Question about Radio Communications
Uhf radio problems
My Oricom UHF088 has a constant speaker noise when I turn it on and a wining noise than increases and decreases with the revs of the motor. I have connected it straight to the battery as this is one of the wiring options.
  • 9 Answers
SOURCE: can't increase & decrease the volume
Double check your connections. Still not working fine. Remove the input jack connector and try to touch or hold the tip of the connector, also adjust the volume of the speaker, you should heard loudly the 60 hertz sound of your body signal. Otherwise you have a defective amplifier in the speaker system.
Posted on Aug 25, 2007
Neto
  • 123 Answers
SOURCE: uhf radio cb tranciever
Hello Are You using the correct antenna?,when you turn the squelch down do you hear static sound?, are you using squelch codes? if it is just a CB radio that works on Citizen Band (11 Mts) this radios does not have squelch codes.
Let me know the brand, model of the radio.
Posted on Dec 19, 2007
  • 290 Answers
SOURCE: needing wiring diagram for 1991 dodge dynasty le
here is what I found:
http://www.the12volt.com/installbay/stereodetail/715.html
Posted on Mar 26, 2009
luckyluke78
  • 333 Answers
SOURCE: 1989 Chevy Truck , Stock Radio , Whining noise
Sounds like you have a capacitor problem.It could be a number of issues , but i suggest you check the alternator one first.
If you unplug the power cable to the back of the alternator and the whining goes away then replace the capacitor(usually only one bolt/screw)and you should be OK.
If not I sometimes have dissconnected the + wire from the HT coil when the car is running and the same applies,and if this works replace the capacitor or fit one if there isn't.
If none of this helps fit one to the + wires of your radio.
Please leave fair comment if I have helped you.
Thank you
Posted on Sep 01, 2009
Testimonial: "This is Great Info, I'll try all ideas . Ross "
  • 708 Answers
SOURCE: Constant high pitched whining noise. Increases
you could be low on transmission fluid check that and make sure it registering properly on the dipstick.
Posted on Oct 20, 2009
For my Nissian titan 2005 truck -When plugging in my speaker harness to my factory radio it starts making a buzzing noise coming from the speakers does anyone know why?
does the buzz increase and decrease with engine RPM? if so a capacitor/filter is needed in the powering of that circuit (although that should not happen with a factory unit if installed as spec'd by the manufacturer).
Feb 23, 2016 | Cars & Trucks
Wireing diagram oricom uhf 088
Oricom UHF088 Questions & Answers - ProductReview.com ...
www.productreview.com.au > ... > Oricom > Oricom UHF088
Ask a question about Oricom UHF088 in UHF Radios. ... need a DC regulated power supply, you can pick one up from stores like from Supercheap Auto, Dick Smith or JayCar. ... I am after the wiring diagram for the uhf088 hand piece please?Missing: trucks
UHF088 UHF 5 Watt 2- Way CB Radio (in vehicle) - Oricom
www.oricom.com.au/uhf088-uhf-5watt-cb-radio-in-vehicle.html
Dec 29, 2015 | Cars & Trucks
High intermitent revs at idol and while driving
If engine is increasing/decreasing constantly this is called hunting. Or does it suddenly just rev wildly then go back to normal?Please give more detail and resubmit. Please andd make model year and engine option of vehicle
Jun 02, 2015 | Cars & Trucks
Oct 20, 2009 | 2003 Toyota Sienna
Noise from speakers when playing basses
Offhand, could either be the subwoofer speaker itself or the electronics (amp and/or crossover). One way to determine is by physcially checking the sub speaker. When playing with bass on, pls try restricting speaker movement by pressing on it and see if the noise is reduced. Another is to temporarily replace the speaker. You can try speakers meant for the car, home entertainment or book shelf, just dont set the volume too high.
If the speakers are ruled out, then it would be the electronics inside. For this, you would need familiairty with electronic components and circuittry, a DVM and a soldering iron. Access to an oscilloscope and an audio signal generator would be nice but not a necessity. The idea is to inject a constant audio signal and determine where the noise (if electronic) is coming from. In most instances, it would be a leaky electrolytic capacitor either in the input stage or feedback loop. At other times, it would be also a capacitor in the band pass filter.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 28, 2008 | Audio Players & Recorders
hello, check and see if cabinet has loose screws or if back panel is tight,bass can vibrate screw loose.good luck! also look for anything caught in the woofer causing the noise.
Indicator light not working and humming noise
your circuit board is bad not repairable i have the same prob but not kenwood they said it would cost more then its worth.
Jan 03, 2008 | Kenwood 103SW Speaker
Sound Level Changes Constantly
Make sure digital sound control is not set to optimal
Make sure incredible surround is off
Press optimal sound mix until it says "OSM Off"
Double-check the speaker connections
May 07, 2007 | Philips FWC399 CD Shelf System
Radio Communications Logo
23 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
