 2200
After replacing the fuser fixing films on a canon ir 2318 so many times,when i replaced a fixing film,it displayed e0000007 error after four days
YBQ-TECH
SOURCE: E007ON IR2016(FUSER FILM OFF TRACK AND WILL NOT REPAIR ITSELF)
oh.....
the fuser film sleeve of IR 2016 and IR2200 are the same size.
please check the other reasons...
Posted on Dec 17, 2008
  • 122 Answers
SOURCE: Canon Ir2200 Error E007 I have replaced the fixing
take out fixing unit, drive it manually if fixing film do not rotate- apply some mixture of teflon grease and silicon oil on heater element. if fixing film rotating normally,check fixing drive unit.
Posted on Feb 16, 2011
  • 122 Answers
SOURCE: I change fixing film still
you may have forgotten to tight connector screw of heating element.check it if it is ok then check the continuity of heater element with multimeter, if it is not showing continuity replace it.
Posted on Mar 02, 2011
SOURCE: Sir I have Canon IR
Sir I have canon 2870 machine. The machine giving the finisher problems, when starting the finisher going down. The machine showing the problem E540. Please kindly solve
Posted on Jun 09, 2011
SOURCE: i have System error E007 problem in my Canon iR-2016 copier machine
system error
Posted on Jan 07, 2012
CAnon xerox Machine IR 2318 L Error code : E 000007-0000 solve my problem
E007-0000 Description Fixing film sensor failure
The fixing film sensor is faulty. Remedy - Check the connector of the fixing film sensor. - Replace the fixing film sensor. - Replace the DC controller PCB.
Jan 31, 2015 | Canon Office Equipment & Supplies
Error ( E000100-0000 ) canon 2318
IN MOST CASES ERROR E007 IS DISPLAYED WHEN THE OPTOMETRIC SENSOR ON THE FIXING UNIT CANNOT SENSE THE THE ROTATION OF THE FIXING FILM WHICH AT MOST TIMES IS CAUSED BY TORN FIXING FILM SIMPLY CHECK AND REPLACE BUT CONTACT YOUR SERVICE TECHNICIAN TO AVOID DAMAGING THE ENTIRE UNIT
Jan 19, 2014 | Canon imageRUNNER 5570 Copier
CAnon xerox Machine IR 2318 ERROR CODE E000007-0000 SOLUTION
open fixing unit & replace fuser film.......................................
Feb 03, 2013 | Office Equipment & Supplies
Canon copier ir 2016 system error E007
i have canon ir2016 photocopier machine and its given me system error, and the error code is E007. i now when its happen so, its the fuser film that is worn out. i change the fuser and fix a new one but still the error is there. what should i do next to clear the error?
May 12, 2011 | Canon iR 2016i Black and White Copier
My canon ir 2318L shows error**E000007-0000 how can i solve this problem
Feb 28, 2011 | Office Equipment & Supplies
Display shows "system Error E007"
This is a error on the fuser unit (E007 Fixing film rotation error).
The fixing film sensor is faulty. - Check the connector of the fixing film
sensor.
Normally you must change the fuser to resolve it.
Bye
Feb 18, 2011 | Canon iR 2016i Black and White Copier
Hi guru, my canon ir4570 had E000110-0001, should I replace the laser unit? and sometimes when copier is ready to scan, immediately had error E0000007-0000 and the paper position is jamm under the fixing,...
code 110 is for laser polygon motor you should replace the unit. for problem 007- check fixing film if it is ok then open the unit and take out fuser film apply mixture of some white grease and fuser oil(silicon oil) and put back the film and unit.hope this helps you.
Jan 24, 2011 | Office Equipment & Supplies
Canon imageRUNNER 2200 Logo
old marine
old marine
