Question about edmodo.com
Edmodo error! the request is missing required data parameters
Application Error
Normally that means a page has been removed from a website or that you typed in the web address incorrectly. Check for misspelled words or that you didn't miss a capital letter. If you're positive you entered the URL correctly, the page was most likely removed or no longer exists.
Hope that helps!
Jan 30, 2014 | edmodo.com
Tip
Common FTP Error Codes
110 Restart marker reply. In this case, the text is exact and not left to the particular implementation; it must read: MARK yyyy - mmmm where yyyy is User-process data stream marker, and mmmm server's equivalent marker (note the spaces between markers and "=").
120 Service ready in nnn minutes.
125 Data connection already open; transfer starting.
150 File status okay; bout to open data connection.
200 Command okay.
202 Command not implemented, superfluous at this site.
211 System status, or system help reply.
212 File status.
213 File status.
214 Help message. On how to use the server or the meaning of a particular non-standard command. This reply is useful only to the human user.
215 NAME system type. where NAME is an official system name from the list in the Assigned Numbers document.
220 Service ready for new user.
221 Service closing control connection.
225 Data connection open; no transfer in progress.
226 Closing data connection. Requested file action successful (for example, file transfer or file abort).
227 Entering Passive Mode (h1, h2, h3, h4, p1, p2).
230 User logged in, proceed. Logged out is appropriate.
250 Requested file action okay, completed.
257 "PATHNAME" created.
331 User name okay, need password.
332 Need account for login.
350 Requested file action pending further information.
421 Service not available, closing control connection. This may be a replay to any commend if the service knows it must shut down.
425 Can't open data connection.
426 Connection closed; transfer aborted.
450 Requested file action not taken.
451 Requested action aborted. Local error in processing.
452 Requested action not taken. Insufficient storage space in system. File unavailable (e.g., file busy).
500 Syntax error, command unrecognized. This may include errors such as command line too long.
501 Syntax error in parameters or arguments.
502 Command not implemented.
503 Bad sequence of commands.
504 Command not implemented for that parameter.
530 Not logged in.
532 Need account for storing files.
550 Requested action not taken. File unavailable (e.g., file not found, no access).
551 Requested action aborted. Page type unknown.
552 Requested file action aborted. Exceeded storage allocation (for current directory or dataset).
553 Requested action not taken. File name not allowed.
on Jan 12, 2010 | Computers & Internet
Tip
COMMON FTP ERROR CODES
~~~~~~~~~COMMON FTP ERROR CODES~~~~~~~~~~
# Description
110 Restart marker reply. In this case, the text is exact and not left to the particular implementation; it must read: MARK yyyy = mmmm where yyyy is User-process data stream marker, and mmmm server's equivalent marker (note the spaces between markers and "=").
150 File status okay; about to open data connection.
200 Command okay.
212 Directory status.
213 File status.
214 Help message.On how to use the server or the meaning of a particular non-standard command. This reply is useful only to the human user.
215 NAME system type. Where NAME is an official system name from the list in the Assigned Numbers document.
227 Entering Passive Mode (h1,h2,h3,h4,p1,p2).
230 User logged in, proceed. Logged out if appropriate.
421 Service not available, closing control connection.This may be a reply to any command if the service knows it must shut down.
452 Requested action not taken. Insufficient storage space in system.File unavailable (e.g., file busy).
530 Not logged in.
on Dec 03, 2009 | Computers & Internet
I dont know my group code
how would I locate my group code that is require in signing up for ceu for respirator therapist
Feb 05, 2013 | Edmodo
How do you message a teacher
how to answer miss wertjes
Jan 18, 2013 | Edmodo
Forgot my pasword edmodo
If you forget your password, you can always make a new account, or if you have lots of important data, there is the word "Forgot?" in little blue letters. Clicking on that will get you a new password, so you can still access your account. :) Hope this helped!
Oct 05, 2012 | Edmodo
What is the code reading u1000 traction
Hi there:
DTC U1000 Class 2 Data Link
These DTCs set when the control module does not receive a message that it was expecting from another control module, and does not know which control module did not send that message.
Modules connected to the class 2 serial data circuit monitor for serial data communications during normal vehicle operation. Operating information and commands are exchanged among the modules. When a module receives a message for a critical operating parameter, the module records the identification number of the module which sent the message for State of Health monitoring. A critical operating parameter is one which, when not received, requires that the module use a default value for that parameter. When a module does not associate an identification number with at least one critical parameter within 5 seconds of beginning serial data communication, DTC U1000 is set. When more than one critical parameter does not have an identification number associated with it, the DTC will only be reported once.
Hope helps.
Sep 27, 2012 | 2005 Chevrolet Equinox
Download driver
Computers that request driver downloads are restorable by performing system updates. Once activated, the computer searches to compile the entire resources required from available networks. In situations that computer requests updates least networked would require ascertaining the exact program that is missing feature to cause functionalities. An extensive program malfunction least requires updates however requires reinstallation or new program altogether. The computer displays request to capture drivers as manufacturer designer's notification. Refer with computer support experts since request for missing driver would involve incompatibility condition least updatable. For example, missing computer drivers is installable on devices that are compatible to the system alternately, computers that least allows to replace drivers as incompatible will still request for drivers from peripheral devices. In such a situation, either the device requires attaining functionality on another computer or requires acquiring device that least requires drivers to function. Refer with computer technicians experts to configure the condition.
Feb 27, 2011 | Computers & Internet
This is a Compaq Presario CQ62. It is 3 months old. The orange Compaq screen pops up but then the computer shuts down after just a few seconds. Have tried it unplugged, plugged in with and without the...
Simple test to determine if it's a hardware or software problem : try to boot in the BIOS. If you can't then it's hardware you should just return it, it's still in the warranty. If you can then Windows is totally corrupted so just reinstall it.
Dec 19, 2010 | Compaq Computers & Internet
My Brother MFC-5440CN states machine error 7E. Help!!
error 7e means "no head parameters stored in the eeprom".
1) locate the head data sticker at the front left of the machine. it should have a 12 digits number at the top row and headx..... at the second row. the data is the 12 digits number. if the sticker is missing somehow, there's another one at the head/carriage unit.
2) enter maintenance mode.
3) enter 6 and 8 for property data entry
4) enter 2 5 8 0 within 2 seconds and you're at the data entry state.
5) key in the 12 digits number. use # and 1 to 6 to enter letter a to f.
6) hit the ok button. machine should beeps and display "input accepted". if it say "input error" there's a checksum error, meaning you keyed the number in wrong. it will return you to the data entry state.so just key the number in again (step 5).
7) exit maintenance mode. done.
Nov 21, 2009 | Brother MFC-5440CN All-In-One InkJet...
edmodo.com Logo
150 people viewed this question
Top edmodo.com Computers & Internet Experts
Endre Nagy
Endre Nagy
David Payne
David Payne
Are you an edmodo.com Computer and Internet Expert? Answer questions, earn points and help others
