Midea hyk07 remote control
How do you reset E1 error code ?
change the batteries and see if there's a diff
Jun 30, 2016 | Universal AC Remote Control For CARRIER,...
My Midea Split Air Conditioner displays EC on the indoor unit after working for 10 - 15 minutes. What does that mean and how do I go about it?
Turn off the circuit breaker to the Midea A/C unit. I found mine outside. My unit has It's own breaker. It's in a metal case covering. I opened the door to the metal case and inside was a black box with 2 led lights that were not lighted. I pulled the metal pull on the black box and the black box popped out. On the back were 2 fuses that look like batteries. I replaced the black box and heard a beep from the A/C unit indicating power was back on. I used the remote to turn on unit and now it works like a charm!
May 08, 2016 | Midea Heating & Cooling
Lost remote control to ku32085 air conditioner
there are universal controls that are compatible with some Air conditioners, see a local dealer
Aug 13, 2011 | Midea Heating & Cooling
Changing temp readout on Midea Air Con Controller from F to C
  1. Make sure the unit is NOT on lock mode
  2. Press reset button for 2 second or until the Flashinf "F" appear on the temperature display or panel.
  3. Press Add button to change from Fahrenheit"F" to celius "C".
  4. Then press confirm and then cancel button to finish.
Jul 09, 2010 | Heating & Cooling
We have a Midea Model no MSX-24HRDN1-QCOW, purchased last year. Can you please advise how to switch the split wall system to heat ? Our email is hbw@chariot.net.au or ph no is 08 8266 5555, fax 08 8266...
Hi Jenny,Pressing the mode button on the remote until it display HEAT or a sun or an arrow next to heat or a sun will indicate that it is in heat mode.
Hope this helps I take the time to help you so please rate me
May 10, 2010 | Midea WP10000 Air Conditioner
Midea
If your unit is remote control try to check the mode icon.
Feb 02, 2008 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
