Question about Locks & Locksmithing
I have a Lewis and Clark lockdown triple security lock TSA80. The longer cable was not securely in place when I locked it so one end separated from the lock in transit. I pushed it back in, unknowingly jamming or resetting the combination. TSA agent opened the portion of the lock securing lugguage contents, however the longer cable is still locked to the bag handle. How can I reset the combination and / or remove the lock?
I can't answer the problem - but am interested as we had an identical failure on holiday in South Africa. We had to force the case open as the lock and the mechanism seemed to have come adrift in that when moving the lever with the correct combination - the case neither opened or closed. I'm sending it back to Samsonite under warranty to hopefully get it repaired/replaced. I rang the UK number listed on the Samsonite website. Bit disappointed as Samsonite should be more reliable - particularly given the price of the case, at £295, isn't exactly cheap.
Posted on Oct 11, 2009
  • 4 Answers
SOURCE: resetting my master lock
Posted on Jun 15, 2010
  • 541 Answers
SOURCE: how to reset an open master lock
your answer is on this site
Posted on Jul 05, 2010
SOURCE: how to unlock a tsa lock that I forgot combination
I have a new carlton misha cabin case and it has arrived with on of the zip arms in the lock and I cant get it to move and have not been given the code, could some one help please
Posted on Nov 13, 2010
  • 263 Answers
You need to go to service not try will be permanently locked
Posted on Mar 30, 2011
How do i reset a lewis clark luggage lock if i forgot the combination
I did these:
1) Apply continuous pressure on the tip of the long cable as if you were trying to unlock it. Do it softly, pain would block your sensitivity.
2) Turn the first dial (the closest to the long cable) slowly, as many times as you need, until you feel there is one number where the tip feels slightly (hardly noticeable) loose. Stop there.
3) Do the same for the second dial.
4) For the third dial press the tip of the short cable instead, and do the same as in step 2.
5) Very likely it will open, but if it did not, leave the dials in the position you found and start again. If at least one of your dials is correct, detecting differences will be easier.
Hope this helps.
Jul 18, 2014 | Lewis N. Clark Industries Lewis N. Clark...
Security system lockdown
If the car battery loses a cell, it can kill the battery and the power locks will not work. Also, a major breaker or fuse could have blown.
Mar 11, 2014 | Audi Cars & Trucks
Neutral safety swtch? security lockdown?
what is the question, here, i cant figure it out?
are you asking why the shift lever is locked in park?
Feb 03, 2014 | 1996 Toyota Camry
Buick security light flashing? How to reset security?
If you have a remote key fob for your locks etc it very much sounds like the battery is dead which will cause the car to"lockdown" so-replace battery. Good luck!
Jul 11, 2012 | 1996 Buick LeSabre
How to lock my pictures
Once you have jailbroken your iPhone. You'll got a Cydia icon on your SpringBoard.
  1. Launch the Cydia.
  2. Go to Search Tab and search for Lock Down and tap it.
  3. Tap Install button at Top-Right and then Confirm button at Top-Right to begin installation.
  4. After completion, go back to Springboard where you'll find a brand new icon i.e. LockDown.
How to use LockDown
  • When you will run the Lockdown application for the first time, you will be asked to setup a Safety Code and a Password. This password will be used to unlock any locked application and to open Lockdown itself. Safety code is useful in case you forget your LockDown password.
  • Once you have setup the Password and safety code, you will see all your iPhone applications listed on next screen.
  • Select any application you want to lock, a Lock button will appear. By tapping that button your selected application will be locked and a little lock icon will appear next to that locked application.
  • Now if you close LockDown App and try to open you locked application (Mail app in this example), you will be prompted to enter the password to open it. Use your Lockdown password to open that App.
(Once you open the app, use it and when you close the app it will be automatically locked again. So no need to re-lock it in LockDown.)
Lets check other options in Lock Down.
  • Tap LockDown to launch it. This time you'll be asked to input the password to open LockDown. Do it.
  • Tapping any locked application in LockDown will prompt you if you want to Unlock it. Pressing the Unlock button will perform the unlock that App.
  • Locked Applications button at the top right quickly shows all the locked application only rather scrolling through all applications to locate locked ones.
  • Under Settings tab at Bottom, following options are available:Locking Options
    • Lock All Applications
    • Unlock All Applications
    • Lock This Application (ON/OFF)
    Password Management
    • Change Saftey Word
    • Change Password
    • Forgot Password
    Other Settings
    • Lockdown Dylib (If you turn it OFF, even if you open a locked application it will not prompt for password. So, it's helpful when you are using your iPhone by yourself. See the details in screenshot. )
    • Lock Icon Moving (When turned ON it do NOT let anyone to move any icon to preserve your arrangement of icons.)
    • Lock App Deletion (When turned ON it do NOT let anyone to delete any application without your permission.)
    • Enable Launch Button (When turned ON, Lockdown will show a launch button when you open a locked application and input password.)
I am using this great application since the day it's supported with iPhone OS 3.0. It's working like a charm and will keep it installed because of its usefulness and surely recommend it.
May 13, 2011 | AT&T Lands Phones
Turn over no start
On MY jeep, the Security Lockdown system kicked in, and it would not start at all, until I put the key in the door, and locked and unlocked it 5 times. I felt stupid, but it worked! A guy at the dealership told me, b/c he owed me a favor. He said usually it is a wrecker call!
Dec 19, 2008 | 1996 Jeep Grand Cherokee
I have a BOSS DR-670 Dr.Rhythm and it has a security slot on the back of it.Can you tell me what it does? Thank you
I believe this is an anti-theft connector so you can attach your device to a desktop or a workstation in a public location.
These types of locks are usually on the end of flexible cables and have key locks or combination tumbler locks on them.
Alternatively, you can purchase these cable locks seperately and chain up your device (much like a bicycle) in public places.
Sep 22, 2008 | Audio Players & Recorders
Locks & Locksmithing Logo
181 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
