Question about Kenmore 63942 Dryer
Kenmore gas dryer will not heat or shut off - Kenmore 63942 Dryer
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 56 Answers
Plug it of then in, or check the manual: Kenmore 80 Series Dryer Manual
Posted on Nov 17, 2013
vitg55
  • 70 Answers
SOURCE: Kenmore gas Dryer Heats at start then stops heating
Usually problem like this with electrical solenoids located on the top of gas valve inside the dryer. They need to be replace.
Posted on Dec 08, 2008
jumptrout51
  • 3361 Answers
SOURCE: kenmore gas dryer model 97284100
The door latch is about $5. Replace it.
Any appliance parts store has them.
Posted on Mar 27, 2009
  • 68 Answers
SOURCE: Kenmore gas dryer model #76812690 will not heat.
does the dryer heat initially when you first turn on the dryer Or no heat at all?
the first thing i would check is tthe thermal fuse thats located on the back of the unit. test it with a multimeter and see if it has continuity, if it doesnt then replace that and your operating thermostat. the check to be sure you venting to the outside of your house is not clogged
Posted on Apr 29, 2009
  • 97 Answers
SOURCE: Kenmore 80 Series gas dryer starts with heat but very short time
Hello Friend, Your problem is very simple to fix. You're dryer needs a gas valve coil kit. To replace coils just remove front of dryer body and look below drum you will see the gas valve. The valve coils are located on top of valve (two little round black cylinders). It's simple, just remove the two screws from the little metal bracket that holds them down, unplug the wires from them and just lift them straight up off of the valve. Take notice that one has 3 wires and one has 2 wires. Just replace with new coils and plug wires back in and re-fasten metal bracket. Your dryer will run like new. Happy to help, Tim.
Posted on Jun 24, 2009
localwonder
  • 6784 Answers
SOURCE: kenmore gas dryer wont heat up
Check the following areas to combat this issue. the most common problem spot will be a blown Thermal fuse.
1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
Posted on Aug 11, 2009
Managemylife com sears
Ohms out the two gas solenoids. You might find one open. Replace both.
Make sure the vent/air flow is not restricted.
Oct 18, 2013 | Kenmore Dryers
Gas dryer heat shuts down won't dry cothes
This sounds like the heat sensore that goes to the gas valve. It is there fore shutting down the gas.
Jun 15, 2011 | Kenmore Dryers
Our kenmore gas dryer is starting but after 1 minute the heat shuts off what could it be
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101/,./'
Mar 27, 2011 | Kenmore 600 6965 Electric Dryer
Dryer runs but no heat and it does not shut off (timer not shutting dryer off)
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 23, 2011 | Kenmore 63942 Dryer
Kenmore 70 series dryer starts and heats up then shuts off
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 02, 2010 | Kenmore 73952 Gas Dryer
Kenmore dryer wont heat or shut off at end of cycle
heatman101
Aug 08, 2010 | Kenmore Dryers
Kenmore Dryer doesn't shut off and doesnt' get hot
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
heatman101
Apr 14, 2010 | Kenmore 73952 Gas Dryer
Gas dryer heats fine but shuts down before the drying cycle is over taking longer to dry clothes. Lint trap and exhaust tube cleaned out.
You are going to most likely need a vent cleaning. The dryer is getting too hot and shutting off because it is not exhausting good.
Apr 29, 2009 | Kenmore 94702 Front Load Stacked Washer /...
Heat runs ten minutes than heat shuts off continues to run
I'm thinking the thermostat has failed, it get's too hot and the emergency over temp sensor kills the flame before a fire is started.
Apr 07, 2009 | Kenmore 63942 Dryer
Will not heat
glow bar igniter ... - thermal fuse ( not all models ) ... - coil on the gas valve ... - gas valve ... - thermostats ... - motor heat switch ... - timer ... - selector switch ... - sensor ... All these will cause this problem.
Mar 22, 2009 | Kenmore 74672 Gas Dryer
Kenmore 63942 Dryer Logo
106 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
