Question about Hardware & Accessories
How to fix a burnt timer on a Kingston AL/59389
It's al black horizontal lines/smudges over the printed page. How to cean this?
Black Horizontal Lines are normally caused by a Light Burnt Drum.
The drum in built into the toner cartridge for this machine so replacing the cartridge will fix the problem.
Jan 14, 2015 | HP LaserJet 4L Printer
Flashing Al o5
how old is machine could be sensor on element or burnt our element
Mar 20, 2012 | Hotpoint 24 in. FDW60 Free-standing...
After wash cycle finishes and buzzer goes off if you do not push the knob in the timer will continue to move until it reaches the next setting then will start that cycle
That is a burnt contact on the timer and to fix that the timer needs to be replaced. Click reply and give me BRAND and FULL EXACT model number as found on label inside of lid on the rim and ill give ya the timer part number
Aug 17, 2011 | Washing Machines
Whirlpool washer will occasionally be filling with water and pumping water out, problem will last until i turn timer knob to next action, after turning timer to "sweet spot" washing machine will...
These timers are normally sealed units (crimped and pressed sheet metal) and replaced as a unit.
If you could open one up, you'd find
that the contacts causing the intermittent problem are burnt from arcing. All washing machine timers
will eventually get this problem with enough use. As an electrician, you'll recognize that all switches
(washing machine timers are a series of switches oriented around a slow (timer) motor) are rated
for a given number of make/break cycles. Washing machine timer contacts are no different.
If you could actually "shine up" the offending pair of burnt contacts, another pair would soon
show the same symptoms, since all the contacts in your timer have endured the same number of
make/break cycles.
Feb 21, 2011 | Washing Machines
Hello all, Hope everyone is fine. I have a kingston 4 GB pendrive. My system got shutdown while my pendrive is connect to it. Now this pendrive is not detecting on any systems. Can any one help me how to...
your pendrive might have been burned due to a surge.. I have experienced this but the problem was the USB drive itself, the technician who assembled the desktop interchanged the USB connections making it very destructive to plug in any USB device.
Kingston usually has warranty. Have it replaced on the nearest service center or at the very least have it repaired. I wouldnt recommend you opening it unless you wanted to see the real cause. If it smells burnt then chances are your data is lost or the thumbdrive wouldnt work.
If it can no longer be detected in any system and your warranty is out and if you're desperate to have it fixed, you can bring it to any cellular repair shop, have them open it and check for burns.. Hope they have a means of retrieving it.
Hope this provides any help,
levibit
Dec 14, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Tengo u enredo Con La Instalación bosques temporizador de del 59.017 , ya Que bastante apagador sin neutro sin cable y saque y Siguiente Realice lo: 1 - cable de El universo del apagador Que TIENE...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Espanol minimo > 2 foto/dibujo
http://waterheatertimer.org/images/Timer-es2-1000.jpg
http://waterheatertimer.org/images/Woods-dial-450.jpg
Instrucciones no espanol, no francais, no chino ...
Sep 22, 2010 | Woods Mechanical Inwall Timer 59017
My gardena timer suddely has a restricted water flow its the mechanical one thar has lasted about 15 years are parts available Ithink it may need a new diaphram.......Al
No joke, that is the longest I have ever heard of a Gardena timer working. I suspect you are correct about the diaphragm, but there is not much hope of finding new parts for that model. I suggest celebrating your amazing feat with a new (not as well made, sadly) Gardena timer and keep an eye out for a part at a garage sale to fix the old one when you can. I suspect you take very good care of your tools. So few people do anymore. Regards,
Farmerbear
Aug 18, 2010 | GARDENA Melnor/Gardena 31169 Watering...
Tarjeta no inicializada
Debes formatearla. Para esto debes usar la opcion correspondiente dentro de la camara o el aparato donde estes utilizando la memoria.
ATENCION: Al formatear se borra TODA la informacion de la tarjeta.
Mar 28, 2010 | Kingston 4GB Secure Digital High Capacity...
Will Purchase Oven or Parts from Non-Working Oven.
Al, your switch is likely a DKJ/1-60. As you know you can\'t find one, however there is a switch that will fix your oven. It\'s part # 05XDE5218104600 and is made for Delonghi ovens. It looks the same as the DKJ/1-60 and works the same. Get it at The Gourmet Depot website for $10 + shipping
May 13, 2009 | Black & Decker CTO649 Toaster Oven with...
Hardware & Accessories Logo
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
