Panasonic TV model CT-27G7DR
1. The TV screen is fine until it warms up. 2. After a minute or so, the screen goes blank or there is a thin picture line that goes across the middle of the screen. 3. The screen will pop up occasionally after vibrations or pounding on it. 4. I thought it was the antenna connection in the back of the T.V. Wiggling it tends to make the screen come back for a while. 5. I wiggled the back of this too many times. It is now broken, but I can put it back with glue, but it still continues to black out. 6. I have tried taking the T.V. apart & blowing it out with compressed air. This seemed to help for a day or 2. The problem kept coming back. 7. It seems like there is a loose connection. 8. I do not want to buy a new T.V., due to the digital signal becoming standard in the next few years, but I also do not want to spend a lot of money on a repair. Any suggestions, Ginty
  • Anonymous Jan 04, 2008
    sanyo model DS24205 screen went completely black with thin horizontal line in center. I cannot get a picture or sound
    Brigadier General:
  • 6,966 Answers
Hi, Very often, the vertical IC is the culprit. What happens is due to excessive heat, the solder joints of the IC's pins gets undone. More often than not, re-applying heat through a soldering iron would solve the problem. It may also be a wise move to re-solder surrounding components and to check for any loose connections. Pls be reminded of safety precautions when working inside a TV unit. Hope this be of help. Post back how things turned up or should you need additional information. Good luck and kind regards.
Posted on Sep 28, 2007
SOURCE:
My 27 inch Insignia flat screen tube TV goes blank
The vertical deflection has gone out. Put it in the shop.
Apr 24, 2010 | Insignia NS-27RTV 27" TV
Mitsubishi VS-50707 screen is jittery when it first turns on
Sounds like the verticle circuit is failing a honest shop will take of this for you around 180-230 if you want to do yourself youll need a iron and some filters and an verticle ic
Sep 26, 2009 | Mitsubishi VS-50707 50" Rear Projection...
Sony KV-32S66 Picture Rolling Up/Black Horizontal Lines
the problem there is a loose connection on the board,you said that you smacked the right side of the tv and it goes normal.there are parts that should be resolder on the board in order to back into normal operation.
Oct 22, 2008 | Sony KV-32S66 32" TV
Toshiba 27D46 Black Screen - White Horizontal Line
I fixed the problem by taking it to a repair shop
Apr 24, 2008 | Toshiba 27D46 27" TV
TV has a thin horizontal line across the screen
intermintence in vertical IC deflection its a job for experienced tech need to look for that circuit and do fine job resolding that IC
Apr 01, 2008 | Sanyo DS31590 31" TV
Picture reduced to a horizontal line across center
sounds like the vertical, more info ctechnicians.com
Dec 21, 2007 | Hitachi 35UX80B 35" TV
13 inch rca true flat tv
if it is a straight thin line from left to right you have a vertical problem time to call service tech
Nov 29, 2007 | RCA TruFlat 27F520T 27" TV
Red Line across Screen
sounds like you have a vertical sweep problem. Where the fault lies cpuld be the vertical output IC the verticle b+ feed, could be the capacitors in the vertical circuit?? Your gonna need to troubleshoot thr vrtical circuit if your not a tech thin my advise is to take the set to a pro for sn est. Good Luck
May 22, 2006 | Hitachi 36UX01S 36" TV
Televison & Video Logo
199 people viewed this question
Top Televison & Video Experts
Ekse
