Question about Sony STR-DE705 Receiver
The right speaker has distorted sound at 100 % volume and sound is low, the left speaker is dead....need some clue what to check first ? Thanks in advance . Almost forgot (!!!).It is my 28inch Samsung TV set......Kaz
3 Suggested Answers
linswad
  • 258 Answers
SOURCE: Right speaker is distorted with low volume, left
There is something wrong with the right channel amplifier, you need to get this equipment serviced.
Posted on Mar 26, 2010
Possibly one of the power transisitors has gone out. They are typically used in pairs, and if one went out, this is likely what you would experience.
Open the unit and look for the power transistors. The have 3 leads and should be connected directly to a heat sync. If one burnt out, it will likely be obvious by just looking at it. Power transistors are cheap (>$10) and there are many online sources to by them from. With a litle soldering skill, shouldn't be too bad.
Posted on Feb 02, 2013
Marshall MB4410, with low volume gives no real volume,
Guitar amps have preamp sections (think unpowered audio mixer) and power amp sections (Crown rack-mount amp). An excellent way to isolate audio problems if amp is still producing audio is to check the preamp out (line out). Preamp output distorted = preamp failure. Connect MP3 player to "Power Amp In"...sound distorted = power amp failure. In your case the latter is the case as your "line out" is clean. Also test each speaker for clear sound as speaker cone damage from being overpowered is fairly common. At 300w. I'll assume the failure was not from cranking the volume to loud but a shorted speaker or speaker wiring could zap the power amp in an instant.
Jan 06, 2014 | Marshall MB4410 Bass Combo Amplifier
Right channel distorted denon UDRA M7
Hello there, I have the same amplifier and now it has the same problem on the right output. Have you found out how to fix it? Thanks!
Nov 07, 2013 | Audio Players & Recorders
Str-gx800es sony receiver problem- right channel speaker sound is 'static', low and distorted. I have checked checked all speaker and output/input source cable connections with no luck. All left channel...
If you have checked the speakers and wiring, the right channel has a audio driver or output problem, which explains the low volume, static, and distortion. A service technician will be required to fix the receiver so it will balance the left side.
Jan 10, 2011 | Sony STR-GX800ES Receiver
When the volume is turned up past 30 the sound shorts out and breaks up on my KD-R200
Well if say ur volume doesnt go much past 30,,they usally do called distortion,,but if your cd volume say goes to a 100 and it doin that @ 30,,could be a speaker wire touchin ,,another,,or channell goin out,,I would take it and make sure connected good and pos and neg correct,,goodluck
Nov 18, 2010 | JVC AM FM CD DET FACE CAR STEREO
2005 Chevy Silverado Bose stereo operators manual, how do I set the EQ presets?
My left front speaker sounds distorted at low volume but sounds ok when I turn up the volume.2005 Chevy silverado bose stereo and speakers
Apr 30, 2010 | OEM Systems Car Audio & Video
Right speaker is distorted with low volume, left side is fine. Swapped speakers no difference (ie it isn't a speaker problem). Using the balance knob, full left sounds fine, full right is very distorted...
Mar 26, 2010 | Sony STR-DE705 Receiver
The left audio channel & bass is dead.
Double-click the "speaker-volume" icon on the system-tray, to open the "sound-mixer".
Make sure that you have not "panned-100%-left" nor "panned-100%-right", so that 0% of the sound comes out from one speaker, while 100% of the sound comes out from the other speaker.
Also, make sure that no "mute" button has been selected.
Feb 02, 2010 | Gateway Media Center 610XL PC Desktop
Asus A8N32 SLI Deluxe Motherboard audio problem
The new boards multiplex the connectors on the back panel to maximize use. Open the Realtek control panel and configure for sterio 2.1. Also, these new boards do not provide any power drive, so to get decent volume, you will need amplified speakers.
Oct 09, 2009 | ASUS A8N-SLI Premium Motherboard
Strange problems with Z-2300's
I'm having this same problem and have sort of solved it with a really wierd technique I found at Logitech. Evidently this problem is related to the control pod rather then the RCA jack. Try this:
Unplug the control pod from the subwoofer Turn off the main switch Turn the volume knob one full turn, tap the knob Repeat again (2 times) Replug the control pod Turn on the main switch and the control pod See what happens
I found that this got the speaker working finicky after it was almost totally useless. It seems to be cutting out randomly, but fidgeting with the control pod or it's connector jack fixes it. No clue what the deal is here, but your problem is identical to mine so take some time to screw around with these components with music running so you can hear if it suddenly works.
Nov 12, 2008 | Logitech Z-2300 Computer Speakers
21 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
