Question about Canon PIXMA Office Equipment & Supplies
CODE 2.114.0 - PIXMA Canon Office Equipment & Supplies
Where do I find my link code
Link code for which service provider? See below:
CableVision UR2-CBL-CV04 code: 096
Charter DIGITAL code: 0463
Comcast M1057 code: 0463, 10463
Cox COX code: 0463
Direct TV RC23 code: 10463
Dish Network VIP508 code: 720
Dish Network VIP622 code: 720
Motorola DRC800 code: 0463
One for All URC-6690 code: 0464
Phillips PDVR8 code: 115
Phillips PH5DSS code: 115
Phillips PHDVD5 code: 115
Phillips PMDVR8 code: 115
RCA RCU807 code: 135
Rogers DCT3250 code: 0463
Shaw DCT3416 code: 0463
Sony RM-VL600 code: 8043
TiVo HD code: 0091
TiVo SERIES 3 code: 0091
Oct 13, 2015 | Proscan 26LB30QD 26 in. LCD HDTV
COD ERROR 2,114
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken . Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or poor ink cartridge contacts. Sometimes the power supply unit must be checked as a poor SMPS unit can deliver low voltage and cause issues to the printer function. Check all the leads and connections of the mother board , the tags to the ink cartridge. Also check the mechanical settings of the ink cartridge , if jammed or tight remove motor and manually free the drive before it is set back.
Jul 13, 2011 | Canon PIXMA MP160 All-In-One InkJet...
Remote code for 26" LCD Dynex tv
Remote code for who? Dish network? Comcast?
Cox COX code: 0463
TiVo HD code: 0091
Jun 06, 2011 | Dynex DX-L26-10A 26 in. HD-Ready LCD TV
I need to flash my phone
You can unlock any blackberry from any network & after unlocking you can use your blackberry with any GSM provider around the world by just entering one time blackberry which is comes from server, based on IMEI & unique code for every blackberry set. Also unlock any CDMA blackberry using MEID
Unlock 8100 Blackberry IMEI MEP Code
Unlock 8220 Blackberry IMEI MEP Code
Unlock 8230 Blackberry IMEI MEP Code
Unlock 8300 Blackberry IMEI MEP Code
Unlock 8310 Blackberry IMEI MEP Code
Unlock Curve 8320 Blackberry IMEI MEP Code
Unlock 8350 Blackberry IMEI MEP Code
Unlock 8500 Blackberry IMEI MEP Code
Unlock 8520 Blackberry IMEI MEP Code
Unlock 8700 Blackberry IMEI MEP Code
Unlock 8800 Blackberry IMEI MEP Code
Unlock 8810 Blackberry IMEI MEP Code
Unlock 8820 Blackberry IMEI MEP Code
Unlock 8830 Blackberry IMEI MEP Code
Unlock Curve 8900 Blackberry IMEI MEP Code
Unlock Bold 9000 Blackberry IMEI MEP Code
Unlock 9100 Blackberry IMEI MEP Code
Unlock 9300 Blackberry IMEI MEP Code
Unlock 9500 Blackberry IMEI MEP Code
Unlock 9520 Blackberry IMEI MEP Code
Unlock Storm 9530 Blackberry IMEI MEP Code
Unlock Storm2 9550 Blackberry IMEI MEP Code
Unlock 9600 Blackberry IMEI MEP Code
Unlock Tour 9630 Blackberry IMEI MEP Code
Unlock 9650 Blackberry IMEI MEP Code
Unlock Bold 9700 Blackberry IMEI MEP Code
Unlock Torch 9800 Blackberry IMEI MEP Code
Unlock 9900 Blackberry IMEI MEP Code
Unlock Gemini Blackberry IMEI MEP Code
Unlock Javelin Blackberry IMEI MEP Code
Unlock Niagara Blackberry IMEI MEP Code
Unlock Thunder Blackberry IMEI MEP Code
Unlock AtT&T Blackberry IMEI MEP Code
Unlock movistar Blackberry IMEI MEP Code
Unlock T-Mobile Blackberry IMEI MEP Code
Unlock Verizon Blackberry IMEI MEP Code
Unlock Vodafone Blackberry IMEI MEP Code
Unlock Etisalat Blackberry IMEI MEP Code
Unlock Orange Blackberry IMEI MEP Code
Unlock O2 Blackberry IMEI MEP Code
Unlock Cingular Blackberry IMEI MEP Code
Unlock Bell Blackberry IMEI MEP Code
Unlock Fido Blackberry IMEI MEP Code
Unlock Virgin Blackberry IMEI MEP Code
Unlock TELUS Blackberry IMEI MEP Code
Unlock Rogers Blackberry IMEI MEP Code
Unlock Digicel Blackberry IMEI MEP Code
Unlock Cable & Wireless Blackberry IMEI MEP Code
Unlock Telcel Blackberry IMEI MEP Code
Unlock Comcel Blackberry IMEI MEP Code
Unlock Airtel Blackberry IMEI MEP Code
Unlock 3 Hutchison Blackberry IMEI MEP Code
Unlock Claro Blackberry IMEI MEP Code
Unlock Globalstar Blackberry IMEI MEP Code
Unlock Tele2 Blackberry IMEI MEP Code
Unlock Zain Blackberry IMEI MEP Code
Unlock Sprint Blackberry IMEI MEP Code
Oct 18, 2010 | RIM BlackBerry Curve 8520 Smartphone
Displaying error E and 5 (In Blinking) and error code 2,114 while scanning........help me out of this...........thanx
The e2 error os no paper, e5 is improperly or damaged ink carts, as is the e14 error code. Make sure that there is plently of fresh paper, and replace the carts with new canon carts. If you are using refilled carts in this machine, the failure rate of this series of carts is nearly 60%. Last step to try would be to unplug the printer from power and let sit for at least 10 minutes, plug back in and power up.
Sep 29, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Hi I need PHILIPS P568 IMEI 351265412565412 unlocking codes.... please help me.
Codes for imei 351265412565412, model Philips P568 Unlocking codes: Code for NCKKN is : **00012*39094694# Code for NSCKN is : **00022*35077294# Code for SPCKS is : **00032*36089094# Code for CKCCK is : **00042*37037294# Code for PCKKP is : **00052*33054694# Code for XXXXX is : **00062*37035294# Code for XXXXX is : **00072*33775294#
Repair codes: Code for NCKKN is : **00013*43714762# Code for NSCKN is : **00023*43070742# Code for SPCKS is : **00033*43251752# Code for CKCCK is : **00043*43072702# Code for PCKKP is : **00053*43718722# Code for XXXXX is : **00063*43872702# Code for XXXXX is : **00073*43878442#
New Algo Codes Unlocking codes: Code for NCKKN is : **00012*7563374371217567# Code for NSCKN is : **00022*7161634379412367# Code for SPCKS is : **00032*7262814378202967# Code for CKCCK is : **00042*7367634371472367# Code for PCKKP is : **00052*7969374375277567# Code for XXXXX is : **00062*7367434371470367# Code for XXXXX is : **00072*7931434377110367#
Repair codes: Code for NCKKN is : **00013*2159969789537257# Code for NSCKN is : **00023*2185567789015457# Code for SPCKS is : **00033*2103668789074247# Code for CKCCK is : **00043*2185763789017417# Code for PCKKP is : **00053*2159365789531217# Code for XXXXX is : **00063*2165763789817417# Code for XXXXX is : **00073*2165337789813157#
May 17, 2010 | Belkin Cameras
QUIERO SABER CUAL ES EL CODIGO PARA UNA TELEVISION SHARP SP
aver si te ayuda esto
Code 000 for RCA TV Code 003 for RCA TV Code 004 for RCA TV Code 005 for RCA TV Code 006 for RCA TV Code 007 for RCA TV Code 019 for RCA TV Code 054 for RCA TV Code 055 for RCA TV Code 082 for RCA TV Code 096 for RCA TV Code 098 for RCA TV Code 099 for RCA TV Code 100 for RCA TV Code 101 for RCA TV Code 102 for RCA TV Code 103 for RCA TV Code 129 for RCA TV Code 179 for RCA TV Code 181 for RCA TV Code 188 for RCA TV Code 190 for RCA TV Code 196 for RCA TV Code 202 for RCA TV Code 203 for RCA TV Code 212 for RCA TV Code 215 for RCA TV Code 233 for RCA TV Code 281 for RCA TV Code 352 for RCA TV
estos son los codigos
May 05, 2010 | RCA RCU600M Remote Control
How to get free GTA SanAndreas CHEAT CODES?
here are all the cheat codes
Adrenaline Mode
Cheat code: MUNASEF Aggressive Drivers
Cheat code: YLTEICZ All Cars Explode
Cheat code: allcarsgoboom All Cars Have Nitro
Cheat code: COXEFGU or SPEEDFREAK All Green Lights
Cheat code: ZEIIVG Always Midnight
Cheat code: NIGHTPROWLER or XJVSNAJ Beach Party
Cheat code: CIKGCGX Black Traffic
Cheat code: IOWDLAC Blow Up All Cars
Cheat code: CPKTNWT Boats Fly
Cheat code: AFSNMSMW or FLYINGFISH Cars Float Away When Hit
Cheat code: BSXSGGC or BUBBLECARS Cars Fly
Cheat code: RIPAZHA Chaos Mode
Cheat code: STATEOFEMERGENCY Clear Wanted Level
Cheat code: ASNAEB Country Vehicles and Peds, Get Born 2 Truck Outfit
Cheat code: BMTPWHR Elvis is Everywhere
Cheat code: ASBHGRB or BLUESUEDESHOES Everyone is Armed
Cheat code: FOOOXFT Faster Clock
Cheat code: YSOHNUL Faster Gameplay
Cheat code: PPGWJHT or SPEEDITUP Fat
Cheat code: BTCDBCB Foggy Weather
Cheat code: CFVFGMJ Full Weapon Aiming While Driving
Cheat code: OUIQDMW Funhouse Theme
Cheat code: CRAZYTOWN or PRIEBJ Gang Members Everywhere
Cheat code: MROEMZH or ONLYHOMIESALLOWED Gangs Control the Streets
Cheat code: BIFBUZZ or MROEMZH Have a Bounty on Your Head
Cheat code: BAGOWPG Have Jetpack
Cheat code: ROCKETMAN or YECGAA Have Parachute
Cheat code: AIYPWZQP Health, Armor, $250k
Cheat code: HESOYAM Hitman In All Weapon Stats
Cheat code: NCSGDAG or PROFESSIONALKILLER Huge Bunny Hop
Cheat code: CJPHONEHOME or JHJOECW Increase Wanted Level Two Stars
Cheat code: OSRBLHH Infinite Ammo, No Reload
Cheat code: FULLCLIP or WANRLTW Infinite Health, Except for Explosions and Falls
Cheat code: CAINEMVHZC Infinite Oxygen
Cheat code: CVWKXAM Invisible Car
Cheat code: WHEELSONLYPLEASE or XICWMD Large Health Boost
Cheat code: BAGUVIX Max All Vehicle Skill Stats
Cheat code: NATURALTALENT Max Muscle
Cheat code: BUFFMEUP or JYSDSOD Max Respect
Cheat code: OGXSDAG or WORSHIPME Max *** Appeal
Cheat code: EHIBXQS or HELLOLADIES Mega Jump
Cheat code: KANGAROO or LFGMHAL Mega Punch
Cheat code: IAVENJQ or STINGLIKEABEE Never Get Hungry
Cheat code: AEDUWNV Never Wanted
Cheat code: AEZAKMI or IFIRSTDOZ Ninja Theme
Cheat code: AFPHULTL or NINJATOWN No Wanted Level
Cheat code: TESTEDUCATIONALSKILLS Orange Sky 21:00
Cheat code: OFVIAC Overcast Weather
Cheat code: ALNSFMZO Peds Attack Each Other, Get Golf Club
Cheat code: AJLOJYQY Peds Attack You With Weapons, Rocket Launcher
Cheat code: BGLUAWML Perfect Handling
Cheat code: PGGOMOY or STICKLIKEGLUE Pink Traffic
Cheat code: LLQPFBN Rainy Weather
Cheat code: AUIFRVQS Recruit Anyone - 9mm
Cheat code: SJMAHPE Recruit Anyone - Rockets
Cheat code: ROCKETMAYHEM or ZSOXFSQ Reduced Traffic
Cheat code: GHOSTTOWN or THGLOJ Riot Mode
Cheat code: IOJUFZN Sandstorm
Cheat code: CWJXUOC Six Star Wanted Level
Cheat code: BRINGITON or LJSPQK Skinny
Cheat code: KVGYZQK Slower Gameplay
Cheat code: LIYOAAY or SLOWITDOWN **** Magnet
Cheat code: BEKKNQV Smash n' Boom
Cheat code: JCNRUAD Spawn Bloodring Banger
Cheat code: CQZIJMB Spawn Caddy
Cheat code: RZHSUEW Spawn Dozer
Cheat code: EEGCYXT Spawn Dozer
Cheat code: ITSALLBULL Spawn Hunter
Cheat code: OHDUDE or OHDUDE Spawn Hydra
Cheat code: JUMPJET or JUMPJET Spawn Monster
Cheat code: AGBDLCID or MONSTERMASH Spawn Quad
Cheat code: AKJJYGLC or FOURWHEELFUN Spawn Racecar
Cheat code: PDNEJOH or VPJTQWV or VROCKPOKEY Spawn Rancher
Cheat code: JQNTDMH Spawn Rhino
Cheat code: AIWPRTON Spawn Romero
Cheat code: AQTBCODX or WHERESTHEFUNERAL Spawn Stretch
Cheat code: CELEBRITYSTATUS or KRIJEBR Spawn Stunt Plane
Cheat code: FLYINGTOSTUNT or URKQSRK Spawn Tanker Truck
Cheat code: AMOMHRER Spawn Trashmaster
Cheat code: TRUEGRIME or UBHYZHQ Spawn Vortex Hovercraft
Cheat code: KGGGDKP Suicide
Cheat code: GOODBYECRUELWORLD or SZCMAWO Sunny Weather
Cheat code: AFZLLQLL or PLEASANTLYWARM Taxis Have Nitrous, L3 Bunny Hop
Cheat code: VKYPQCF Thunderstorm
Cheat code: MGHXYRM or SCOTTISHSUMMER Traffic is Cheap Cars
Cheat code: BGKGTJH or EVERYONEISPOOR Traffic is Country Vehicles
Cheat code: FVTMNBZ Traffic is Fast Cars
Cheat code: EVERYONEISRICH or GUSNHDE Very Sunny Weather
Cheat code: ICIKPYH or TOODAMNHOT Weapon Set 1, Thug's Tools
Cheat code: LXGIWYL Weapon Set 2, Professional Tools
Cheat code: KJKSZPJ or PROFESSIONALSKIT Weapon Set 3, Nutter Tools
Cheat code: UZUMYMW
May 02, 2010 | Rockstar Games Grand Theft Auto: San...
Need code for phillips big screen lost manual for jumbo remote
Code 002 for Philips TV Code 003 for Philips TV Code 004 for Philips TV Code 008 for Philips TV Code 012 for Philips TV Code 019 for Philips TV Code 062 for Philips TV Code 068 for Philips TV Code 069 for Philips TV Code 075 for Philips TV Code 076 for Philips TV Code 086 for Philips TV Code 087 for Philips TV Code 088 for Philips TV Code 130 for Philips TV Code 132 for Philips TV Code 134 for Philips TV Code 167 for Philips TV Code 183 for Philips TV Code 196 for Philips TV
Jul 12, 2009 | RCA RCU600M Remote Control
35 people viewed this question
old marine
old marine
