Question about GE GTUP270EMWW Washer
GTUP270EMWW Washer/Dryer Stack: wash cycle will not engage after filling. Also replaced lid lock mechanism that was not allowing lid to open... Cycle would fill but never fully run, lid would not open due to lid lock remaining engaged.
  • 641 Answers
SOURCE: My washer does not wash the clothes or go through the spin cycle.
It sound like a belt problem. Try to move tub manually first, in case it move smoothly -open the front panel, the belt should be between the motor and the drive pulley (lower front). In case it torn or not in its place, you should replace it. In case it doesn't move smoothly - maybe that a sock or other piece of clothing get between the clothes tub and the outer tub and prevent tub's spining. If this is the situation, it should be removed. Good luck !!
Posted on Jun 02, 2006
SOURCE: Washer will not spin
I fixed it yesterday. After checking the continuity of my lid switch and pressure switch and finding them ok I removed the tubing from the pressure switch and applied air (blew into it). There was a clog and blowing on it removed it for now. Apparently the pressure switch was telling the machine that the tub was full of water and wouldn't let it start the spin cycle. I ran three loads last night and it worked perfect. I may have to remove the connection on the side of the tub and clean it properly if it clogs again.
Posted on Mar 25, 2009
  • 125 Answers
SOURCE: GE PROFILE WASHER DOESN'T CYCLE TO WASH FROM FILL
  1. Clear the ERROR from the screen: Press and hold the MY CYCLES and BACK buttons simultaneously for 3 seconds. The control will display any recorded errors. Please write down what error codes are shown on your screen in case service is needed. If a MORE icon is displayed on the screen, press MORE to list additional errors. When the EXIT button appears, press EXIT.
  2. Remove Power: Follow the onscreen instructions to remove power (unplug unit) and then immediately plug unit back in.
  3. Clear Setup Mode: After power is restored, a setup screen that begins with "Congratulations..." will be shown. DO NOT PRESS the OK button shown at the bottom of the screen. Press the START/STOP and POWER buttons simultaneously until the Home Screen is displayed. Your unit is ready to function normally.
Posted on Aug 20, 2009
SOURCE: GE spacesaver stack washer & dryer: The
the dryer won't heat up. everything else works. the drum goes around with clothes in it. it just won't heat up .
Posted on Jan 16, 2010
beltronic205
  • 1460 Answers
SOURCE: Washer fills-up with too much water and won't do wash cycle
I trust the fill valve is shutting off when off. The problem would then be water level switch or pipe connected to this its also called a Pressure switch, it detects how much water enters the drum then shuts off the supply,No washing could be due to the weight of water and clothes.....Please leave me feedback
Posted on Apr 08, 2010
Lid lock broken can I overide?
Washer not starting Cycle:
I would have to slam the washer lid before the washer recognized the lid was shut.
What I did to fix:
1. Ref the link below for Schematics
http://blog.kennyluong.com/Tricking-A-Maytag-Bravos-Washer/
2. Looking at the Lid Lock section of the Schematic:
Place a jumper between pins 2 and 3 of J15
This engages the 1st switch (Lid Lock) so, I don't have to slam the lid anymore
3. Since my Lock switch (2nd switch), which is engaged with a magnetic, is working, my work is done.
If you find that your machine is still not starting the cycle, you will need to
replace the Lid Lock mechanism or ref the above link for temp bypass.
Mar 30, 2014 | Maytag Bravos Top Load Washer
Hoover nextra washing machine door wont lock / cycle start
sounds like the door lock mechanism. if this cannot signal it has engaged, to the board, no other function will work (you don't want the washer going with the door open, trust me :) )
Nov 08, 2013 | Hoover Nextra 160 HNWF 3137 Front Load...
Washer doesnt drain
Suds Detection
Sd is displayed when the machine/motor control, by analyzing drag on the basket, detects a suds-lock condition, and is steady on while the control then runs a mini-clean out cycle. If the clean out cycle is unable to correct the over-sudsing problem, the cycle ends and Sd flashes in the display. This may signify:
Excessive detergent usage.
Basket cannot engage during drain step.
Mechanical friction on drive mechanism, not allowing basket to engage.
Nov 04, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer fills and does the wash cycle then stops. doesnt rinse or spin
Most likely your lid switch is broken on the washer. I(t acts as a safety mechanism to stop the tub during spin should you open the lid.)
The switch is located under the top of the washer on the right side of the lid opening. It is activated by a plastic strike on the same side of the lid.
Jun 12, 2010 | Whirlpool LTE6234D Top Load Stacked...
Jan 03, 2010 | GE Spacemaker Washer and Dryer Electric...
The washer on my double stack won't drain or spin.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Without a complete model number, I'm guessing but usually, washers have a lid lock built in that prevents the washer from draining or spinning unless the lid is closed.
If the lid lock is defective, the washer probably won't go into spin mode.
Check yours for the lock, where it attaches and replace it. It's probably not too expensive.
Oct 27, 2009 | Kenmore Washing Machines
Agitator starts at begining of cycle before washer is full
Please be carful as running the agitator without enough water will overheat and kick out the motor, however it should be ok when it resets itself.
Yes, the machine should stop agitating when you lift the lid so this too is part of the problem.
After looking at the print I can only suggest that the cam contacts in the timer ( contacts 12 and 14) that start the motor are burned and stuck together.
Quentin
Sep 17, 2009 | Frigidaire FEX831CS Top Load Stacked...
Washing machine fills, but won't agitate
maytag washer dryer stack unit , model # lse7806ace washer fills with water but won't agitate or do anything else. I had the same problem a year ago and replace the lid switch asssemby and fuse and it worked fine until now. the switch clicks when I open and close the lid and the pink and orange wires show continuity with the lid closed.
Aug 29, 2008 | Maytag LSE7806A Top Load Stacked...
Kenmore stack washer/dryer model#11098752790
Check your lid switch ,if its not engaging replace it.
Jun 03, 2008 | Kenmore 98702 Stacked Washer/Dryer
GE GTUP270EMWW Washer Logo
105 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
