Question about Solo 450 Mist Blower
Mix backpack put new fuel tank on & now won't start getting to much fuel
Put gas only in motor
Did you run it with the pure gas in the tank? If so, it's probably beyond repair of the average homeowner. If you did not run it put your mixed fuel in the tank, push the primer many times to force the oil/gas mix into the carb, and you should be good.
Jul 31, 2014 | Husqvarna 130bt 130 Bt Gas Powered...
Why does my Poulan Pro PPBP30/30cc backpack blower have no power?
It may be fuel starved from either blockage in the carb or a broken intake fuel line. You can dump the fuel and mix up a back of fresh fuel with some system cleaner added and run it through and see if the unit picks up a bit. If a system cleaning doesnt improve performance with the gas tank empty look inside the tank and see if the fuel line is broken off or split. Many times fuel lines just get broken from alcohol fuels and age.
Jun 24, 2014 | Homelite Consumer Products Backpack...
Yardman 27cc 445cfm Backpack Blower starts fine, but when I try to depress the trigger for more power it dies. Idles smooth with full choke and dies when on no choke setting. Have had someone say it needs...
There may be a plugged fuel filter in the fuel tank, or perhaps you have the oil mix to rich. other problems could be that it needs a new spark plug or carburetor adjusted.
Try spraying the carb out with carb cleaner, add a little seafoam in with the gas.
Oct 21, 2013 | Mtd Products TB2BP EC 27Cc Backpack Blower
My echo packpack blower won't start
How long has it been since its been started? If its been a while go to Home Depot and get some fuel stabilizer follow the instructions - if it hasn't been to long go to home depot and get a new spark plug and replace the old one as well as clean the filter -make sure to put fresh oil/gas ratio in the tank - use stabilizer if needed
Oct 25, 2012 | Echo 50.8cc Backpack Blower
Gas and oil mixed in 4 cycle backpack leaf blower
If it is a 4 cycle blower, you do not mix oil with the fuel....It takes straight Gas. there is an oil cap to put engine oil in crankcase, this only usually takes 2,3,4 oz. of oil. Sounds like your Spark Plug probably fouled out from having oil mixed in your gas. I would recomend changing your Spark Plug and put some Fresh GAS only in the blower, dump the old stuff out !!! You should be on your way Blowing in No Time !
Nov 27, 2011 | Troy-Bilt 32cc 4Cycle Backpack Blower
Accidentally put mixed gas and tried to start. Blew white smoke after starting but wouldn't run. Drained tank and put premium back in now won't even start.
There will still be some fuel mix in your fuel lines and filter. Also it probably fouled your spark plug. Try changing the spark plug first, and probably buy an extra one or two to keep in case. Also either replace the fuel filter or clean it out good, oil will stick to the elements in the filter. It won't hurt anything to run a mix in a gasoline engine, just lubed things up a little extra. Let me know if you need anything else, Daniel.
Oct 13, 2011 | Polaris ATV
My backpack blower won;t start. I replaced the spark plug and it still won't start. Can you make a suggestion?
Check and make sure the rubber hoses coming out of the fuel tank are not broken and look inside also if not that carb is cloggged up maybe pull the fuel hose off and spray some gumout up into it to open up the jet, spray some gumout in the carb and see if you get a sputter out of it then you know your not getting any fuel.. carb needs cleaning
Oct 03, 2010 | Husqvarna Forest & Garden 125bt Backpack...
Ryobi backpack leaf blower about three years hard to start
Basics to check:
1) Spark plug - brown or dark brown - OK
a) is it carbon or fuel fouled
b) is there spark
2) Muffler remove for inspection
a) exhaust screen clean or plugged
b) inspect cylinder wall/piston as the flywheel is slowly rotated
3) Check cylinder compression
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
Nov 24, 2009 | Ryobi Garden
Ryobi RY08576 25.4cc was started without mixed fuel
If the engine is sticky ie harder to pull it might have to be pulled apart new piston and honing of cylinder. not difficult just a pain. If it doesn't seem any harder to pull, Drain all of the unmixed fuel. Put a few drops of 2cylinder oil in the spark plug hole and pull the starter a few times with the plug out of it. Put a few more drops in repeat. Replace the plug (new plug) Put in mixed fuel prime the system cross your fingers and it should start up for you.
May 12, 2009 | Ryobi Backpack Blower 25.4cc
Blower runs fine for 30 or 45 mins, then will not come up to speed.
there is a fuel filter in the fuel tank that some times gets cloged try that and fresh gas -oil mix
Nov 01, 2008 | Homelite Consumer Products Backpack...
Solo 450 Mist Blower Logo
18 people viewed this question
Top Solo Garden Experts
Colin Stickland
Colin Stickland
Steve
Steve
Level 1 Expert
Are you a Solo Garden Expert? Answer questions, earn points and help others
