Question about Kenwood KDC-BT652U
Display issues blank display
Blank display
Please check the connection to the display again. The main board could be the issue.
Jul 09, 2015 | Office Equipment & Supplies
It is blank. When connected to an external monitor i can see the display on the LCD projector but not on the laptop. When I disconnect the LCD projector then the laptop monitor displays for a second and...
It could be a Operating system issue, or a hardware voltage issue.
I would place my bets on the OS. Simple solution is to update your driver, if that does not work, reinstall your OS
Feb 24, 2011 | Sony VAIO VGN-NR310E/S Laptop
Radio works but display screen black
The 2003 - 2005 Accord CD/Radio unit is prone to display failure. Honda had issued a TSB some years back but you may be beyond the warranty period. We repair this display issue. Check it out: www.autoclockrepair.com
Oct 05, 2010 | 2004 Honda Accord
My Laptop (Toshiba A215) won't booting and had blank screen. I check the hdd it's ok but why the display still blank. Thank you
it is issue with the display screen u need to take to service center to replace display cable or display
Jun 07, 2010 | Toshiba Satellite A215-S4747 Notebook
Blank display on my camera
6280 me operation failed aaraha he
Apr 12, 2010 | Cameras
Radio works but display is blank. help?
Jeep radios are notorious for having display and channel issues. If your display is not operative, then your radio internally damaged and is not worth repairing. It is better to replace it at this point.
Nov 22, 2009 | 2002 Jeep Grand Cherokee
N95 display gone suddenly........do no Y ? ??
cost would be very less dont worry try reloading thhe software
Jul 03, 2009 | Nokia N95 Cellular Phone
My Inspiron 6000 screen is blank. I can get an image on a monitor through the serial port, but when on its own, the notebook screen is black. I have noticed that there is a brief flash when booting up, but...
Hi ,
1. You can check the display on external monitor>If the display is blank on external monitor also, its pretty clear that there is an issue with system board
2. If the Exernal monitor comes up fine, it will be an issue with the display of the laptop, you can cross check the issue by booting the computer to BIOS, IF you get same response on BIOS as well. Its an issue with the Display itself you can replace the display panel.
Hopefully, its covered under warranty ;)
Jun 29, 2009 | Dell Inspiron 6000 Notebook
PHASER 8500 XEROX
Is the display saying NOT READY, or is it not comming on.
If the display is blank there is a known problem with those displays and Xerox will replace them free of charge.
If you have a blank display, call 1-800-835-6100.
If I am misunderstanding the issue provide more details please.
Feb 29, 2008 | Xerox Phaser 8500N Printer
Kenwood KDC-BT652U Logo
23 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
