Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
Steering wheel is very loose. - John Deere 420,1020,2010,2020,2510,2520 Tractor Float
Tightening steering wheel on husqvarna tractor 42in 15 horsepower no. yth1542
Interesting! The steering gear can commonly become loose at a several points. I would check the steering wheel itself, prise off the central plastic cover and make sure the nut underneath is tight. Check the gear at the bottom of the steering wheel shaft, if this gets loose it can jump the gear teeth. Sometimes this is so bad the steering wheel will turn without moving the wheels. Tighten everything and replace any worn parts.
Jun 13, 2016 | Husqvarna Garden
What is a CV joint?
A wobble in the steering is more likely to be one of
- loose wheel nuts
- loose hub nut
- worn steering tie rod outer joint
- worn steering tie rod inner joint
- loose steering rod universal
- worn steering knuckle ball joint
Out of these a worn or loose steering tie rod joint is most likely. If you can, jack the front of the car up and rest it on axle stands, NOT just on the jack, then have one person shake the front wheel back and forth while holding it at 9 and 3 o'clock, while another holds the steering wheel still. Then look at and feel each joint to see if you can locate the looseness.
Jun 27, 2014 | 1997 Toyota Camry
Steering wheel loose on a 1996 Honda
Hi there are several things that can make your steering wheel
feel loose. Check that the universal joint that connects to the steering rack from inside the car are not loose by moving the steering up and down, it could also be the steering column bush,(only if the wheel go up and down side ways) check
also the tie rod ends by jacking the car grab the front and back of the wheel and shake in and out to see if you have any loose.(always secure the car on stands ) other than that it could be the rack and pinion steering mechanism that would need to be changed.
Jun 18, 2014 | 1996 Honda Civic Steering Wheel Ring
My steering wheel wiggles
You could have an out-of-balance or out-of-round condition on the front tires, but similarly it could be something more serious
-loose front wheel hub
-worn front suspension joint
-worn steering tie rod joint
-loose steering box mounts
-loose steering column u-joint
-loose or word steering wheel attachment
Oct 31, 2013 | 1991 GMC Sonoma
Steering wheel is loose and wobbly
If the loose motion is coming from the tilt part, there are three bolts inside the column that need to be tightened up.
Someone would need to remove the steering wheel to access the bolts.
Oct 07, 2012 | 1991 Oldsmobile 88
Steering wheel feels loose. Took to garage, had
This sounds like you need new track rod ends, this would cause free play in the steering, also it could be the bottom suspension arms. the garage should have checked these though! if the wheel is vibrateing then it may need the wheels rebalanced. if it is that you steering will shake at 60mph
Jan 20, 2010 | 2002 Land Rover Freelander
I have a 1981 Corvette with tilt steering wheel. The steering wheel has started flopping like something is loose in the steering column. Whats going on? Thanks Jim
You must remove the steering cowl below the steering wheel and see what is loose, broken or worn. It more likely to be a loose bolt, in which case just tighten it and refit the cowl.
Hope that helps
Jan 15, 2010 | 1981 Chevrolet Corvette
The steering wheel turns but the wheels are not
Inspect your steering for any linkage that has come loose. Check it from steering wheel to the front wheels. Repair any thing that is loose or just hanging.
Good luck.
Let me know if this helps.
roundo4
Aug 28, 2009 | Garden
Alot of play in steering wheel and power steering is completely out. Is there any way to repair theproblem or do you think I need to replace both?
look for loose steering gear shaft adjusted too loose or shaft bushing worn. steering linkages loose.wheel bearings improperly adjusted.
Apr 28, 2009 | 1981 Ford F 150
My steering wheel is loose.
your steering wheel has splines . they strip or worn cant tighten have to replace steering wheel . it has a nut under the horn pad .it might have come loose. but i have never seen one come a lose. but i have known the splines wear on them. disable air bag in steering wheel before removing steering wheel.
Mar 31, 2009 | 2002 Ford Escape
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
13 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
