Question about Siemens Washing Machines
Siemens ultra sense front loader keeps reading E04
2 Suggested Answers
  • 6277 Answers
SOURCE: Change door swing on a Siemens front load ultra
I suspect that if the door's position/swing was interchangeable it would not only be mentioned in the manual but it would be a strong selling point!
The problem is that the holes for the hinges, the door catches, the electronics/electrics for the door solenoid and close sensors need to be available already on the other side. On top of those requirements the door needs to be the same internal shape upside down, as it would be upside down if swapped over to the other side, if you see what I mean.
So sorry, all in all it doesn't look good, does it ;-0(
If this has clarified the situation for you please score accordingly.
Thanks and good luck!
John C
Posted on Apr 13, 2011
My Siemens XLI 1240 is making banging noise and moving on spin cycle. I've checked its level.
top loader ( not mentioned if top or front loader) the support rods air dampeners are shot that support the tub
Replace with new ones
get from service agent spares
Feb 20, 2018 | Siemens Washing Machines
How do I change the language setting on the Siemens S16-74 Front Loader back to English?
If you can identify the current language setting, you can try an on-line translator of the menu items to determine which one is for language settings.
Alternatively, you can download the user manual for your appliance and look up the language change procedure there. The menu items are almost certainly arranged in the same order in any language, so it would be a matter of keeping track of where you are in the process.
http://www.siemens-home.bsh-group.com/uk/customer-service/user-manuals
Oct 19, 2017 | Siemens Cell Phones
What is error code e04 bosch front loader washer
The "E04" error code on your Bosch washer refers to a drainage problem as you may or may not already know. ( it can mean door lock error, but that is usually a by-product of it not draining )
What you may have is either a partially clogged pump, or a faulty pump...the later being the least likely
Nov 22, 2016 | Bosch Washing Machines
My siemens washer front loader is displaying an E04 what does that mean
Drain is blocked - unplug the auxillary drain plug and check for clog.
Mar 21, 2014 | Siemens WXL142 Front Load Washer
Getting a E04 error code
According to siemens website Laundry appliances use many different codes depending upon age and origin. Faults that can be dealt with by the user are normally listed in the instruction book. Link to instruction manual download Flashing LEDs or displays frequently indicate door not closed, low water pressure or a blockage in the drain pump, drain hose or your drainage system.
Dec 09, 2013 | Siemens WFXD5200UC Front Load Washer
We get the error code eo4 on our Bosch front loader, and it does not spin.
Hi, "E04" means the "suds or pump is blocked"
Bosch E04 Solution:
  1. Get some towels and if possible a wet/dry vac. If the machine drained, it won't be too bad. If your machine is stuck full of water, I can't say! I'd guess you could get wet.
  2. Locate the round door on the front of the machine (about 6" in diameter, lower right corner)
  3. Find a drill bit or small screwdriver that fits in the hole in the round door.
  4. Insert the bit into the hole in the door. It will push in a tab, it doesn't take much force. Rotate the hole to 6'oclock and it should come free.
  5. Once the door out of the way you'll be greeted by a 3-4" plastic cap with wings so you can unscrew it by hands. There is a small collector lip at the bottom of the cap, that is where I held my wet/dry vac to catch the water. Unscrew slowly so you don't get flooded. Take your time and keep unscrewing it until it is free.
  6. Pull out the trap that you just unscrewed and you'll most likely see the item that caused the E04 error code. There is an side of the trap that is marked that it needs to be installed facing downward, so watch for that when you put it back in.
  7. Read these direction upside down and backwards to put it all back together.
  8. Run a load and watch for leaks. You could leave the door off until you are sure you screwed the cap in tight enough.
Jun 23, 2011 | Bosch Nexxt Premium WFMC6400UC Front Load...
Change door swing on a Siemens front load ultra sense
John C
Apr 13, 2011 | Siemens WFXD5200UC Front Load Washer
I have a siemens front loading washing mashing, the door will not unlock and there is an error code E 04 is this something I can fix or do I need to call for service?
This machine is most likely a the E04 error, which means the pump is blocked.
if in fact its a bosch you will find this should fix the error.
Bosch E04 Solution:
  4. Insert the bit into the hole in the door. It will push in a tab, it doesn't take much force. Rotate the hole (clockwise) to 6'oclock and it should come free.
  5. Once the door is out of the way you'll be greeted by a 3-4" plastic cap with wings so you can unscrew it by hand. There is a small collector lip at the bottom of the cap, that is where I held my wet/dry vac to catch the water. Unscrew slowly so you don't get flooded. Take your time and keep unscrewing it until it is free.
  7. Read these directions upside down and backwards to put it all back together.
Dec 31, 2010 | Washing Machines
Siemens XLP 1400 stops with F12
The manual says that it means there's water in the base pan because the apliance is leaking and you should callCustomer Service.
I cleaned the filter and then put the machine onto its Empty cycle. After that it worked.
Oct 19, 2008 | Siemens WXLP1460 Front Load
Water Does Not Drain
You may need to Clean out the pump catch to do this you need to remove the drain pump access cover, insert a pointed object (or tool) into the hole, Bottom right front of the unit push in to release the latch and rotate the cover clockwise.
you will need to clean this out use a shop vac to remove the water in the unit or have plenty towels handy
AS far as the fault code
E:04=Er:04washing=Door control broken
Cause=Faulty Triac or control module
Feb 17, 2008 | Siemens WFXD5200UC Front Load Washer
Washing Machines Logo
85 people viewed this question
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
