Question about HP Computers & Internet
Water damage lcd screen
Water stopped my hp mini 110 - the LCD is not working - when I attach it another monitor the laptop is works fine, but the lcd not
  • 69 Answers
You can either source a new LCD from ebay or a parts website or you can buy a new laptop. Repairing/Replacing the LCD will take about 1-3 hours depending on what you know about computers. Purchasing a new one is a much easier route.
Posted on Oct 31, 2014
harvester3
  • 181 Answers
SOURCE: Blank LCD Screen
Well, sounds like a couple of things if an external monitor works. First, toggle a couple of times between lcd and external just to make sure that it's not set to external only.
If that's no help, look closely at the lcd while the operating system is running. Can you see any image at all? If so (or if not) you have a bad inverter (we have them at the shop for around 25.00). The other possibilities are a bad backlight (which means a new lcd, about 75.00) or it's possible the lcd cable has simply came loose from it's socket.
That's about all it could be on these models if you're getting an external image. I'm using a T30 right now. They tend to have bad memory slots, but great machines.
Good luck
Posted on Nov 26, 2007
SOURCE: laptop screen in complete darkness but external monitor works fine
I have a problem with my hp laptop monitor's hinges, could you link where you were able to purchase those hinges?
Also, make sure you monitor's ribbon cable isn't missing any wires or that all of those wires are fully contacting.
Posted on Jan 16, 2008
IB4G2008
  • 3587 Answers
SOURCE: water stain in my LCD screen
gotta take it all the way apart, which is not that tough, but does take a large amount of patience. What type of laptop you got there?
got backup?
Posted on Feb 12, 2008
  • 4 Answers
SOURCE: Dell Inspiron 1000 laptop LCD screen blackout
I HAVE POSTED THE SOLUTION FOR THIS BEFORE. ON THE LEFT REAR THE SCREW FROM BOTTOM OF UNIT TO THE LCD. LOOK INSIDE WHERE THE TOP AND BOTTOM GO TOGETHER YOU WILL SEE A PIECE OF ALUMINUM TAPE IF IT STICKS OUT PAST THE BOSS TOWARD THE PC BOARD. WHEN YOU MOVE LCD THERE IS ENOUGH FLEX FOR IT TO SHORT TO PC BOARD. TRIM THIS OFF AND YOUR PROBLEMS WILL BE SOLVED. CAUTION REMOVE BATTERY AND UNPLUG FROM AC BEFORE THE ABOVE. BOBBY
Posted on Jan 09, 2009
  • 57 Answers
SOURCE: HP DV1000 screen too dim
The 4 most common problems with dim lcd's on a laptop are boken screens, bad power inverter, bad florescent bulbs or a broken cable.
You can test the power inverter with a meter.
There should be 2 bulbs. If your screen is dim and your inverter is good and you can still make out what is on the screen, you probably have a bad bulb. If you can't determine which bulb is bad you'll have to replace both.
In my opinion, the easiest way to handle this is to replace the whole screen. Yes, it's more exspensive, but consider that it is most likely to fix your problem. A replacement screen comes with the power inverter, both bulbs, and the cable; already assembled and ready to install.
Posted on Mar 06, 2010
Hp mini 110 screen fliclers if cursor moved to top of screen
Video drivers ? Reinstall them ? Does same thing happens on external monitor ?
Nov 20, 2012 | HP Mini 110-1037NR Netbook
Dropped my laptop now 1 half of my screen is white and the other half is fine
Hardware damage
1) Laptop OFF, monitor OFF, connect a VGA monitor to the VGA port on the netbook.
The VGA port is on the Left Rear side.
This is an example of a VGA Cable, and VGA connector,
http://en.wikipedia.org/wiki/VGA_connector
Scroll down a little for the VGA Cable example.
NOTE* Color does Not matter. Usually it is Blue. Can be Black or White in color.
You can use a CRT type of monitor, (Looks like a small TV), or a flat LCD screen monitor if it has a VGA cable.
2) Turn the monitor on. If a CRT type of monitor allow it to warm up.
Turn the laptop on.
By factory default the display should show on the external monitor.
However there are at LEAST 3 display options available;
A) Internal monitor of laptop ONLY
B) Internal monitor of laptop AND external VGA monitor
C) External VGA monitor ONLY
Press, and hold down on the Fn key, (Bottom left corner of Keyboard), and at the SAME time tap once on the F4 key.
(The F4 key is the Display Toggle-Over key)
No display on external VGA monitor?
Hold the Fn key down again, and tap once more on the F4 key.
Display good on the external monitor? Fine. Your graphics chipset is good. Problem lays within the Display Assembly, (LCD screen, Display Cover, etc), or the Video Cable.
Also posted in case you do not repair the netbook, or repair is set for a later date. This way you can at least use the netbook at home.
Remove ALL power. Remove the AC adapter (Charger), and Battery.
Video Cable:
The video cable attaches to the motherboard, in the upper left area near the left Hinge.
It then leads under the left Hinge, and up into the Display Assembly.
(LCD screen/ Display Cover, Display Bezel, etc. is the Display Assembly)
From there it connects to the back of the LCD screen.
(The Mini 110-3135dx has LED backlighting, and does not use a screen Inverter )
Just due to normal opening, and closing of the laptop, the Display Panel Cable, (HP for Video Cable), can be pulled on.
This means the connection of the Display Panel Cable, at the motherboard side could have been pulled loose, or at the LCD screen side.
It can also damage the tiny wires inside the Display Panel Cable.
From your description, it sounds like the Display Assembly was open, when it landed.
Display Panel Cable connections should be PHYSICALLY, plugged in to ensure the connections are tight.
A visual examination will NOT do.
Connection on the motherboard side AND -> LCD screen side.
If there is visual signs of damage to the Display Panel cable's sheath, also suspect damage to the tiny wires inside the Display Panel Cable. (Stretched/Broken)
Check the connections first. You can leave the laptop partially disassembled, and check, before putting it back together.
If physically checking, by trying to plug the two connections of the cable in, does no good, you have to suspect if the Display Panel Cable may be damaged.
A continuity check with a multimeter set to OHMs, and checking each wire in the cable, is the next step of the diagnosis.
You can take the cable down to the nearest 'Mom and Pop' computer store, and have the tech check it for a few dollars.
Or due to the price of a replacement you may just wish to replace, and see if that was the problem.
The HP part number is HP 607755-001.
HOWEVER, this is supposed to be for a kit that contains 3 cables.
1) LCD Cable (Display Panel Cable)
2) Webcam Cable
3) Power Cable.
[ Power Cable:
The DC Power Jack is the jack on the laptop, that you plug the AC adapter ( Charger ), into.
The DC Power Jack is NOT soldered to the motherboard, with this model.
Instead it is soldered to a cable of wires, and the wires end in a plug.
The plug is unplugged from the motherboard, and the entire assembly is replaced as a unit. (It's a Power Jack Harness, really)
DC Power Jacks get broken. This one will be easy to replace ]
http://www.aliexpress.com/store/product/LCD-video-Cable-for-HP-Mini-110-110-1000-110-1100-Laptop-LCD-Cable-6017B0207601-6017B0232102/908032_556440323.html
Check the part number on your Display Panel Cable, and see if it matches up to the one you are going to buy, is the best method however.
Display Panel Cable checks out OK, or you have replaced it, and it doesn't solve the problem, the problem is the LCD screen.
Again, in my searching of the LCD screen replacements, I found they all use LED lighting for your model. (Mini 110-3135dx)
LED backlighting as a rule now, does Not use a screen Inverter.
Could I be wrong, and your laptop does indeed have a screen Inverter?
Only you will know once you open the Display Assembly, and check the Display Panel Cable connection at the back of the LCD screen.
If a screen Inverter is used it will be in the Display Assembly.
A screen Inverter could easily have been damaged in a fall, and a bad screen Inverter COULD show the results you stated.
I say -> COULD.
I believe the Display Panel Cable connection may be loose at the motherboard side, and/or LCD screen side, or it may be damaged.
If not I believe the LCD screen is the problem.
To check the Display Panel Cable on the motherboard side, for this model, you have to remove the Top Cover. (HP for Palm Rest Cover)
This means the Static sensitive hardware components for the laptop, will be exposed.
This means you NEED to wear an ESD wrist strap, once the Top Cover is removed.
BEST method however is to just put it on BEFORE starting to disassemble. This way you do not forget, and have a Static shocked laptop, that is only going to be good enough for a DOORSTOP.
One example,
http://www.radioshack.com/product/index.jsp?productId=2103245
The alligator clip needs to be connected to a good ground source.
I connect to an unpainted surface, of the metal frame of an open, empty desktop computer case.
You can also set a large metal serving tray (Unpainted), on the table you're working on, and connect to it.
Or a large metal knickknack. (Unpainted)
Pictorial guide that may help. Allows you to see someone working on an HP Mini,
http://www.insidemylaptop.com/replace-keyboard-in-hp-mini-1033cl-notebook/
Service Manual from HP Support (Free),
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&lc=en&product=4307901&
In the list click on -
HP Mini 110 and Compaq Mini CQ10 - Maintenance and Service Guide
[ Note*
On page 65 it shows the Wireless LAN cables.
Number 6 states,
"Disconnect the display panel cable from the motherboard"
It is actually referring to the Figure on the next page. Page 66.
And Number 1 ]
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 23, 2012 | HEWLETT-PACKARD HP Mini-Notebook...
2/3 of display is black
Strange could be video card issue or broken screen. try connecting it to TV or another monitor see if the picture is clear than video card is fine and display is damaged
Mar 02, 2011 | HP Mini 1000 Netbook
I have a Dell Inspiron Mini. When i turn it on the desktop wont show. All i get is a black screen.
This might be a sign of a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp.
Test with an external monitor attached to the laptop. If you get display on the external monitor, then this confirms the case.
Aug 22, 2010 | Dell Inspiron Mini 10 Notebook
The screen on my hp mini 110 went white
A white LCD screen can be caused by (likeliness):
1. Loose connection between the video cable and the LCD screen.
2. Defective LCD screen.
3. Defective motherboard.
A local computer repair store should be able to fix this for you.
Jun 25, 2010 | HP Mini 110-1037NR Netbook
I have a fine horizontal line running 2/3rd's of my hp mini note book.should i be concerned?
This could be a hardware issue with the LCD screen of display card. To confirm the same, connect an external monitor and check if the same line appears on external monitor. If external mitor works fine, then its a LCD defect. If you have same issue on both LCD and External monitor, then it could be due to display card. In either cases you may need to take to service center.
May 22, 2010 | HP Mini 1000 Netbook
My Pres C300 laptop works fine with an attached monitor. But its own LCD screen is currently having 3 equal horizontal sections. First (top) section is normal, second flickers and is normal when pressed,...
Since the laptop works fine with an attached monitor, it means the problem is the inverter.
The problem with your laptop screen is that the inverter is malfunctioning, that is why you have those three equal horizontal sections.
Change the inverter of your laptop screen and you will see that the screen will be stable back.
Take care.
Apr 27, 2010 | HP 435768-001 - Compaq Presario C300...
Hp pavilion dv4 screen will not work. everything
Few trouble shoot solution when it comes to these HP Laptop from 08-09.
1). Remove battery and ram. Plug in AC Adapter and insert only ONE RAM into a slot. Boot up and see if this will turn on display (it work on a HP Dv4-1225dx) IF it works then shut down and re insert the two ram and should be good to go :)
2). If your tech savvy remove keyboard and gain access to LCD flex ribbon cable to check if cable is loose (or go on a limb and replace the lcd flex cable ). I would detach it and re attach the ribbon back to motherboard. ( This happen sometimes by chance)
3). Your LCD is shot dead so it will need to be replaced. Current used LCD can range from $40-$50 and new ones with warranty $60-$100. HP is set up for easy LCD removal so shouldn't take more then 30mins to replace, just be careful when handling the ribbon and inverter cables.
GOOD LUCK
(Fix many HP Laptop for friends and family)
Apr 04, 2010 | HP Computers & Internet
Gateway flat LCD dead
I'm not sure if your referring to the lcd monitor (gateway brand) or a laptop's lcd screen not working anymore.
1. if it's an lcd monitor...
a. test monitor in a different pc before assuming the problem is the lcd screen
b. replace the monitor if after testing monitor is in deed the item failing.
2. if it's the lcd screen from your gateway laptop.
a. you may be able to attach a regular analog monitor to the paralel port on your gateway.. test and see if the monitor that you attach will give you a picture (you may have to toggle with some some keys on your laptop keyboard to make have the signal going to the "externa" or attached monitor.
if the other monitor does not work either.. you video controller on your motherboard on your laptop may be failing and you may not have other options that to replace your laptop.
b. if the external/attached monitor works.. very likely the problem is the lcd screen for that you need to get a replacement and you may have to contact gateway to find out about pricing (or places to send your laptop for service if you're still within warranty). if you have an old laptop you may have to considere simply replacing the unit as buying a new lcd screen may very likely be more expensive than the same working laptop.
Oct 02, 2008 | Computers & Internet
Computers & Internet Logo
41 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
