Question about Zanussi WJS1265W Front Load Washer/Dryer
Hi, John Lewis JLWM 1407....when door shut door closed light does not illuminate and when start button pressed spin speed light immediately goes to 'none', machine makes whirring noise and wash selection time goes to zero and machine beeps as if cycle finished. Five years old....fixable or new machine? Thank you.
  • 1462 Answers
SOURCE: Reluctant to start
problem is almost certainly the door interlock. to replace, remove the plastic clip holding the door boot onto the cabinet and peel it back adjacent to the door lock. the door lock is just held in by two screws accessible at the front of the cabinet. not an expensive part. easy job - takes about 10 min
Posted on Mar 26, 2007
  • 19 Answers
SOURCE: problem with washing machine
New door sensor im afraid,unless the machine senses that the door is properly shut none of your wash or spin cycles will start.Sensor located inside washer casing , where lock pin on door handle enters machine.It may just be loose,try tightening the two screws either side of lock keep.If it needs replacing you will need to UNPLUG washer ,remove lid and slide your arm down inside front of washer to access.Good luck.
Posted on Aug 23, 2007
  • 96 Answers
SOURCE: Zanussi ZWF1437W washing machine - wont start
The error message "Err" usually indicates that the wash program and option are not compatible. 40 degrees and 900 rpm Spin should be o.k.. I would try another wash program with no special options and see if the problem goes away.
Posted on Mar 07, 2008
SOURCE: Machine won't start and clicks if turned on with door open
Ok, this is the fix:
No payload. Close the door. Press off, then press on. Then enter a program starting by selecting the fabric and the others as usual. Do not press start, instead press the slip button to advance the programme to the very last phase, ie drain and empty. Then press start. It will perform this operation with no load and pump out the “no water”. This part takes 5 minutes. After the 5 mins the programme will end and the machine will beep annoyingly, but the computer will be reset and you can clear the program and use the machine as normal.
Why?
I had the same problem. The stupid computer inside remembers the program whilst it’s off and unplugged. What has happened is you accidently pressed start and start again to pause it in very quick succession. This confuses the computer and it thinks that a program is in progress. This is why it wants to close the door. There is no problem with the latch (unless it is a separate problem). You have to let it play out a program to reset it, which is why you can play the very last “drain” segment.
Question.
Presumably there’s a way to reset the computer either by a secret button combo or shorting out two pins from the computer box. I don’t know. If someone knows this please tell me.
Good Luck!
Posted on Nov 18, 2008
SOURCE: simpson ezi loader washing machine clicks 3 times
It sounds like a door switch fault see if the end light and the start/pause light are flashing count the flashes if end flashes 4 times and the start/pause once or maybe more this could be error 41, door switch fault.A door switch would cost about $ 20 but there may still be a problem with the main Programmer.
Good luck.
Posted on May 03, 2010
Entrance light on Lift Master garage door opener won't stay on when door is opened ?
Light Feature
Activate the Light Feature
  1. Close the garage door.
  2. Start with the garage door opener lights "ON".
  3. Press and hold the light button for 10 seconds. (Upon pressing the light button, the lights will immediately turn off and come on 10 seconds later.)
Deactivate the Light Feature
  2. Start with the garage door opener lights "OFF".
  3. Press and hold the light button for 10 seconds. (Upon pressing the light button, the lights will immediately turn on and go off 10 seconds later.)
Light Timer
Press the Light button to turn the opener light on or off. It will not control the opener lights when the door is in motion. If you turn it on and then activate the opener, the light will remain on for 4-1/2 minutes. Press again to turn it off sooner. The 4-1/2 minute interval can be changed to 1-1/2, 2-1/2, or 3-1/2 minutes as follows:
  1. Press and hold the Lock button until the light blinks (about 10 seconds).
  2. A single blink indicates that the timer is reset to 1-1/2 minutes.
  3. Repeat the procedure and the light will blink twice, resetting the timer to 2-1/2 minutes.
  4. Repeat again for a 3-1/2 minute interval, etc., up to a maximum of four blinks and 4-1/2 minutes.
Oct 20, 2017 | Building Materials
Just got my 2003 explorer sport trac dome light dont come on when you open the doors but they come on when you push the button to turn them on how do I get them to come on when I open the doors?????
The instrument cluster illuminates the interior lamps when an unlock signal is received from the vehicle security module. The illuminated entry feature will be canceled when any of the following conditions are met:
  • 25 seconds have elapsed since the illuminated entry feature was activated and the interior lamp control is not activated (door ajar or courtesy lamp switch on).
  • The instrument cluster receives a request from the vehicle security module (remote transmitter lock button pressed) and the interior lamp control is not activated.
  • The ignition is in the RUN or START position and the interior lamp control is not activated.
The instrument cluster illuminates the courtesy lamps when any door is open or ajar. The courtesy lamps shuts off when the doors are closed and the illuminated entry feature is not active or when the vehicle speed is greater than 5 mph (8 km/h). The interior lamps are not reactivated until the vehicle speed is less than 3 mph (5 km/h) and a new door open warning lamp signal is received.
The instrument cluster controls the courtesy lamps illuminated entry function by activating the battery saver relay.
The panel dimmer switch is integrated into the headlamp switch and controls the interior lamps by activating the instrument cluster through circuit 1034 (BK/WH).
The vehicle security module sends a signal to the instrument cluster on the UBP network circuit to indicate a request to turn the illuminated entry feature on or off.
The on-demand lamps, glove compartment assembly, homelink module, puddle lamps and illuminated vanity mirrors are controlled by the battery saver relay. The battery saver relay becomes active (relay coil is energized) when the instrument is in the awake mode, or in the sleep mode (relay coil is de-energized).
Nov 28, 2016 | 2003 Ford Explorer Sport Trac
Oko 72630. Why is it stuck on rinse cycle?
Could be several reasons:
- Selected the "Night cycle" program (means standing with the drum full of water, reason: too much noise in the spin cycle)
- Set to the "Rinse hold" (means standing with the drum full of water, reason: wrinkles on the clothes)
According to your description I think that this is not a failure otherwise error E20 will be appears on display.
Once the washing programme has come to an end, END illuminates on the programme progress display.
If RINSE HOLD was selected, the display beside the START/ PAUSE button flashes.
1. After a rinse hold, the water must first be pumped out:
- Either press the START/PAUSE button (the water is pumped out and the washing is spun according to the completed programme;
After the START/PAUSE button is pressed again, the spin speed can still also be changed during spinning), or
- Turn the programme selector to PUMP OUT and press the START/PAUSE button (the water is pumped out without spinning),or
- Turn the programme selector to SPIN or SHORT SPIN and press theSTART/PAUSE button (the water is pumped out and the washing is spun or gently spun).
At the end of this programme step, the END indicator will illuminate.
2. Open the door.
As soon as the DOOR indicator lights up green, the door can be opened.
Dado
Aug 15, 2015 | AEG Washing Machines
2002 ford expedition interior lights are not on what fuse is it?
Courtesy Lamps - central junction box. fuse # F1.21 that goes to interior lamp relay in the instrument cluster and F.24 this fuse powers battery saver relay .
Interior Lighting The interior light system consists of the following:
  • front map lamp assembly
  • front door courtesy lamp
  • generic electronic module (GEM)
  • glove box lamp assembly
  • central security module
  • interior lamp switch
  • interior lamp relay
  • illuminated vanity mirrors (Navigator only)
  • reading lamp assembly
  • rear courtesy lamp
  • running board lamp
  • underhood lamp assembly
  • The generic electronic module (GEM) illuminates the interior lamps when an unlock signal is received from the remote anti-theft personality central security module. The illuminated entry feature will be canceled when any of the following conditions are met:
    • The GEM receives a request from the central security module (remote transmitter lock button pressed) and the interior lamp control is not activated.
    The GEM will illuminate the interior lamps when any door is open or ajar. The interior lamps are; the dome lamp, the rear cargo lamp, the door courtesy lamp and the side rail lamps. The courtesy lamps will shut off when the doors are closed and the illuminated entry feature is not active or when the vehicle speed is greater than 5 mph (8 km/h). The interior lamps will not be reactivated until the vehicle speed is less than 3 mph (5 km/h) and a new door open warning lamp switch is received.
    The GEM controls the interior lamps illuminated entry function by activating the interior lamp relay.
  • You have an electronic control module and relays involved in the operation of these lights also !
  • What
    Jan 08, 2015 | 2002 Ford Expedition
    Motor won't turn on Samsung VRT Plus WF433B*GJ**
    When washing heavily soiled loads, do not overload your washer in order to assure good cleaning results.
    To add a forgotten item:
    1. Press the Power button.
    2. Press the Start/Pause
    3. Wait for the door lock light to go out (Immediately).
    4. Add the item, close the door, and press the Start/Pause
    The door safety state continues for 15 seconds and the cycle is restarted.
    ensure thorough cleaning,
    To
    Try washing bedding, towels, undergarments,
    contact using the ActivFresh
    GETTING STARTED
    1. Load your washer.
    2. Close the door.
    Z_
    Push the laundry into the drum completely to prevent the laundry from being caught in the door or
    ....... from falling out of the drum.
    3. Press the Power button.
    4. Add detergent and additives to the dispenser (page 20-21).
    5. Select the appropriate cycle and options for the load (page 14-16).
    6. Press the Start/Pause
    7. The Wash Indicator light will illuminate.
    8. The estimated cycle time will appear in the display.
    The time may fluctuate to better indicate the time remaining in the cycle.
    The actual time required for a cycle may differ from the estimated time in the display depending on the
    water pressure, water temperature, detergent, and laundry.
    9. Before your washer starts to fill, it will make a series of clicking noises to check the door lock and do a
    quick drain.
    When the cycle is complete, the door lock light will go out and "End" will appear in the display.
    DO NOT attempt to open the door until the door lock light is off. To add a forgotten item, see
    "Loading your washer" section (page 13).
    When your washer is restarted after a pause, expect a delay of up to 15 seconds before the cycle
    continues.
    Pressing Power button cancels the cycle and stops your washer.
    The pre wash, wash, rinse and spin indicator lights will illuminate during those portions of the cycle
    Nov 28, 2013 | Samsung 4.3 cu. ft. VRT Plus , Steam and...
    How do I use the Child Lock option on Samsung WF-B1456GW?
    You can use the child lock feature in 2 ways.
    1. To prevent operation of the washing machine when no wash cycle is running
    To set this feature, switch the machine on using the POWER button at the top-left of the control-panel. Next, press and hold both the SPIN and RINSE buttons for about 3 seconds - until the child lock light indicator on the control panel illuminates. All functions of the washing machine will now be disabled apart from POWER ON/OFF until such time as the child lock is deactivated.
    To deactivate the child lock, press and hold the SPIN and RINSE buttons again until the child lock light indicator on the control panel goes out.
    2. To prevent any tiny fingers from tampering with the machine while a program is running.
    After pressing the START/PAUSE button to start the wash cycle, press and hold the SPIN and RINSE buttons until the child lock light indicator illuminates. All buttons on the control panel will now be disabled until the child lock has been disabled. When the wash cycle has finished, you will need to switch the child lock off again to reactivate the buttons. Once you have finished using the washer, reactivate the child lock again before switching the power off as above.
    The feature can also be used when using the delayed start feature, but needs to be set after pressing the START/PAUSE button.
    Hope this helps. Please let me know if I can be of further assistance.
    Regards,
    BElectric
    Feb 09, 2011 | Washing Machines
    CRFATSMAN opener - Problem when closing only
    It sounds like you have a loose connection. Pull the logic board and check for bad connections especially around the small transformer.
    Feb 23, 2010 | Sears Craftsman LiftMaster Chamberlain...
    Light comes on wont spin wsr-maytag mod m6d5600tqo ser mw2607338 type bwsr-nat-1206006-fm22 light wont turn off even with door closed dryer is not old new in 2008
    Check the door switch. It just might be sticking which is why the light remains on and the dryer won't spin...
    J. Lewis
    Dec 21, 2009 | Maytag Dryers
    Lg intellowasher model wm 1290fhb door will not open. tried waiting 1 hour! tried power on and off, tried child lock
    1. Press the SPIN SPEED and SOIL LEVEL buttons simultaneously.
    2. Press the Power button, while pressing the SPIN SPEED and SOIL LEVEL buttons. Then buzzer will sound twice.
    3. Press the Start/Pause button repeatedly with about 1 second interval until the lamps goes out.
    4. The washer powers off and unlock the door.
    Oct 18, 2009 | LG WM-1290FHB Front Load Washer
    Kenmore 16039 - "Clean" light is flashing & dishwasher won't start
    Watch the light closely. If it blinks 7 times then pauses, this indicates a heater or door latch issue.
    Press the following buttons in sequence: Hi Temp Wash, Heated Dry, Hi Temp Wash, Heated Dry.
    If this doesn't work, check the tech sheet. (should be stuck to inside of the bottom toe panel)
    All lights should illuminate then a diagnostic sequence will start.
    Listen carefully, as soon as you hear the water begin to fill, open the door and feel the heater. if cold, check the heater for continuity (should be around 10ohms)
    Also, bend the door catch on the dishwasher tub downward, this will engage the door latch better. Don't bend too far as it will hit the door while closing.
    Jun 15, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
    Zanussi WJS1265W Front Load Washer/Dryer Logo
    106 people viewed this question
    Top Zanussi Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
    shaun taylor
    Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
