Question about Braun KSM 2 Electric Blades Grinder
I have a chefmate coffee grinder. The plastic hub with attached blades broke. Are replacement parts available? Model number is GC6000.
  • 4 Answers
SOURCE: blade replacemen braun grinder
Insert a small standard screwdriver in the slot in the center of the bottom. Turn the blade slowly until you feel the screwdriver catch in the slot. This holds the motor still so you can simply unscrew the blade counter-clockwise. Do the same to hold the motor from turning while you screw the new blade on clockwise.
Posted on Jan 12, 2008
abhishek33
  • 1239 Answers
hi sir  thats only to remove older blade[damaged] apply lubricant to loose it and leaving for some time try to shaft with screw drewer
Posted on Sep 10, 2008
  • 4 Answers
SOURCE: Braun KSM1 XXU coffee grinder stuck 'ON'
The little plastic piece is part of the spring tension for one motor brush. It has been re-installed. I no longer need any assistance.
Posted on Sep 25, 2008
SOURCE: Blade Change Braun KSM2 Coffee Grinder
There is a small slot on the bottom for a flat screwdriver to lock the shaft in place. Then unscrew the blade.
Posted on May 04, 2009
SOURCE: tassimo coffee maker part replacement
If your machine is made by Bosch then go to www.bosch-eshop.com where you can order spare parts online. I think the part number is 616231:Jet and is called a Tassimo piercing unit.
Posted on Nov 20, 2009
Change or sharpen blade on cuisinart spice and nut grinder
you can replace it by contacting cuisineart on line and or their toll free number provide the part # and they will send you another one it will cost you though
Sep 30, 2014 | Cuisinart Spice/Nut Grinder
Tip
Krups 203 Blade Replacement Procedure
<span>Krups is among one of the foremost names in coffeemakers, espresso machines, blenders and toaster ovens. Krups also makes coffee bean grinders, such as the Krups 203a. This portable, plug-in grinder has a removable lid and bean grinder chamber. The blade on the Krups bean grinder is fastened to the bottom of the grinder chamber. You may need to replace the blade on your Krups 203. The Krups 203 comes with a limited 1-year warranty, but the company recommends you send your grinder to the company to make repairs. Order replacement parts for your grinder by calling the Krups customer service department at 1-800-526-5377.<br /><br />Unplug your Krups grinder from the wall.<br /><br />Remove the grinder's lid, and use a cloth to wipe out the inside of the grinder chamber.<br /><br />Put your safety gloves on and then grasp the blade of the grinder with your channel locks.<br /><br />Use the pliers to turn the plastic fastening nut to the left as you continue to hold the blade with the channel locks. Once the plastic nut comes loose, twist it off by hand and remove it, along with the plastic washer beneath it and the old blade.<br /><br />Set the new blade in place, and replace the washer and nut. You will have to hold the new blade in place with the channel locks as you tighten the securing nut. <br /><br />Things You'll Need<br /><br /> Cloth<br /> Safety gloves<br /> Channel locks<br /> Pliers<br /></span>
on Jun 02, 2011 | Krups 203-42 Electric Blades Grinder
Can I order 2 blades for my 1119 Toastmaster electric coffee grinder?
The grinder is available for under $20 (Amazon.com sells it for under $15). At that price it's a throwaway item and no parts are available.
Jul 20, 2011 | Toastmaster 1119 Electric Blades Grinder
Need replacement part for Starbucks Barista Blade Grinder! Please help? Went to grind as I usually do but there is apparently a plastic circular part under the blades (I imagine that keeps the blades in...
your best bet is probably to search ebay for a dead one you can strip, cheaper grinders tend not to be supported with parts, personally id recommended throwing it away and getting a better grinder, blade grinders do not give a consistent grind, they are just about acceptable for grinding for a french press but anything else youll be far better off with a burr grinder
May 10, 2011 | Starbucks Barista® Blade Grinder
Source for replacement blade for CBG5 B&D Coffee Grinder
Unable to find any parts supplier who offered a replacement blade for the CBG5 SmartGrind Coffee grinder, the broken plastic center spindle was reconstructed around the attachment nut, and an epoxy cement was poured around the nut and over the center of the blade.
This solution has worked in testing the blade on the grinder, but how long it will hold up has not yet been determined.
T.B.
Oct 07, 2009 | Black & Decker Black and Decker CBG5...
Stuck Grinder Bowl
This seems to be a widespread problem on units manufactured in 2007 and later.
Unplug the unit from the AC outlet. Remove the six screws that hold the lower plastic cover on the motor base (four screws are hidden under the adhesive rubber footpads). This exposes the lower end of the motor shaft, which has a slot in it. By inserting a flat blade screwdriver into the slot and holding the cutting blades with a rag or a wad of paper towel to avoid cutting one's fingers, it is possible to twist the shaft back and forth about 90 degrees. You may need another person to help, because one needs to perform this twisting action while pulling the motor base away from the grinding cup and blade assembly.
Once you get the @&%$#! thing apart, reassemble the motor base. (With the slotted motor shaft, why didn't the designers simply put a hole in the plastic base so one could stick a screwdriver in without disassembling it?) Plug it into the wall outlet and use a small object like a toothpick or matchstick to activate the recessed motor switch so you can spin the motor without the grinding cup in place. Use the blunt edge of a small snap-blade utility knife as a scraper to gently scrape the plastic pin of the motor shaft as it spins, much as one would work a wood turning lathe. Periodically check the fit of the brass hub of the grinding cup on the plastic pin. Continue to shave the pin until the grinding cup slips onto and off the pin with no resistance. Take care to machine the pin uniformly from top to bottom; avoid making grooves.
Why this mechanism worked properly when my grinder was new about 18 months ago and suddenly decided to get stuck this week is a bit of a mystery. The unit in question has been used since it was purchased exclusively to grind flax seed, but the ill-fitting pin normally doesn't come into contact with foods, anyway. There was no obvious evidence of swelling of the plastic due to heat from the motor or oils from seeds. Since the blade and hub are free to travel up and down on the plastic motor shaft pin a bit, I suspect that on occasion the blade doesn't settle properly and the clutch doesn't engage, allowing the pin to spin in the brass bushing until it starts melting, and then the hub settles so that the clutch is fully engaged. This may happen in a matter of just a couple of seconds of operation. Once that happens, the pin conforms to the microscopic grooves inside the brass bushing, allowing it to still turn slightly relative to the motor shaft, but locking it on so that it can't come apart. If Cuisinart had made the pin more tapered and the hole in the brass bushing to match, much like a Jacobs taper on an industrial drill press spindle, this would be much less of a problem.
BOTTOM LINE: Before loading the grinding cup and starting the grinder, push the blade hub down with your finger to make sure the clutch is fully engaged.
Apr 14, 2008 | Cuisinart SS Grind Central, removable bowl...
Feb 20, 2008 | Braun KSM 2 Electric Blades Grinder
Cup for grinder
This happened to mine this morning. I was so frustrated because the reason I bought this was because of the removeable bowl. My bf got it off but he broke off a piece of plastic (he is pretty sure the piece of plastic was on the bowl part).
I put it back on and it kind still worked- I think I will just need to get a replacement bowl now - but it was hard to get off again.
When I tried to get it off the second time, I moved it into the "unlocked" postion and then manipulated the the blade part while pulling and it came off - but of course mine was broken already.
There appears to be two areas where it locks - on the base and a part on the bowl. I think somehow they get out of synch.
The problem is not with the base I think but with the bowl.
Although, now that it is "sorta" broken - I can't remember what parts were supposed to be loose before and which ones were not. The blade part of the bowl is very loose now. My boyfriend is pretty sure the plastic broke off the bowl part so I am going to get another bowl. I hope that solves my problem!
Feb 04, 2008 | Cuisinart DCG-12BC Electric Blades Grinder
Cuisinart DCC490SA 10-Cup Coffee Maker
Does the black plastic thing not lift out of the coffee maker? I just scrub the black bottom and clear top in the sink or run it in the dishwasher. HTH-
Jan 28, 2008 | Cuisinart DCC490SA Coffee Maker
Braun KSM 2 Electric Blades Grinder Logo
56 people viewed this question
Top Braun Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Are you a Braun Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
